AaronRPI
Monitor HELP
Tue Jul 30, 2019 11:10 am
HELP!   I have a working monitor that i have been using with my raspberry  pi. Yesterday, i installed  usb mobile monitor  driver for rpi's so i can work on my pi somewhere  else then my office. When i rebooted the pi, the screen did not fit my monitor! The monitor has 2 inches of blackness on the right  side and everything is squished together.
PLZ HELP!
P.S. i couldn't even get usb mobile monitor to work!!
PLZ HELP PLZ😨😲😳
"I will go anywhere as long as it is forward" David Livingstone
Andyroo
Re: Monitor HELP
Wed Jul 31, 2019 1:08 pm
I would check cmdline.txt and config.txt for any entries and comment them out.
AaronRPI
Re: Monitor HELP
Thu Aug 01, 2019 10:26 am
I installed the driver (raspberryin.zip) off their website, so i did not enter anything into the terminal. Also, i just remembered i did not do sudo apt update before i insalled it.
P.S. config.txt?
aBUGSworstnightmare
Re: Monitor HELP
Thu Aug 01, 2019 3:14 pm
P.S. config.txt?
as you did not mention WHAT monitor and Pi and OS your're using troubleshooting will be hard to impossible ...
AaronRPI
Re: Monitor HELP
Fri Aug 02, 2019 11:03 am
I am using a rpi 3 B+ running NOOBS with an LG monitor.
Re: Monitor HELP
Fri Aug 02, 2019 11:36 am
The question the aBUGSworstnightmare asked is still valid.
NOOBS is not an Operating System. It is an OS installer and boot selector.
Are you running Raspbian (installed from NOOBS) or something else?
Is it the current Buster release or an old one like Stretch?
LG Is a manufacturer. That doesn't tell us which monitor you are using. Has it got a model number?
All of these details are important to give us information on how to help you.
AaronRPI
Re: Monitor HELP
Sat Aug 03, 2019 10:55 am
I am using linux, and i can not find the monitor's modle number. I do not think the monitor is the problem, i think it is the HDMI output. Also, the monitor has no signal from pi part way through the boot. It is acting like the HDMI cable is not fully in, which happened and gave me the same problem i have now, but it was an easy fix. I already checked all the cables connecting the pi to the monitor.
AaronRPI
Re: Monitor HELP
Thu Aug 22, 2019 10:01 am
How do i reset my pi without shift because i have a wireless keyboad. Can i do it from the terminal?
Re: Monitor HELP
Thu Aug 22, 2019 10:13 am
What do you mean by "reset"?
What process needs "shift"?
What keyboard doesn't include a "shift"?
This is a doctor free zone.
Re: Monitor HELP
Thu Aug 22, 2019 10:18 am
If you are referring to NoobS Recovery read the ReadMe:
https://github.com/raspberrypi/noobs/bl ... /README.md
Retired disgracefully.....
