webbsmurfen
Unstable driver (?) for wireless keyboard and mouse..
Fri Jul 26, 2019 1:29 pm
My wireless keyboard/mouse solution seems to crash once a while, using Buster (RPI 4 4gb) but it seems to work perfectly in earlier RPI models and in old Stretch
A typically "crash" is when mouse just freeze, and keyboard works without any problems
Hardware: RAPOO 9060ms Wireless mouse/keyboard combo
New batterys
Below a typical dmesg (before it happeneds)
pi@raspberrypi:~ $ dmesg -c
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.19.58-v7l+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1245 SMP Fri Jul 12 17:31:45 BST 2019
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] cma: Reserved 256 MiB at 0x000000001ec00000
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] random: get_random_bytes called from start_kernel+0xc0/0x4e8 with crng_init=0
[ 0.000000] percpu: Embedded 17 pages/cpu s39488 r8192 d21952 u69632
[ 0.000000] pcpu-alloc: s39488 r8192 d21952 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1280x1024@60 smsc95xx.macaddr=DC:A6:32:05:54:0A vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=d9ed116f-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 3735596K/4050944K available (8192K kernel code, 658K rwdata, 2340K rodata, 2048K init, 850K bss, 53204K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0x(ptrval) - 0x(ptrval) (10208 kB)
.init : 0x(ptrval) - 0x(ptrval) (2048 kB)
.data : 0x(ptrval) - 0x(ptrval) ( 659 kB)
.bss : 0x(ptrval) - 0x(ptrval) ( 851 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 27981 entries in 83 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000018] Switching to timer-based delay loop, resolution 18ns
[ 0.000239] Console: colour dummy device 80x30
[ 0.000262] console [tty1] enabled
[ 0.000303] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.000324] pid_max: default: 32768 minimum: 301
[ 0.000585] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000603] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001350] CPU: Testing write buffer coherency: ok
[ 0.001750] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002383] Setting up static identity map for 0x200000 - 0x20003c
[ 0.002539] rcu: Hierarchical SRCU implementation.
[ 0.003394] smp: Bringing up secondary CPUs ...
[ 0.004295] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005312] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.006294] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.006428] smp: Brought up 1 node, 4 CPUs
[ 0.006441] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.006450] CPU: All CPU(s) started in HYP mode.
[ 0.006459] CPU: Virtualization extensions available.
[ 0.007235] devtmpfs: initialized
[ 0.017474] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.017688] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017710] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.025021] pinctrl core: initialized pinctrl subsystem
[ 0.025860] NET: Registered protocol family 16
[ 0.028803] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.030261] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.030272] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.030465] Serial: AMBA PL011 UART driver
[ 0.033500] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.069270] bcm2835-dma fe007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.071662] vgaarb: loaded
[ 0.072026] SCSI subsystem initialized
[ 0.072222] usbcore: registered new interface driver usbfs
[ 0.072272] usbcore: registered new interface driver hub
[ 0.072368] usbcore: registered new device driver usb
[ 0.090394] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:37, variant start
[ 0.100123] raspberrypi-firmware soc:firmware: Firmware hash is d2b1b7fb01475cb3914b2086299e32d724e832f1
[ 0.111636] clocksource: Switched to clocksource arch_sys_counter
[ 0.188961] VFS: Disk quotas dquot_6.6.0
[ 0.189034] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.189189] FS-Cache: Loaded
[ 0.189364] CacheFiles: Loaded
[ 0.189904] simple-framebuffer 3e97a000.framebuffer: framebuffer at 0x3e97a000, 0x280000 bytes, mapped to 0x(ptrval)
[ 0.189918] simple-framebuffer 3e97a000.framebuffer: format=r5g6b5, mode=1280x1024x16, linelength=2560
[ 0.194796] Console: switching to colour frame buffer device 160x64
[ 0.199180] simple-framebuffer 3e97a000.framebuffer: fb0: simplefb registered!
[ 0.208110] NET: Registered protocol family 2
[ 0.208757] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.208781] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.208846] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.208916] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.209034] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209063] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.209349] NET: Registered protocol family 1
[ 0.209883] RPC: Registered named UNIX socket transport module.
[ 0.209893] RPC: Registered udp transport module.
[ 0.209902] RPC: Registered tcp transport module.
