billrv
Re: RaspberryPi 4 as access point BRIDGE not working
Tue Aug 06, 2019 5:57 am
I tried the original instructions for setting up a bridge and it didn't work and when it did it wasn't reliable.
I tried the newer instructions for setting up the bridge from 7/31 and they work, at least for now.
But I need the bridge to have a static IP address in my network. How do I specify that?
EDIT: added...
I need the bridge to have static IP address 192.168.2.39/16 and gateway 192.168.0.1. I also need DHCP to hand out addresses 192.168.2.37-38 to devices that connect to this AP. There will be other AP's on the network that will hand out different address ranges and other static IP addresses but all the same gateway.
Thanks,
Ernst
Tue Aug 06, 2019 6:16 am
Thanks,
I do not have the means to test at the moment but you could try for yourself to follow the instructions (see below) in /etc/dhcpcd.conf to specify a fixed address for the interface br0.
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
What I would try is to include the following (example) at the end of the file:
interface br0
Update: the above configuration works, tested on a Pi 4.
The road to insanity is paved with static ip addresses
billrv
Tue Aug 06, 2019 12:43 pm
Thanks,
#interface eth0
interface br0
OK. That worked. Thanks.
The gateway is supplying DHCP. I need this AP to hand out DHCP addresses 192.168.2.37-38 only on this AP. There will be other AP's on the network with different static IP's and need to hand our different DHCP address ranges. Is that something I need to configure on the router or can/must it be done on each AP? And how to specify?
epoch1970
Tue Aug 06, 2019 1:16 pm
A bridge only applies within a given network. A bridge is exactly like a physical network switch device.
Contrast that with a router, placed at the border between 2 networks.
You seem to want to use 2 networks, you don't need a bridge, you need to setup your Pi as a router.
EDIT
Nope. The term "Gateway" is exchangeable with "Router". So if you want a 192.168.2.0/24 network, the router/gateway needs to be somewhere on that same network, e.g. 192.168.2.1.
If the router at 192.168.2.1 has another interface, say at 192.168.0.10, it can allow traffic to cross over to the 192.168.0.0/24 network.
And from there to the internet I guess, via the router at 192.168.0.1.
saxicek
Sat Apr 04, 2020 9:45 pm
@ernst: in your guide you have:
iface br0 inet manual
Is the manual intended or should it be:
iface br0 inet dhcp
Unlike the others I am still facing issue that I can see the AP, I can connect to it but I don't get IP address from DHCP. When I tried tcpdump I saw DHCP requests on br0 but they were not coming to DHCP server (different machine). Seemed like they were not forwarded to the network. :-(
EDIT:
Found out the root cause of my issue - it was caused by firewall having default FORWARD policy set to DROP. To check your firewall rules run:
sudo iptables -L
If it has line "Chain FORWARD (policy DROP)" then you need to add rule that enables forwarding for br0. I've extended "/etc/network/interfaces" to:
auto br0
iface br0 inet dhcp
    bridge_ports eth0 wlan0
    post-up iptables -A FORWARD -p all -i br0 -j ACCEPT
