A typically "crash" is when mouse just freeze, and keyboard works without any problems
Hardware: RAPOO 9060ms Wireless mouse/keyboard combo
New batterys
Below a typical dmesg (before it happeneds)
In this case i was plaing some minecraft when the mouse froze so i had to connect a logitec mousepi@raspberrypi:~ $ dmesg -c
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.58-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1245 SMP Fri Jul 12 17:31:45 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1280x1024@60 smsc95xx.macaddr=DC:A6:32:05:54:0A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=d9ed116f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735596K/4050944K available (8192K kernel code, 658K rwdata, 2340K rodata, 2048K init, 850K bss, 53204K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 659 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 27981 entries in 83 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000018] Switching to timer-based delay loop, resolution 18ns
[ 0.000239] Console: colour dummy device 80x30
[ 0.000262] console [tty1] enabled
[ 0.000303] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000324] pid_max: default: 32768 minimum: 301
[ 0.000585] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000603] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001350] CPU: Testing write buffer coherency: ok
[ 0.001750] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002383] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002539] rcu: Hierarchical SRCU implementation.
[ 0.003394] smp: Bringing up secondary CPUs ...
[ 0.004295] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005312] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006294] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006428] smp: Brought up 1 node, 4 CPUs
[ 0.006441] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006450] CPU: All CPU(s) started in HYP mode.
[ 0.006459] CPU: Virtualization extensions available.
[ 0.007235] devtmpfs: initialized
[ 0.017474] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017688] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017710] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.025021] pinctrl core: initialized pinctrl subsystem
[ 0.025860] NET: Registered protocol family 16
[ 0.028803] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.030261] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.030272] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.030465] Serial: AMBA PL011 UART driver
[ 0.033500] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.069270] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.071662] vgaarb: loaded
[ 0.072026] SCSI subsystem initialized
[ 0.072222] usbcore: registered new interface driver usbfs
[ 0.072272] usbcore: registered new interface driver hub
[ 0.072368] usbcore: registered new device driver usb
[ 0.090394] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:37, variant start
[ 0.100123] raspberrypi-firmware soc:firmware: Firmware hash is d2b1b7fb01475cb3914b2086299e32d724e832f1
[ 0.111636] clocksource: Switched to clocksource arch_sys_counter
[ 0.188961] VFS: Disk quotas dquot_6.6.0
[ 0.189034] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.189189] FS-Cache: Loaded
[ 0.189364] CacheFiles: Loaded
[ 0.189904] simple-framebuffer 3e97a000.framebuffer: framebuffer at 0x3e97a000, 0x280000 bytes, mapped to 0x(ptrval)
[ 0.189918] simple-framebuffer 3e97a000.framebuffer: format=r5g6b5, mode=1280x1024x16, linelength=2560
[ 0.194796] Console: switching to colour frame buffer device 160x64
[ 0.199180] simple-framebuffer 3e97a000.framebuffer: fb0: simplefb registered!
[ 0.208110] NET: Registered protocol family 2
[ 0.208757] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.208781] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.208846] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.208916] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.209034] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209063] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209349] NET: Registered protocol family 1
[ 0.209883] RPC: Registered named UNIX socket transport module.
[ 0.209893] RPC: Registered udp transport module.
[ 0.209902] RPC: Registered tcp transport module.
[ 0.209911] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.209927] PCI: CLS 0 bytes, default 64
[ 0.213001] Initialise system trusted keyrings
[ 0.213177] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.221919] FS-Cache: Netfs 'nfs' registered for caching
[ 0.222395] NFS: Registering the id_resolver key type
[ 0.222419] Key type id_resolver registered
[ 0.222428] Key type id_legacy registered
[ 0.222447] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.224650] Key type asymmetric registered
[ 0.224661] Asymmetric key parser 'x509' registered
[ 0.224769] bounce: pool size: 64 pages
[ 0.224807] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.224965] io scheduler noop registered
[ 0.224975] io scheduler deadline registered (default)
[ 0.225131] io scheduler cfq registered
[ 0.225142] io scheduler mq-deadline registered (default)
[ 0.225152] io scheduler kyber registered
[ 0.254108] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.254127] brcm-pcie fd500000.pcie: could not get clock
[ 0.254187] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.254224] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.311670] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.311942] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.311957] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.311974] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.312016] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.312153] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.314841] PCI: bus0: Fast back to back transfers disabled
[ 0.314858] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.315017] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.315077] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.315245] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.317820] PCI: bus1: Fast back to back transfers disabled
[ 0.317836] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.317883] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.317902] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.317932] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.317949] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.318009] pci 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.318031] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.321220] iproc-rng200 fe104000.rng: hwrng registered
[ 0.321434] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.321962] vc-sm: Videocore shared memory driver
[ 0.322351] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.332282] brd: module loaded
[ 0.341791] loop: module loaded
[ 0.342532] Loading iSCSI transport class v2.0-870.