[ 0.209911] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.209927] PCI: CLS 0 bytes, default 64
[ 0.213001] Initialise system trusted keyrings
[ 0.213177] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.221919] FS-Cache: Netfs 'nfs' registered for caching
[ 0.222395] NFS: Registering the id_resolver key type
[ 0.222419] Key type id_resolver registered
[ 0.222428] Key type id_legacy registered
[ 0.222447] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.224650] Key type asymmetric registered
[ 0.224661] Asymmetric key parser 'x509' registered
[ 0.224769] bounce: pool size: 64 pages
[ 0.224807] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.224965] io scheduler noop registered
[ 0.224975] io scheduler deadline registered (default)
[ 0.225131] io scheduler cfq registered
[ 0.225142] io scheduler mq-deadline registered (default)
[ 0.225152] io scheduler kyber registered
[ 0.254108] brcm-pcie fd500000.pcie: dmabounce: initialised - 32768 kB, threshold 0x00000000c0000000
[ 0.254127] brcm-pcie fd500000.pcie: could not get clock
[ 0.254187] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.254224] brcm-pcie fd500000.pcie: MEM 0x600000000..0x603ffffff -> 0xf8000000
[ 0.311670] brcm-pcie fd500000.pcie: link up, 5.0 Gbps x1 (!SSC)
[ 0.311942] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.311957] pci_bus 0000:00: root bus resource [bus 00-01]
[ 0.311974] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.312016] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.312153] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.314841] PCI: bus0: Fast back to back transfers disabled
[ 0.314858] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.315017] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.315077] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.315245] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.317820] PCI: bus1: Fast back to back transfers disabled
[ 0.317836] pci_bus 0000:01: busn_res: [bus 01] end is updated to 01
[ 0.317883] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.317902] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.317932] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.317949] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.318009] pci 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.318031] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.321220] iproc-rng200 fe104000.rng: hwrng registered
[ 0.321434] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.321962] vc-sm: Videocore shared memory driver
[ 0.322351] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.332282] brd: module loaded
[ 0.341791] loop: module loaded
[ 0.342532] Loading iSCSI transport class v2.0-870.
[ 0.344149] libphy: Fixed MDIO Bus: probed
[ 0.344580] bcmgenet fd580000.genet: failed to get enet clock
[ 0.344595] bcmgenet fd580000.genet: GENET 5.0 EPHY: 0x0000
[ 0.344612] bcmgenet fd580000.genet: failed to get enet-wol clock
[ 0.344628] bcmgenet fd580000.genet: failed to get enet-eee clock
[ 0.344865] unimac-mdio unimac-mdio.-19: DMA mask not set
[ 0.361663] libphy: bcmgenet MII bus: probed
[ 0.402155] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus at 0x(ptrval)
[ 0.403018] usbcore: registered new interface driver r8152
[ 0.403076] usbcore: registered new interface driver lan78xx
[ 0.403127] usbcore: registered new interface driver smsc95xx
[ 0.403391] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.403420] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 0.405178] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 0.405329] genirq: irq_chip Brcm_MSI did not update eff. affinity mask of irq 55
[ 0.405947] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.405961] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.405973] usb usb1: Product: xHCI Host Controller
[ 0.405984] usb usb1: Manufacturer: Linux 4.19.58-v7l+ xhci-hcd
[ 0.405995] usb usb1: SerialNumber: 0000:01:00.0
[ 0.406503] hub 1-0:1.0: USB hub found
[ 0.406563] hub 1-0:1.0: 1 port detected
[ 0.406959] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 0.406986] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 0.407005] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 0.407338] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 0.407352] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.407363] usb usb2: Product: xHCI Host Controller
[ 0.407374] usb usb2: Manufacturer: Linux 4.19.58-v7l+ xhci-hcd
[ 0.407385] usb usb2: SerialNumber: 0000:01:00.0
[ 0.407868] hub 2-0:1.0: USB hub found
[ 0.407921] hub 2-0:1.0: 4 ports detected
[ 0.409006] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.434571] dwc_otg fe980000.usb: base=(ptrval)
[ 0.634927] Core Release: 2.80a
[ 0.634939] Setting default values for core params
[ 0.634969] Finished setting default values for core params
[ 0.835294] Using Buffer DMA mode
[ 0.835304] Periodic Transfer Interrupt Enhancement - disabled
[ 0.835313] Multiprocessor Interrupt Enhancement - disabled
[ 0.835324] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.835380] Dedicated Tx FIFOs mode
[ 0.836034] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = ded2c000 dma = 0x00000000ded2c000 len=9024
[ 0.836059] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.836070] dwc_otg: Microframe scheduler enabled
[ 0.836157] WARN::hcd_init_fiq:457: FIQ on core 1
[ 0.836174] WARN::hcd_init_fiq:458: FIQ ASM at c07ae224 length 36
[ 0.836191] WARN::hcd_init_fiq:497: MPHI regs_base at f0810200
[ 0.836226] dwc_otg fe980000.usb: DWC OTG Controller
[ 0.836264] dwc_otg fe980000.usb: new USB bus registered, assigned bus number 3
