[Solved] USB HDD poweroff (HDD abruptly stop spinning when running the shutdown command)
Posted: Sun Jul 28, 2019 11:08 am
I have external 2TB WD usb HDD drive attached to my RP2/3. HDD works file. However its abruptly stop spinning during the shutdown procedure. IT produce specific scratch sound. The seems disk dont park the heads before cut off. For most modern HDD it safe, but sound still annoying.
I tried to use udisksctl to detach disk after umount procedure.
It works fine until logout, but not later. Unfortunately udisksctl require D-Bus. Thereafter it was not possible to use udisksctl after umount.target during shutdown procedure.
As i understood "udisksctl power-off " do 2 things: put hdd in sleep mode (ka stop spinning) and remove /dev/sda from list.
During shutdown I think its possible to replace udisksctl via hdparm (or etc). HDD will stop spinning. Rest will be done by OS automatically.
So i implemented here small properpoweroff sctipt and run it after umount.target :
No specific scratch sound anymore. Power off log:
HDD smart status possible to check by smartctl utulity. It show same values as official WD windows utility.
I think that "Power-Off_Retract_Count" should not grow after save poweroff
PS: I used 5V10A UPS for Pi, so HDD can take as mach power as it need.
PS: I did this topic because i did not find solution and it can be useful for others. If someone have comments you are welcome.
#umount
/bin/umount -f /dev/sda1
/bin/sleep 4
#detach
/usr/bin/udisksctl power-off -b /dev/sda
/bin/sleep 10
sudo nano /etc/systemd/system/properpoweroff.service
[Unit]
Description=[=======USB-HDD-spindown============]
DefaultDependencies=no
After=umount.target
Before=shutdown.target reboot.target halt.target
[Service]
ExecStart=/bin/bash /my/hddspindown
Type=oneshot
RemainAfterExit=yes
[Install]
WantedBy=shutdown.target
systemctl daemon-reload
sudo systemctl stop properpoweroff.service
sudo systemctl start properpoweroff.service
sudo systemctl disable properpoweroff.service
sudo systemctl enable properpoweroff.service
nano /my/hddspindown
# it comes after umount.target, and drives already unmounted but can spinning
# replace /dev/sda with your drive
/sbin/hdparm -Y /dev/sda
/bin/sleep 5
sudo chmod 744 /my/hddspindown
sudo poweroff
[ OK ] Started Show Plymouth Power Off Screen.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped dhcpcd on all interfaces.
[ OK ] Stopped LSB: Manage my cool stuff.
[ OK ] Stopped LSB: Manage my UPS.
[ OK ] Stopped target Basic System.
[ OK ] Stopped Forward Password Requests to Plymouth Directory Watch.
[ OK ] Stopped target Paths.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Sockets.
[ OK ] Closed triggerhappy.socket.
[ OK ] Closed Syslog Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Stopped target System Initialization.
[ OK ] Stopped target Swap.
Stopping Network Time Synchronization...
[ OK ] Stopped target Encrypted Volumes.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped Apply Kernel Variables.
Stopping Load/Save Random Seed...
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /run/user/0...
Unmounting /boot...
[ OK ] Unmounted /run/user/0.
[ OK ] Unmounted /boot.
[ OK ] Reached target Unmount All Filesystems.
Starting [=======USB-HDD-spindown============]...
[ OK ] Stopped File System Check on /dev/disk/by-partuuid/9b7bbdf9-01.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Removed slice system-systemd\x2dfsck.slice.
[ OK ] Started [=======USB-HDD-spindown============].
[ OK ] Reached target Shutdown.
[ 3281.364761] reboot: Power downI think that "Power-Off_Retract_Count" should not grow after save poweroff
sudo apt-get install -y smartmontools --no-install-recommends
sudo smartctl -ax --device=sat /dev/sda| grep "K "
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 208 206 021 - 4591
4 Start_Stop_Count -O--CK 100 100 000 - 740
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 100 253 000 - 0
9 Power_On_Hours -O--CK 099 099 000 - 1164
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 447
192 Power-Off_Retract_Count -O--CK 200 200 000 - 101
193 Load_Cycle_Count -O--CK 199 199 000 - 5080
194 Temperature_Celsius -O---K 120 101 000 - 32
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
||||||_ K auto-keep
[2019-07-28 14:48:10] 318ms