[ 0.344149] libphy: Fixed MDIO Bus: probed
[ 0.344580] bcmgenet fd580000.genet: failed to get enet clock
[ 0.344595] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.344612] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.344628] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.344865] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.361663] libphy: bcmgenet MII bus: probed
[ 0.402155] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.403018] usbcore: registered new interface driver r8152
[ 0.403076] usbcore: registered new interface driver lan78xx
[ 0.403127] usbcore: registered new interface driver smsc95xx
[ 0.403391] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.403420] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.405178] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.405329] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 55
[ 0.405947] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.405961] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.405973] usb usb1: Product: xHCI Host Controller
[ 0.405984] usb usb1: Manufacturer: Linux 4.19.58-v7l+ xhci-hcd
[ 0.405995] usb usb1: SerialNumber: 0000:01:00.0
[ 0.406503] hub 1-0:1.0: USB hub found
[ 0.406563] hub 1-0:1.0: 1 port detected
[ 0.406959] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.406986] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.407005] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.407338] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.407352] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.407363] usb usb2: Product: xHCI Host Controller
[ 0.407374] usb usb2: Manufacturer: Linux 4.19.58-v7l+ xhci-hcd
[ 0.407385] usb usb2: SerialNumber: 0000:01:00.0
[ 0.407868] hub 2-0:1.0: USB hub found
[ 0.407921] hub 2-0:1.0: 4 ports detected
[ 0.409006] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.434571] dwc_otg fe980000.usb: base=(ptrval)
[ 0.634927] Core Release: 2.80a
[ 0.634939] Setting default values for core params
[ 0.634969] Finished setting default values for core params
[ 0.835294] Using Buffer DMA mode
[ 0.835304] Periodic Transfer Interrupt Enhancement - disabled
[ 0.835313] Multiprocessor Interrupt Enhancement - disabled
[ 0.835324] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.835380] Dedicated Tx FIFOs mode
[ 0.836034] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded2c000 dma = 0x00000000ded2c000 len=9024
[ 0.836059] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.836070] dwc_otg: Microframe scheduler enabled
[ 0.836157] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.836174] WARN::hcd_init_fiq:458: FIQ ASM at c07ae224 length 36
[ 0.836191] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[ 0.836226] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.836264] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.836295] dwc_otg fe980000.usb: irq 36, io mem 0x00000000
[ 0.836347] Init: Port Power? op_state=1
[ 0.836357] Init: Power Port (0)
[ 0.836598] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.836612] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.836623] usb usb3: Product: DWC OTG Controller
[ 0.836634] usb usb3: Manufacturer: Linux 4.19.58-v7l+ dwc_otg_hcd
[ 0.836645] usb usb3: SerialNumber: fe980000.usb
[ 0.837137] hub 3-0:1.0: USB hub found
[ 0.837185] hub 3-0:1.0: 1 port detected
[ 0.837752] dwc_otg: FIQ enabled
[ 0.837761] dwc_otg: NAK holdoff enabled
[ 0.837770] dwc_otg: FIQ split-transaction FSM enabled
[ 0.837783] Module dwc_common_port init
[ 0.837987] usbcore: registered new interface driver uas
[ 0.838095] usbcore: registered new interface driver usb-storage
[ 0.838254] mousedev: PS/2 mouse device common for all mice
[ 0.839408] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.839598] bcm2835-cpufreq: min=600000 max=1500000
[ 0.840165] sdhci: Secure Digital Host Controller Interface driver
[ 0.840173] sdhci: Copyright(c) Pierre Ossman
[ 0.840563] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.840934] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.843961] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.844100] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.844220] usbcore: registered new interface driver usbhid
[ 0.844229] usbhid: USB HID core driver
[ 0.844970] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.846581] [vc_sm_connected_init]: start
[ 0.854959] [vc_sm_connected_init]: end - returning 0
[ 0.856006] Initializing XFRM netlink socket
[ 0.856033] NET: Registered protocol family 17
[ 0.856111] Key type dns_resolver registered
[ 0.856501] Registering SWP/SWPB emulation handler
[ 0.857061] registered taskstats version 1
[ 0.857076] Loading compiled-in X.509 certificates
[ 0.864853] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.864917] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 33, base_baud = 0) is a PL011 rev2
[ 0.867828] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.868337] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.868946] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.868959] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.894814] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 0.913065] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.914673] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.916352] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.919238] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.920846] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.928870] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.931352] of_cfs_init
[ 0.931431] of_cfs_init: OK
[ 0.932060] Waiting for root device PARTUUID=d9ed116f-02...