[ 0.836295] dwc_otg fe980000.usb: irq 36, io mem 0x00000000
[ 0.836347] Init: Port Power? op_state=1
[ 0.836357] Init: Power Port (0)
[ 0.836598] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.836612] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.836623] usb usb3: Product: DWC OTG Controller
[ 0.836634] usb usb3: Manufacturer: Linux 4.19.58-v7l+ dwc_otg_hcd
[ 0.836645] usb usb3: SerialNumber: fe980000.usb
[ 0.837137] hub 3-0:1.0: USB hub found
[ 0.837185] hub 3-0:1.0: 1 port detected
[ 0.837752] dwc_otg: FIQ enabled
[ 0.837761] dwc_otg: NAK holdoff enabled
[ 0.837770] dwc_otg: FIQ split-transaction FSM enabled
[ 0.837783] Module dwc_common_port init
[ 0.837987] usbcore: registered new interface driver uas
[ 0.838095] usbcore: registered new interface driver usb-storage
[ 0.838254] mousedev: PS/2 mouse device common for all mice
[ 0.839408] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.839598] bcm2835-cpufreq: min=600000 max=1500000
[ 0.840165] sdhci: Secure Digital Host Controller Interface driver
[ 0.840173] sdhci: Copyright(c) Pierre Ossman
[ 0.840563] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 0.840934] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.843961] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.844100] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.844220] usbcore: registered new interface driver usbhid
[ 0.844229] usbhid: USB HID core driver
[ 0.844970] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 0.846581] [vc_sm_connected_init]: start
[ 0.854959] [vc_sm_connected_init]: end - returning 0
[ 0.856006] Initializing XFRM netlink socket
[ 0.856033] NET: Registered protocol family 17
[ 0.856111] Key type dns_resolver registered
[ 0.856501] Registering SWP/SWPB emulation handler
[ 0.857061] registered taskstats version 1
[ 0.857076] Loading compiled-in X.509 certificates
[ 0.864853] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 0.864917] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 33, base_baud = 0) is a PL011 rev2
[ 0.867828] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.868337] brcmstb_thermal fd5d2200.thermal: registered AVS TMON of-sensor driver
[ 0.868946] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 0.868959] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 0.894814] sdhci-iproc fe340000.emmc2: Linked as a consumer to regulator.1
[ 0.913065] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 0.914673] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.916352] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.919238] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 0.920846] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 0.928870] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 0.931352] of_cfs_init
[ 0.931431] of_cfs_init: OK
[ 0.932060] Waiting for root device PARTUUID=d9ed116f-02...
[ 0.977228] random: fast init done
[ 0.981676] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 0.995270] mmc1: new high speed SDIO card at address 0001
[ 1.030177] mmc0: new ultra high speed DDR50 SDHC card at address 1234
[ 1.031306] mmcblk0: mmc0:1234 SA16G 14.5 GiB
[ 1.032465] mmcblk0: p1 p2
[ 1.060997] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.061037] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.061714] devtmpfs: mounted
[ 1.068304] Freeing unused kernel memory: 2048K
[ 1.131964] Run /sbin/init as init process
[ 1.163585] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.163600] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.163612] usb 1-1: Product: USB2.0 Hub
[ 1.165234] hub 1-1:1.0: USB hub found
[ 1.165491] hub 1-1:1.0: 4 ports detected
[ 1.491700] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.573858] systemd[1]: System time before build time, advancing clock.
[ 1.627414] usb 1-1.3: New USB device found, idVendor=24ae, idProduct=2000, bcdDevice=10.01
[ 1.627430] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.627443] usb 1-1.3: Product: RAPOO 2.4G Wireless Device
[ 1.627455] usb 1-1.3: Manufacturer: RAPOO
[ 1.637525] input: RAPOO RAPOO 2.4G Wireless Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:24AE:2000.0001/input/input0
[ 1.666051] NET: Registered protocol family 10
[ 1.667262] Segment Routing with IPv6
[ 1.701381] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.702134] systemd[1]: Detected architecture arm.
[ 1.704364] hid-generic 0003:24AE:2000.0001: input,hidraw0: USB HID v1.01 Keyboard [RAPOO RAPOO 2.4G Wireless Device] on usb-0000:01:00.0-1.3/input0
[ 1.713695] input: RAPOO RAPOO 2.4G Wireless Device Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:2000.0002/input/input1
[ 1.714080] input: RAPOO RAPOO 2.4G Wireless Device System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:2000.0002/input/input2
[ 1.715706] systemd[1]: Set hostname to <raspberrypi>.
[ 1.724293] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[ 1.782065] input: RAPOO RAPOO 2.4G Wireless Device Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:24AE:2000.0002/input/input3
[ 1.782642] hid-generic 0003:24AE:2000.0002: input,hiddev96,hidraw1: USB HID v1.01 Mouse [RAPOO RAPOO 2.4G Wireless Device] on usb-0000:01:00.0-1.3/input1
[ 1.985422] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 1.985442] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 2.346189] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.354792] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.360620] systemd[1]: Listening on Syslog Socket.
[ 2.382045] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 2.382195] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.382774] systemd[1]: Listening on udev Control Socket.
