TheTwister
Cannot login through GUI
Sat Aug 03, 2019 1:19 pm
I am unable to log into my Raspberry Pi using the GUI.
But able to login using Putty.
I only have one username and password.
Any ideas?
Re: Cannot login through GUI
Sat Aug 03, 2019 1:49 pm
Have you changed the userid from 'pi'?
Have you connected your new userid to the following groups: adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi?
Andyroo
Sat Aug 03, 2019 2:23 pm
Is Putty set to use certificates or have the password hard coded?
It could be the national language on the Pi not matching your keyboard.
B.Goode
Sat Aug 03, 2019 2:49 pm
Any ideas?
My idea is to ask you to specify what Operating System you are running on your RPi.
(Because by default the recommended Raspbian Operating System simply starts in the Raspberry Pi Desktop (GUI) without any login being required.)
TheTwister
Sat Aug 03, 2019 4:18 pm
Thank you for the replies.
- I haven't created a new user ID.
- I am using Raspbian 9
- However I am not sure if the languages are correct. I tried VNCing also but still no luck
B.Goode
Sat Aug 03, 2019 4:42 pm
Is this a new installation of the now-superceded Raspbian Stretch Operating System?
Or something that used to work but has recently 'broken'?
Which of the 3 variants of Raspbian Stretch are you running?
This might be a symptom of having no free space left on the root filesystem of your Operating System.
The
df -h
command might reveal this, there should be no entries at or very near to 100%.
fbe
Sat Aug 03, 2019 5:06 pm
Autologin to the desktop as user pi is the default behavior for a raspbian image. If you disabled that you can enable it via PuTTY with raspi-config.
sudo raspi-config
then select "3 Boot Options", "B1 Desktop/CLI", "B4 Desktop Autologin".
Then after reboot on the desktop you can try in a terminal window or editor whether or not the letters are shown that you hit on your keyboard...
TheTwister
Sat Aug 03, 2019 6:17 pm
The
df -h
Ah yes My
 /dev/root
is showing 100% so that could be the reason. I hardly save stuff on there but might be updates of programs or cache to something.
Is there a command i can use to remove old versions of files?
Sat Aug 03, 2019 6:31 pm
sudo rm /var/log/* will get you enough space to logon and look at where the space is being used.
If your SDCard has NOOBS you'd lost 1.3GB before installing Raspbian. With Buster Raspbian doesn't really fit on an 8GB card. Minimum recommended size is 16GB now.
B.Goode
Sat Aug 03, 2019 6:32 pm
The Raspbian root filesystem does not store versions of files.
The rm (remove) command can be used to delete/erase files.
rpdom
Sat Aug 03, 2019 7:24 pm
If you've been running sudo apt-get upgrade (or dist-upgrade) at all, you should run sudo apt-get clean every now and then to delete the old installation files that are no longer needed.
If you only use sudo apt upgrade (or full-upgrade) you don't need to do that.
Unreadable squiggle