[ 0.977228] random: fast init done
[ 0.981676] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.995270] mmc1: new high speed SDIO card at address 0001
[ 1.030177] mmc0: new ultra high speed DDR50 SDHC card at address 1234
[ 1.031306] mmcblk0: mmc0:1234 SA16G 14.5 GiB
[ 1.032465] mmcblk0: p1 p2
[ 1.060997] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.061037] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.061714] devtmpfs: mounted
[ 1.068304] Freeing unused kernel memory: 2048K
[ 1.131964] Run /sbin/init as init process
[ 1.163585] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.163600] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.163612] usb 1-1: Product: USB2.0 Hub
[ 1.165234] hub 1-1:1.0: USB hub found
[ 1.165491] hub 1-1:1.0: 4 ports detected
[ 1.491700] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.573858] systemd[1]: System time before build time, advancing clock.
[ 1.627414] usb 1-1.3: New USB device found, idVendor=24ae, idProduct=2000, bcdDevice=10.01
[ 1.627430] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.627443] usb 1-1.3: Product: RAPOO 2.4G Wireless Device
[ 1.627455] usb 1-1.3: Manufacturer: RAPOO
[ 1.637525] input: RAPOO RAPOO 2.4G Wireless Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:24AE:2000.0001/input/input0
[ 1.666051] NET: Registered protocol family 10
[ 1.667262] Segment Routing with IPv6
[ 1.701381] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.702134] systemd[1]: Detected architecture arm.
[ 1.704364] hid-generic 0003:24AE:2000.0001: input,hidraw0: USB HID v1.01 Keyboard [RAPOO RAPOO 2.4G Wireless Device] on usb-0000:01:00.0-1.3/input0
[ 1.713695] input: RAPOO RAPOO 2.4G Wireless Device Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:2000.0002/input/input1
[ 1.714080] input: RAPOO RAPOO 2.4G Wireless Device System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:2000.0002/input/input2
[ 1.715706] systemd[1]: Set hostname to <raspberrypi>.
[ 1.724293] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 1.782065] input: RAPOO RAPOO 2.4G Wireless Device Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:2000.0002/input/input3
[ 1.782642] hid-generic 0003:24AE:2000.0002: input,hiddev96,hidraw1: USB HID v1.01 Mouse [RAPOO RAPOO 2.4G Wireless Device] on usb-0000:01:00.0-1.3/input1
[ 1.985422] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 1.985442] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.346189] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.354792] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.360620] systemd[1]: Listening on Syslog Socket.
[ 2.382045] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.382195] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.382774] systemd[1]: Listening on udev Control Socket.