[ 2.388035] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.537981] i2c /dev entries driver
[ 3.723578] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.820980] systemd-journald[108]: Received request to flush runtime journal from PID 1
[ 4.329172] argon-mem feb00000.hevc-decoder: argon-hevcmem initialised: Registers at 0xfeb00000 length 0x0000ffff
[ 4.329538] argon-mem feb10000.argon-local-intc: argon-intcmem initialised: Registers at 0xfeb10000 length 0x00000fff
[ 4.329880] argon-mem feb20000.h264-decoder: argon-h264mem initialised: Registers at 0xfeb20000 length 0x0000ffff
[ 4.330205] argon-mem feb30000.vp9-decoder: argon-vp9mem initialised: Registers at 0xfeb30000 length 0x0000ffff
[ 4.345485] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.347493] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.347508] [vc_sm_connected_init]: start
[ 4.349126] [vc_sm_connected_init]: installed successfully
[ 4.368240] media: Linux media interface: v0.10
[ 4.401575] videodev: Linux video capture interface: v2.00
[ 4.457012] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.459350] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.483049] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.499700] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.516336] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.534097] bcm2835_audio soc:audio: card created with 8 channels
[ 4.597118] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.597132] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.610659] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.610672] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.623093] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.623107] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.840327] vc4-drm soc:gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.840345] checking generic (3e97a000 280000) vs hw (0 ffffffffffffffff)
[ 4.840356] fb: switching to vc4drmfb from simple
[ 4.840574] Console: switching to colour dummy device 80x30
[ 4.841441] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.843227] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 1
[ 4.843240] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 4.843249] [drm] No driver support for vblank timestamp query.
[ 4.843258] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 4.985305] Console: switching to colour frame buffer device 160x64
[ 4.989089] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.014514] vc4-drm soc:gpu: fb0: DRM emulated frame buffer device
[ 5.113390] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.178102] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.189794] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.190499] usbcore: registered new interface driver brcmfmac
[ 5.411615] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.426192] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
[ 7.136838] uart-pl011 fe201000.serial: no DMA platform data
[ 7.253138] random: crng init done
[ 7.253152] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.317113] 8021q: 802.1Q VLAN Support v1.8
[ 7.598036] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.751973] bcmgenet fd580000.genet: configuring instance for external RGMII (no delay)
[ 8.752263] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.831739] bcmgenet fd580000.genet eth0: Link is Down
[ 13.723185] Bluetooth: Core ver 2.22
[ 13.723223] NET: Registered protocol family 31
[ 13.723228] Bluetooth: HCI device and connection manager initialized
[ 13.723243] Bluetooth: HCI socket layer initialized
[ 13.723250] Bluetooth: L2CAP socket layer initialized
[ 13.723269] Bluetooth: SCO socket layer initialized
[ 13.731861] Bluetooth: HCI UART driver ver 2.3
[ 13.731868] Bluetooth: HCI UART protocol H4 registered
[ 13.731923] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.732036] Bluetooth: HCI UART protocol Broadcom registered
[ 13.912404] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.912411] Bluetooth: BNEP filters: protocol multicast
[ 13.912423] Bluetooth: BNEP socket layer initialized
[ 13.951819] Bluetooth: RFCOMM TTY layer initialized
[ 13.951834] Bluetooth: RFCOMM socket layer initialized
[ 13.951848] Bluetooth: RFCOMM ver 1.11
[ 20.029252] fuse init (API version 7.27)
dmesg: read kernel buffer failed: Operationen inte tillåten
pi@raspberrypi:~ $
