MrDitchy
Pi 4 hangs on boot when 2 displays connected
Fri Jul 26, 2019 9:12 pm
Hi, I have a 1GB Pi 4 that will work perfectly on either my little portable TV (720p) or my computer monitor (1080p). However if I connect both screens I get the rainbow square on both then the 4 Raspberrys on the monitor connected to HDMI 0 and then nothing. If I power down and remove the cable from HDMI 1 it boots perfctly to whichever monitor is connected. I am at a loss as to why. I am also a beginner with Raspian so I will need clear instructions on how to input any help that can be offered. Thanks in advance.
pfletch101
Re: Pi 4 hangs on boot when 2 displays connected
Sat Jul 27, 2019 12:51 am
What are you using to power your Pi? This sounds like a power supply problem.
MrDitchy
Sat Jul 27, 2019 4:31 am
Hi Its a 5.1 volt 3 amp supply that i am using.
MrDitchy
Sat Jul 27, 2019 4:54 am
I have just tried another TV this time a 1080p model I get a no signal although my monitor on HDMI 1 appeared with just the trash can suggesting that it may a lack of power from the HDMI output. I will try and get a second computer monitor and see if that cures the problem. Again on boot both screens had the rainbow square.
So I booted the PI and then plugged the second screen(my 720p TV) into the HDMI 1 and now it works as the second screen. It may hang when booting but at least it works.
Cheers
pfletch101
Sat Jul 27, 2019 1:25 pm
Cheers
"A 5.1 V 3A supply" does not really answer the question I asked. This board is full of descriptions of problems caused by 'power supplies' which are really battery chargers and are unable to maintain their rated voltage and current simultaneously. I strongly suggest that you try getting and using the 'Official' Pi 4 power supply.
MrDitchy
Sun Jul 28, 2019 6:26 pm
Hi,The power supply came from an approved re-seller as part of a kit, so I hoped that it was fit for purpose. My intention is to buy an official supply just as soon as they are back in stock with an Australian plug.
pfletch101
Sun Jul 28, 2019 7:16 pm
My first Pi setup (3B) was bought "from an approved re-seller as part of a kit", and, although it initially seemed to be OK, the power supply started getting flaky after a few weeks. I do have one other non-official power supply that seems to be reliable, but my two official ones have never given me a moment's concern. My new Pi4 (when it is delivered - sigh!!) will have an official supply.
MrDitchy
Sun Jul 28, 2019 8:03 pm
As soon as i get an official supply I will post an update. Cheers
MrDitchy
Tue Aug 13, 2019 5:05 pm
Several items have arrived since my last post. A new 4 GB Pi, a new case and finally an official power supply. I assembled my 4 GB Pi into it's new case and transferred the SD card from my 1 GB Pi and ran it on a single monitor. Later I flashed a new micro SD and placed it in the 1 GB PI. A few days later my new official power supply arrived. I connected it to my 1 GB Pi hooked up the second monitor and it all worked. Then I tried with my 4 GB pi and ran into the same problem a hang on boot when 2 displays are connected. The only common component at this point was the micro SD card. I swapped the micro SD cards between the two Pi's and now my 4 GB Pi boots with both displays connected. I then tried with my old power supply and that also was able to boot the Pi with both displays connected. Both cards are up to date. I try to update as soon as I can.
So to cut a long story short, if your Pi 4 hangs on boot when 2 displays are connected, try a different micro SD card. The cards are different brands, the cheaper of the two is the one that allows the dual displays to work.
pfletch101
Tue Aug 13, 2019 5:46 pm
It seems highly improbable (but not impossible, I grant) that the make or specs of the system SD card is the cause of this. If I wanted to test this, I would clone the 'non-booting' (on the Pi4) system to the 'booting' SD card. My prediction is that the clone of the 'non-booting' system to the 'booting' SD card would not boot with two monitors connected, and that there is a system software difference between the two. Both being up to date does not rule this out.
MrDitchy
Wed Aug 14, 2019 6:53 am
I'm just glad that it all works properly. I guess that a software difference is the most probable cause, although it would be a lot of work to prove the theory.
Dawn567
Thu Aug 27, 2020 3:01 pm
I've got similar problem here. I'm using a raspberry pi 4B/4G and a CanaKit power supply that comes with the raspberry pi . My situation is different that the screen connected to HDMI0 boots correctly while the one connected to HDMI1 will freeze at the welcome screen with "polk it.service" at the bottom left corner.
I tried switching the monitors and ports and the behavior is consistent. Does anyone has any idea what is the problem here?
Thanks!
MrDitchy
Thu Aug 27, 2020 4:08 pm
A different micro SD cards with a fresh install sorted the issue for me. Maybe worth a try.