[ 2.388035] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.537981] i2c /dev entries driver
[ 3.723578] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.820980] systemd-journald[108]: Received request to flush runtime journal from PID 1
[ 4.329172] argon-mem feb00000.hevc-decoder: argon-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 4.329538] argon-mem feb10000.argon-local-intc: argon-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 4.329880] argon-mem feb20000.h264-decoder: argon-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 4.330205] argon-mem feb30000.vp9-decoder: argon-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 4.345485] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.347493] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.347508] [vc_sm_connected_init]: start
[ 4.349126] [vc_sm_connected_init]: installed successfully
[ 4.368240] media: Linux media interface: v0.10
[ 4.401575] videodev: Linux video capture interface: v2.00
[ 4.457012] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.459350] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.483049] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.499700] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.516336] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.534097] bcm2835_audio soc:audio: card created with 8 channels
[ 4.597118] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.597132] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.610659] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.610672] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.623093] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.623107] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.840327] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.840345] checking generic (3e97a000 280000) vs hw (0 ffffffffffffffff)
[ 4.840356] fb: switching to vc4drmfb from simple
[ 4.840574] Console: switching to colour dummy device 80x30
[ 4.841441] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.843227] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.843240] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.843249] [drm] No driver support for vblank timestamp query.
[ 4.843258] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.985305] Console: switching to colour frame buffer device 160x64
[ 4.989089] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.014514] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 5.113390] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.178102] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.189794] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.190499] usbcore: registered new interface driver brcmfmac
[ 5.411615] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.426192] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 7.136838] uart-pl011 fe201000.serial: no DMA platform data
[ 7.253138] random: crng init done
[ 7.253152] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.317113] 8021q: 802.1Q VLAN Support v1.8
[ 7.598036] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.751973] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 8.752263] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.831739] bcmgenet fd580000.genet eth0: Link is Down
[ 13.723185] Bluetooth: Core ver 2.22
[ 13.723223] NET: Registered protocol family 31
[ 13.723228] Bluetooth: HCI device and connection manager initialized
[ 13.723243] Bluetooth: HCI socket layer initialized
[ 13.723250] Bluetooth: L2CAP socket layer initialized
[ 13.723269] Bluetooth: SCO socket layer initialized
[ 13.731861] Bluetooth: HCI UART driver ver 2.3
[ 13.731868] Bluetooth: HCI UART protocol H4 registered
[ 13.731923] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.732036] Bluetooth: HCI UART protocol Broadcom registered