In this case i was plaing some minecraft when the mouse froze so i had to connect a logitec mouse
Here is the dmesg after the crash.
(Continue from [ 20.029252] )
[ 282.311945] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
[ 282.311988] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 5711.342594] ------------[ cut here ]------------
[ 5711.342723] WARNING: CPU: 0 PID: 493 at drivers/gpu/drm/vc4/vc4_firmware_kms.c:899 vc4_crtc_atomic_flush+0x98/0x9c [vc4]
[ 5711.342737] Modules linked in: snd_hrtimer snd_seq_dummy snd_seq snd_seq_device fuse rfcomm bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc joydev evdev brcmfmac brcmutil sha256_generic cfg80211 vc4 v3d gpu_sched drm_kms_helper drm rfkill snd_soc_core drm_panel_orientation_quirks snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops snd_bcm2835(C) bcm2835_codec(C) snd_pcm raspberrypi_hwmon bcm2835_v4l2(C) hwmon v4l2_mem2mem snd_timer bcm2835_mmal_vchiq(C) snd videobuf2_dma_contig v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) argon_mem uio_pdrv_genirq uio fixed i2c_dev ip_tables x_tables ipv6
[ 5711.343386] CPU: 0 PID: 493 Comm: Xorg Tainted: G C 4.19.58-v7l+ #1245
[ 5711.343396] Hardware name: BCM2835
[ 5711.343441] [<c0212c8c>] (unwind_backtrace) from [<c020d49c>] (show_stack+0x20/0x24)
[ 5711.343469] [<c020d49c>] (show_stack) from [<c09763e0>] (dump_stack+0xd4/0x118)
[ 5711.343497] [<c09763e0>] (dump_stack) from [<c0222270>] (__warn+0x104/0x11c)
[ 5711.343513] [<c0222270>] (__warn) from [<c02223c0>] (warn_slowpath_null+0x50/0x58)
[ 5711.343573] [<c02223c0>] (warn_slowpath_null) from [<bf561a08>] (vc4_crtc_atomic_flush+0x98/0x9c [vc4])
[ 5711.343782] [<bf561a08>] (vc4_crtc_atomic_flush [vc4]) from [<bf4fa81c>] (drm_atomic_helper_commit_planes+0x1a4/0x298 [drm_kms_helper])
[ 5711.343913] [<bf4fa81c>] (drm_atomic_helper_commit_planes [drm_kms_helper]) from [<bf563144>] (vc4_atomic_complete_commit+0x60/0x33c [vc4])
[ 5711.344005] [<bf563144>] (vc4_atomic_complete_commit [vc4]) from [<bf563500>] (vc4_atomic_commit+0xe0/0x194 [vc4])
[ 5711.344262] [<bf563500>] (vc4_atomic_commit [vc4]) from [<bf3e3410>] (drm_atomic_commit+0x5c/0x60 [drm])
[ 5711.344606] [<bf3e3410>] (drm_atomic_commit [drm]) from [<bf3e5508>] (drm_mode_atomic_ioctl+0x98c/0xb78 [drm])
[ 5711.344933] [<bf3e5508>] (drm_mode_atomic_ioctl [drm]) from [<bf3d0bc4>] (drm_ioctl_kernel+0xb4/0xf0 [drm])
[ 5711.345256] [<bf3d0bc4>] (drm_ioctl_kernel [drm]) from [<bf3d0ff8>] (drm_ioctl+0x230/0x3cc [drm])
[ 5711.345429] [<bf3d0ff8>] (drm_ioctl [drm]) from [<c03c3f64>] (do_vfs_ioctl+0xbc/0x804)
[ 5711.345451] [<c03c3f64>] (do_vfs_ioctl) from [<c03c46f0>] (ksys_ioctl+0x44/0x6c)
[ 5711.345470] [<c03c46f0>] (ksys_ioctl) from [<c03c4730>] (sys_ioctl+0x18/0x1c)
[ 5711.345489] [<c03c4730>] (sys_ioctl) from [<c0201000>] (ret_fast_syscall+0x0/0x28)
[ 5711.345499] Exception stack(0xda9cbfa8 to 0xda9cbff0)
[ 5711.345511] bfa0: 00e7c6b0 be857a78 0000000c c03864bc be857a78 00000000
[ 5711.345524] bfc0: 00e7c6b0 be857a78 c03864bc 00000036 016fc010 017e66e0 017343b8 00000033
[ 5711.345537] bfe0: b6cf008c be857a44 b6cd7594 b696351c
[ 5711.345676] ---[ end trace 48a6cde497637d2e ]---
[ 7164.864970] ------------[ cut here ]------------
[ 7164.865162] WARNING: CPU: 0 PID: 0 at drivers/gpu/drm/drm_vblank.c:1026 drm_vblank_put+0xf0/0x100 [drm]
[ 7164.865170] Modules linked in: snd_hrtimer snd_seq_dummy snd_seq snd_seq_device fuse rfcomm bnep hci_uart btbcm serdev bluetooth ecdh_generic 8021q garp stp llc joydev evdev brcmfmac brcmutil sha256_generic cfg80211 vc4 v3d gpu_sched drm_kms_helper drm rfkill snd_soc_core drm_panel_orientation_quirks snd_compress snd_pcm_dmaengine syscopyarea sysfillrect sysimgblt fb_sys_fops snd_bcm2835(C) bcm2835_codec(C) snd_pcm raspberrypi_hwmon bcm2835_v4l2(C) hwmon v4l2_mem2mem snd_timer bcm2835_mmal_vchiq(C) snd videobuf2_dma_contig v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev media vc_sm_cma(C) argon_mem uio_pdrv_genirq uio fixed i2c_dev ip_tables x_tables ipv6
[ 7164.865633] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G WC 4.19.58-v7l+ #1245
[ 7164.865641] Hardware name: BCM2835
[ 7164.865671] [<c0212c8c>] (unwind_backtrace) from [<c020d49c>] (show_stack+0x20/0x24)
[ 7164.865690] [<c020d49c>] (show_stack) from [<c09763e0>] (dump_stack+0xd4/0x118)
[ 7164.865710] [<c09763e0>] (dump_stack) from [<c0222270>] (__warn+0x104/0x11c)
[ 7164.865726] [<c0222270>] (__warn) from [<c02223c0>] (warn_slowpath_null+0x50/0x58)
