sharmajar
Quake 3 Compiling
Wed Dec 05, 2012 6:53 pm
Hi Forum
Just starting out with my pi and am attempting compile quake 3 from the ioquake source code on git hub. After I follow the usual instructions of installing the dependant packages that are git, gcc, build-essential and libsdl1.2-dev as well as modifying the build.sh file in nano, I run sudo ./ build.sh and run into this error.
CC code/es/es_glimp.c
CC code/es/etc1encode.c
In file included from /opt/vc/include/interface/vcos/vcos_assert.h:149:0,
                 from /opt/vc/include/interface/vcos/vcos.h:114,
                 from /opt/vc/include/interface/vmcs_host/vc_dispmanx.h:33,
                 from /opt/vc/include/bcm_host.h:46,
                 from /opt/vc/include/EGL/eglplatform.h:95,
                 from /opt/vc/include/EGL/egl.h:36,
                 from code/es/es_glimp.c:36:
/opt/vc/include/interface/vcos/vcos_types.h:38:33: fatal error: vcos_platform_types.h: No such file or directory
compilation terminated.
CGAME_CC code/cgame/cg_main.c
code/es/etc1encode.c:68:12: warning: ‘dsize’ defined but not used [-Wunused-variable]
code/es/etc1encode.c:72:18: warning: ‘ldropped’ defined but not used [-Wunused-variable]
code/es/etc1encode.c:72:28: warning: ‘ltested’ defined but not used [-Wunused-variable]
code/es/etc1encode.c:764:27: warning: ‘block_encode_search’ defined but not used [-Wunused-function]
make[2]: *** [build/release-linux-arm/client/es_glimp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
code/es/etc1encode.c: In function ‘etc1_compress_tex_image’:
code/es/etc1encode.c:1107:36: warning: ‘b’ may be used uninitialized in this function [-Wuninitialized]
code/es/etc1encode.c:1106:36: warning: ‘g’ may be used uninitialized in this function [-Wuninitialized]
code/es/etc1encode.c:1105:36: warning: ‘r’ may be used uninitialized in this function [-Wuninitialized]
make[2]: Leaving directory `/home/pi/quake3'
make[1]: *** [targets] Error 2
make[1]: Leaving directory `/home/pi/quake3'
make: *** [release] Error 2
I've checked the build.sh for any errors twice and there are none.
I just really don't know where to go from here.
Help
algotech
Re: Quake 3 Compiling
Sun Jan 27, 2013 3:21 pm
you may want to check the following post : https://github.com/OpenELEC/OpenELEC.tv/issues/1541
basically adding the actual path to that header in build.sh solves the problem
on my PI I have added this variable:
INCLUDE_DIR2="/opt/vc/include/interface/vcos/pthreads"
and then added it to the end of CFLAGS section :
CFLAGS="-DVCMODS_MISC -DVCMODS_OPENGLES -DVCMODS_DEPTH -DVCMODS_REPLACETRIG -I$INCLUDE_DIR -I$INCLUDE_DIR2" \
on your PI it could be different so just do "find / -name vcos_platform_types.h"
regards
sharmajar
Sun Jan 27, 2013 6:28 pm
Thanks algotech
I actually figured that out myself after reading the build.sh file.
Thanks anyway though
But I also have another problem
My pi decides that around 45 mins into compiling it gives me the error
"file example.so", file format not recognised, treating as linker script
And then stops compiling
My pi does not recognise the .so file extension
Help please!?
dextrus
Sun Jan 27, 2013 6:44 pm
Quite detailed instructions here (I don't think I could make them any more detailed?!):
http://www.pi-fun.com/index.php/projects/quake3-3dtv/
Assumption is of course, that you are using Raspbian. Later in this project we'll be exploring the code (when I get time).
/Dextrus
Have more FUN with your Pi. Visit www.pi-fun.com