[ 13.912404] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.912411] Bluetooth: BNEP filters: protocol multicast
[ 13.912423] Bluetooth: BNEP socket layer initialized
[ 13.951819] Bluetooth: RFCOMM TTY layer initialized
[ 13.951834] Bluetooth: RFCOMM socket layer initialized
[ 13.951848] Bluetooth: RFCOMM ver 1.11
[ 20.029252] fuse init (API version 7.27)
dmesg: read kernel buffer failed: Operationen inte tillåten
pi@raspberrypi:~ $
Here is the dmesg after the crash.
(Continue from [ 20.029252] )
Just to be clear,. The keyboard works without any problems, its just the mouse that freeze[ 20.029252] fuse init (API version 7.27)
[ 282.311945] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[ 282.311988] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 5711.342594] ------------[ cut here ]------------
[ 5711.342723] WARNING: CPU: 0 PID: 493 at drivers/gpu/drm/vc4/vc4_firmware_kms.c:899 vc4_crtc_atomic_flush+0x98/0x9c [vc4]
[ 5711.342737] Modules linked in: snd_hrtimer snd_seq_dummy snd_seq snd_seq_device fuse rfcomm bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc joydev evdev brcmfmac brcmutil sha256_generic cfg80211 vc4 v3d gpu_sched drm_kms_helper drm rfkill snd_soc_core drm_panel_orientation_quirks snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops snd_bcm2835(C) bcm2835_codec(C) snd_pcm raspberrypi_hwmon bcm2835_v4l2(C) hwmon v4l2_mem2mem snd_timer bcm2835_mmal_vchiq(C) snd videobuf2_dma_contig v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) argon_mem uio_pdrv_genirq uio fixed i2c_dev ip_tables x_tables ipv6
[ 5711.343386] CPU: 0 PID: 493 Comm: Xorg Tainted: G C 4.19.58-v7l+ #1245
[ 5711.343396] Hardware name: BCM2835
[ 5711.343441] [<c0212c8c>] (unwind_backtrace) from [<c020d49c>] (show_stack+0x20/0x24)
[ 5711.343469] [<c020d49c>] (show_stack) from [<c09763e0>] (dump_stack+0xd4/0x118)
[ 5711.343497] [<c09763e0>] (dump_stack) from [<c0222270>] (__warn+0x104/0x11c)
[ 5711.343513] [<c0222270>] (__warn) from [<c02223c0>] (warn_slowpath_null+0x50/0x58)
[ 5711.343573] [<c02223c0>] (warn_slowpath_null) from [<bf561a08>] (vc4_crtc_atomic_flush+0x98/0x9c [vc4])
[ 5711.343782] [<bf561a08>] (vc4_crtc_atomic_flush [vc4]) from [<bf4fa81c>] (drm_atomic_helper_commit_planes+0x1a4/0x298 [drm_kms_helper])
[ 5711.343913] [<bf4fa81c>] (drm_atomic_helper_commit_planes [drm_kms_helper]) from [<bf563144>] (vc4_atomic_complete_commit+0x60/0x33c [vc4])
[ 5711.344005] [<bf563144>] (vc4_atomic_complete_commit [vc4]) from [<bf563500>] (vc4_atomic_commit+0xe0/0x194 [vc4])
[ 5711.344262] [<bf563500>] (vc4_atomic_commit [vc4]) from [<bf3e3410>] (drm_atomic_commit+0x5c/0x60 [drm])
[ 5711.344606] [<bf3e3410>] (drm_atomic_commit [drm]) from [<bf3e5508>] (drm_mode_atomic_ioctl+0x98c/0xb78 [drm])
[ 5711.344933] [<bf3e5508>] (drm_mode_atomic_ioctl [drm]) from [<bf3d0bc4>] (drm_ioctl_kernel+0xb4/0xf0 [drm])
[ 5711.345256] [<bf3d0bc4>] (drm_ioctl_kernel [drm]) from [<bf3d0ff8>] (drm_ioctl+0x230/0x3cc [drm])
[ 5711.345429] [<bf3d0ff8>] (drm_ioctl [drm]) from [<c03c3f64>] (do_vfs_ioctl+0xbc/0x804)
[ 5711.345451] [<c03c3f64>] (do_vfs_ioctl) from [<c03c46f0>] (ksys_ioctl+0x44/0x6c)
[ 5711.345470] [<c03c46f0>] (ksys_ioctl) from [<c03c4730>] (sys_ioctl+0x18/0x1c)
[ 5711.345489] [<c03c4730>] (sys_ioctl) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
[ 5711.345499] Exception stack(0xda9cbfa8 to 0xda9cbff0)
[ 5711.345511] bfa0: 00e7c6b0 be857a78 0000000c c03864bc be857a78 00000000
[ 5711.345524] bfc0: 00e7c6b0 be857a78 c03864bc 00000036 016fc010 017e66e0 017343b8 00000033
[ 5711.345537] bfe0: b6cf008c be857a44 b6cd7594 b696351c
[ 5711.345676] ---[ end trace 48a6cde497637d2e ]---
[ 7164.864970] ------------[ cut here ]------------
[ 7164.865162] WARNING: CPU: 0 PID: 0 at drivers/gpu/drm/drm_vblank.c:1026 drm_vblank_put+0xf0/0x100 [drm]