[ 7164.865899] [<c02223c0>] (warn_slowpath_null) from [<bf3f120c>] (drm_vblank_put+0xf0/0x100 [drm])
[ 7164.866221] [<bf3f120c>] (drm_vblank_put [drm]) from [<bf3f1240>] (drm_crtc_vblank_put+0x24/0x28 [drm])
[ 7164.866436] [<bf3f1240>] (drm_crtc_vblank_put [drm]) from [<bf561654>] (vc4_crtc_handle_page_flip+0x50/0x60 [vc4])
[ 7164.866536] [<bf561654>] (vc4_crtc_handle_page_flip [vc4]) from [<bf562f48>] (vc4_crtc_irq_handler+0xc8/0x144 [vc4])
[ 7164.866593] [<bf562f48>] (vc4_crtc_irq_handler [vc4]) from [<c02815a8>] (__handle_irq_event_percpu+0xc0/0x22c)
[ 7164.866609] [<c02815a8>] (__handle_irq_event_percpu) from [<c0281750>] (handle_irq_event_percpu+0x3c/0x8c)
[ 7164.866623] [<c0281750>] (handle_irq_event_percpu) from [<c02817f4>] (handle_irq_event+0x54/0x78)
[ 7164.866638] [<c02817f4>] (handle_irq_event) from [<c028564c>] (handle_fasteoi_irq+0xb4/0x194)
[ 7164.866655] [<c028564c>] (handle_fasteoi_irq) from [<c0280618>] (generic_handle_irq+0x34/0x44)
[ 7164.866673] [<c0280618>] (generic_handle_irq) from [<c0280d54>] (__handle_domain_irq+0x6c/0xc4)
[ 7164.866690] [<c0280d54>] (__handle_domain_irq) from [<c0202244>] (gic_handle_irq+0x4c/0x88)
[ 7164.866704] [<c0202244>] (gic_handle_irq) from [<c02019bc>] (__irq_svc+0x5c/0x7c)
[ 7164.866713] Exception stack(0xc1001ed8 to 0xc1001f20)
[ 7164.866723] 1ec0: c0209a84 00000000
[ 7164.866735] 1ee0: 40000093 40000093 c1004dbc c1000000 c1004e04 00000001 c10957ca c10a4a00
[ 7164.866747] 1f00: c0e67a38 c1001f34 c10051c4 c1001f28 00000000 c0209a88 40000013 ffffffff
[ 7164.866763] [<c02019bc>] (__irq_svc) from [<c0209a88>] (arch_cpu_idle+0x34/0x4c)
[ 7164.866783] [<c0209a88>] (arch_cpu_idle) from [<c09935a4>] (default_idle_call+0x34/0x48)
[ 7164.866801] [<c09935a4>] (default_idle_call) from [<c025423c>] (do_idle+0xec/0x17c)
[ 7164.866819] [<c025423c>] (do_idle) from [<c025458c>] (cpu_startup_entry+0x28/0x2c)
[ 7164.866836] [<c025458c>] (cpu_startup_entry) from [<c098cc80>] (rest_init+0xbc/0xc0)
[ 7164.866853] [<c098cc80>] (rest_init) from [<c0e00fe4>] (start_kernel+0x4b8/0x4e8)
[ 7164.866863] ---[ end trace 48a6cde497637d2f ]---
[10358.996389] usb 1-1.1: new low-speed USB device number 4 using xhci_hcd
[10359.134220] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c018, bcdDevice=43.01
[10359.134229] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10359.134235] usb 1-1.1: Product: USB Optical Mouse
[10359.134240] usb 1-1.1: Manufacturer: Logitech
[10359.142449] input: Logitech USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C018.0003/input/input6
[10359.142683] hid-generic 0003:046D:C018.0003: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:01:00.0-1.1/input0
pi@raspberrypi:~ $
Just to be clear,. The keyboard works without any problems, its just the mouse that freeze
Andyroo
Re: Unstable driver (?) for wireless keyboard and mouse..
Sat Jul 27, 2019 8:24 pm
Try putting the receiver in a USB extension cable - even 5-10cm away from the USB ports have solved some issues before today.
DAI-X
Sun Jul 28, 2019 10:15 am
Yes I have several wireless Rapoo mouse and keyboards, I have had same problem with mouse freezing. As Andyroo said, put the USB adapter on an extension cable and place it closer to your mouse. This has fixed it for me.
It seems to be due to interference from the USB 3.0 ports - which explains why its only seen on the Pi 4.
webbsmurfen
Wed Jul 31, 2019 12:22 pm
Oh thanks guys... I will try this out when Im free from work. (Sorry for the late respond..)
webbsmurfen
Wed Jul 31, 2019 6:50 pm
Well i tried, it didnt work... but i used a 0.5 meters cable (to short maybe)
Andyroo
Wed Jul 31, 2019 7:01 pm
Oh dear. That would have been plenty - normally 10cm or so is fine...
No other ideas I’m afraid.
webbsmurfen
Wed Jul 31, 2019 7:53 pm
Well... I need to test this further. Maybe i was to fast to jump for conclusion . I tested this in a similar OS first, with bad results, I did not test this in Buster.. which is waaay more stable.. I will give it a couple of days and get back to you
RPIgoodSBC
Fri Aug 02, 2019 9:27 pm
I can confirm this issue.
I have a wireless keyboard 2.4Ghz Microsoft with touchpad and radomly the touchpad freezes.Only the touchpad, if I replug the wireless dongle the touchpad works again.In 1 month this happens to me 5 times, no pattern.
I believe is something related to kernel driver.The keyboard works but the touchpad don't.
On first time I believe it is usb-3 interference and put away the wireless dongle but now I can confirm that the wireless dongle keyboard is away usb-3 interference and the freezes happens again.The voltage in the extensor 1m is ok 5,05V, then is not poor power to dongle.
I have installed this software... and wait this bug? happens again.
sudo apt-get install xserver-xorg-input-libinput xserver-xorg-input-evdev xserver-xorg-input-mouse hwinfo
hwinfo --mouse
pi@raspberrypi:~ $ hwinfo --mouse
11: USB 00.1: 10503 USB Mouse
[Created at usb.122]
Unique ID: WE6o.GBTASLx8SV9
Parent ID: ADDn.mUqILwxEtWB
SysFS ID: /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1
SysFS BusID: 1-1.4:1.1
Hardware Class: mouse
Model: "Microsoft® Nano Transceiver v2.0"
Hotplug: USB
Vendor: usb 0x045e "Microsoft Corp."
Device: usb 0x0800 "Microsoft® Nano Transceiver v2.0"
Revision: "9.44"
Compatible to: int 0x0210 0x0025
Driver: "usbhid"
Driver Modules: "usbhid"
Device File: /dev/input/mice (/dev/input/mouse0)
Device Files: /dev/input/mice, /dev/input/mouse0, /dev/input/event1, /dev/input/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.1-event-mouse, /dev/input/by-id/usb-Microsoft_Microsoft®_Nano_Transceiver_v2.0-if01-event-mouse, /dev/input/by-id/usb-Microsoft_Microsoft®_Nano_Transceiver_v2.0-if01-mouse, /dev/input/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.1-mouse
Device Number: char 13:63 (char 13:32)
Speed: 12 Mbps
Module Alias: "usb:v045Ep0800d0944dc00dsc00dp00ic03isc01ip02in01"
Driver Info #0:
Buttons: 5
Wheels: 2
XFree86 Protocol: explorerps/2
GPM Protocol: exps2
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #20 (Hub)
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.58-v7l+ #1245 SMP Fri Jul 12 17:31:45 BST 2019 armv7l GNU/Linux
Keyboard works very good and touchpad too, but sometimes touchpad freezes mouse pointer.
This keyboard was used on rpi3B+ without issues.
Note:
Something related is that if I adjust mouse acceleration on preferences mouse raspbian only valid values are 0,5,10, any other values revert to default 5.It is not posible 8 value for example because is reverted to 5.
webbsmurfen
Sat Aug 03, 2019 8:50 pm
Yeah. To replug the dongle works for a while, maybe 30 minutes or so
RPIgoodSBC
Wed Aug 14, 2019 2:50 pm
Today happens again.Pointer mouse freeze but keyboard works.After remove and replug dongle wireless for touchpad-keyboard-microsoft the mouse pointer works again.
The wireless keyboard with touchpad is this...
https://www.microsoft.com/accessories/e ... /n9z-00001
After the crash the Xorg.0.log is this...
[     9.086]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[     9.086] Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
[     9.086] Current Operating System: Linux 4B 4.19.58-v7l+ #1245 SMP Fri Jul 12 17:31:45 BST 2019 armv7l
[     9.086] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1920x1080@60 smsc95xx.macaddr=DC:A6:32:04:9D:B1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=581f35ea-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[     9.087] Build Date: 05 June 2019  12:49:54PM
[     9.087] xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
[     9.087] Current version of pixman: 0.36.0
[     9.087] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     9.087] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     9.088] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 14 01:00:38 2019
[     9.091] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     9.091] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     9.094] (==) No Layout section.  Using the first Screen section.
[     9.094] (==) No screen section available. Using defaults.
[     9.094] (**) |-->Screen "Default Screen Section" (0)
[     9.095] (**) |   |-->Monitor "<default monitor>"
[     9.098] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[     9.098] (==) Automatically adding devices
[     9.098] (==) Automatically enabling devices
[     9.098] (==) Automatically adding GPU devices
[     9.098] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     9.098] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[     9.098] 	Entry deleted from font path.
[     9.098] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[     9.098] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[     9.098] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[     9.099] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[     9.099] 	Entry deleted from font path.