[ 7164.865170] Modules linked in: snd_hrtimer snd_seq_dummy snd_seq snd_seq_device fuse rfcomm bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc joydev evdev brcmfmac brcmutil sha256_generic cfg80211 vc4 v3d gpu_sched drm_kms_helper drm rfkill snd_soc_core drm_panel_orientation_quirks snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops snd_bcm2835(C) bcm2835_codec(C) snd_pcm raspberrypi_hwmon bcm2835_v4l2(C) hwmon v4l2_mem2mem snd_timer bcm2835_mmal_vchiq(C) snd videobuf2_dma_contig v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) argon_mem uio_pdrv_genirq uio fixed i2c_dev ip_tables x_tables ipv6
[ 7164.865633] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G WC 4.19.58-v7l+ #1245
[ 7164.865641] Hardware name: BCM2835
[ 7164.865671] [<c0212c8c>] (unwind_backtrace) from [<c020d49c>] (show_stack+0x20/0x24)
[ 7164.865690] [<c020d49c>] (show_stack) from [<c09763e0>] (dump_stack+0xd4/0x118)
[ 7164.865710] [<c09763e0>] (dump_stack) from [<c0222270>] (__warn+0x104/0x11c)
[ 7164.865726] [<c0222270>] (__warn) from [<c02223c0>] (warn_slowpath_null+0x50/0x58)
[ 7164.865899] [<c02223c0>] (warn_slowpath_null) from [<bf3f120c>] (drm_vblank_put+0xf0/0x100 [drm])
[ 7164.866221] [<bf3f120c>] (drm_vblank_put [drm]) from [<bf3f1240>] (drm_crtc_vblank_put+0x24/0x28 [drm])
[ 7164.866436] [<bf3f1240>] (drm_crtc_vblank_put [drm]) from [<bf561654>] (vc4_crtc_handle_page_flip+0x50/0x60 [vc4])
[ 7164.866536] [<bf561654>] (vc4_crtc_handle_page_flip [vc4]) from [<bf562f48>] (vc4_crtc_irq_handler+0xc8/0x144 [vc4])
[ 7164.866593] [<bf562f48>] (vc4_crtc_irq_handler [vc4]) from [<c02815a8>] (__handle_irq_event_percpu+0xc0/0x22c)
[ 7164.866609] [<c02815a8>] (__handle_irq_event_percpu) from [<c0281750>] (handle_irq_event_percpu+0x3c/0x8c)
[ 7164.866623] [<c0281750>] (handle_irq_event_percpu) from [<c02817f4>] (handle_irq_event+0x54/0x78)
[ 7164.866638] [<c02817f4>] (handle_irq_event) from [<c028564c>] (handle_fasteoi_irq+0xb4/0x194)
[ 7164.866655] [<c028564c>] (handle_fasteoi_irq) from [<c0280618>] (generic_handle_irq+0x34/0x44)
[ 7164.866673] [<c0280618>] (generic_handle_irq) from [<c0280d54>] (__handle_domain_irq+0x6c/0xc4)
[ 7164.866690] [<c0280d54>] (__handle_domain_irq) from [<c0202244>] (gic_handle_irq+0x4c/0x88)
[ 7164.866704] [<c0202244>] (gic_handle_irq) from [<c02019bc>] (__irq_svc+0x5c/0x7c)
[ 7164.866713] Exception stack(0xc1001ed8 to 0xc1001f20)
[ 7164.866723] 1ec0: c0209a84 00000000
[ 7164.866735] 1ee0: 40000093 40000093 c1004dbc c1000000 c1004e04 00000001 c10957ca c10a4a00
[ 7164.866747] 1f00: c0e67a38 c1001f34 c10051c4 c1001f28 00000000 c0209a88 40000013 ffffffff
[ 7164.866763] [<c02019bc>] (__irq_svc) from [<c0209a88>] (arch_cpu_idle+0x34/0x4c)
[ 7164.866783] [<c0209a88>] (arch_cpu_idle) from [<c09935a4>] (default_idle_call+0x34/0x48)
[ 7164.866801] [<c09935a4>] (default_idle_call) from [<c025423c>] (do_idle+0xec/0x17c)
[ 7164.866819] [<c025423c>] (do_idle) from [<c025458c>] (cpu_startup_entry+0x28/0x2c)
[ 7164.866836] [<c025458c>] (cpu_startup_entry) from [<c098cc80>] (rest_init+0xbc/0xc0)
[ 7164.866853] [<c098cc80>] (rest_init) from [<c0e00fe4>] (start_kernel+0x4b8/0x4e8)
[ 7164.866863] ---[ end trace 48a6cde497637d2f ]---
[10358.996389] usb 1-1.1: new low-speed USB device number 4 using xhci_hcd
[10359.134220] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c018, bcdDevice=43.01
[10359.134229] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10359.134235] usb 1-1.1: Product: USB Optical Mouse
[10359.134240] usb 1-1.1: Manufacturer: Logitech
[10359.142449] input: Logitech USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C018.0003/input/input6
[10359.142683] hid-generic 0003:046D:C018.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:01:00.0-1.1/input0
pi@raspberrypi:~ $