[     9.099] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[     9.099] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[     9.099] (==) FontPath set to:
	built-ins
[     9.099] (==) ModulePath set to "/usr/lib/xorg/modules"
[     9.099] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[     9.099] (II) Loader magic: 0x1fcf80
[     9.099] (II) Module ABI versions:
[     9.099] 	X.Org ANSI C Emulation: 0.4
[     9.099] 	X.Org Video Driver: 24.0
[     9.099] 	X.Org XInput driver : 24.1
[     9.099] 	X.Org Server Extension : 10.0
[     9.102] (++) using VT number 7
[     9.102] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     9.106] (II) xfree86: Adding drm device (/dev/dri/card1)
[     9.120] (II) xfree86: Adding drm device (/dev/dri/card0)
[     9.122] (II) no primary bus or device found
[     9.123] 	falling back to /sys/devices/platform/soc/soc:gpu/drm/card1
[     9.123] (II) LoadModule: "glx"
[     9.125] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     9.167] (II) Module glx: vendor="X.Org Foundation"
[     9.167] 	compiled for 1.20.4, module version = 1.0.0
[     9.167] 	ABI class: X.Org Server Extension, version 10.0
[     9.167] (==) Matched modesetting as autoconfigured driver 0
[     9.167] (==) Matched fbdev as autoconfigured driver 1
[     9.168] (==) Assigned the driver to the xf86ConfigLayout
[     9.168] (II) LoadModule: "modesetting"
[     9.170] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     9.173] (II) Module modesetting: vendor="X.Org Foundation"
[     9.173] 	compiled for 1.20.4, module version = 1.20.4
[     9.173] 	Module class: X.Org Video Driver
[     9.173] 	ABI class: X.Org Video Driver, version 24.0
[     9.173] (II) LoadModule: "fbdev"
[     9.174] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[     9.176] (II) Module fbdev: vendor="X.Org Foundation"
[     9.176] 	compiled for 1.20.3, module version = 0.5.0
[     9.176] 	Module class: X.Org Video Driver
[     9.176] 	ABI class: X.Org Video Driver, version 24.0
[     9.176] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     9.176] (II) FBDEV: driver for framebuffer: fbdev
[     9.219] (II) modeset(0): using drv /dev/dri/card1
[     9.219] (WW) Falling back to old probe method for fbdev
[     9.219] (II) Loading sub module "fbdevhw"
[     9.219] (II) LoadModule: "fbdevhw"
[     9.219] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[     9.221] (II) Module fbdevhw: vendor="X.Org Foundation"
[     9.221] 	compiled for 1.20.4, module version = 0.0.2
[     9.221] 	ABI class: X.Org Video Driver, version 24.0
[     9.222] (II) modeset(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     9.223] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[     9.223] (==) modeset(0): RGB weight 888
[     9.223] (==) modeset(0): Default visual is TrueColor
[     9.223] (II) Loading sub module "glamoregl"
[     9.223] (II) LoadModule: "glamoregl"
[     9.224] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     9.260] (II) Module glamoregl: vendor="X.Org Foundation"
[     9.260] 	compiled for 1.20.4, module version = 1.0.1
[     9.260] 	ABI class: X.Org ANSI C Emulation, version 0.4
removed
[    10.121] (II) modeset(0): Output HDMI-1 connected
[    10.121] (II) modeset(0): Using exact sizes for initial modes
[    10.121] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[    10.121] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    10.121] (==) modeset(0): DPI set to (96, 96)
[    10.121] (II) Loading sub module "fb"
[    10.121] (II) LoadModule: "fb"
[    10.122] (II) Loading /usr/lib/xorg/modules/libfb.so
[    10.124] (II) Module fb: vendor="X.Org Foundation"
[    10.124] 	compiled for 1.20.4, module version = 1.0.0
[    10.124] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    10.124] (II) UnloadModule: "fbdev"
[    10.124] (II) Unloading fbdev
[    10.124] (II) UnloadSubModule: "fbdevhw"
[    10.124] (II) Unloading fbdevhw
[    10.248] (==) modeset(0): Backing store enabled
[    10.248] (==) modeset(0): Silken mouse enabled
[    10.252] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    10.252] (==) modeset(0): DPMS enabled
[    10.253] (II) modeset(0): [DRI2] Setup complete
[    10.253] (II) modeset(0): [DRI2]   DRI driver: vc4
[    10.253] (II) modeset(0): [DRI2]   VDPAU driver: vc4
[    10.253] (II) Initializing extension Generic Event Extension
[    10.254] (II) Initializing extension SHAPE
[    10.254] (II) Initializing extension MIT-SHM
[    10.255] (II) Initializing extension XInputExtension
[    10.256] (II) Initializing extension XTEST
[    10.257] (II) Initializing extension BIG-REQUESTS
[    10.257] (II) Initializing extension SYNC
[    10.258] (II) Initializing extension XKEYBOARD
[    10.258] (II) Initializing extension XC-MISC
[    10.259] (II) Initializing extension SECURITY
[    10.259] (II) Initializing extension XFIXES
[    10.260] (II) Initializing extension RENDER
[    10.260] (II) Initializing extension RANDR
[    10.261] (II) Initializing extension COMPOSITE
[    10.262] (II) Initializing extension DAMAGE
[    10.262] (II) Initializing extension MIT-SCREEN-SAVER
[    10.262] (II) Initializing extension DOUBLE-BUFFER
[    10.263] (II) Initializing extension RECORD
[    10.263] (II) Initializing extension DPMS
[    10.264] (II) Initializing extension Present
[    10.264] (II) Initializing extension DRI3
[    10.265] (II) Initializing extension X-Resource
[    10.265] (II) Initializing extension XVideo
[    10.266] (II) Initializing extension XVideo-MotionCompensation
[    10.266] (II) Initializing extension SELinux
[    10.266] (II) SELinux: Disabled on system
[    10.266] (II) Initializing extension GLX
[    10.527] (II) AIGLX: Loaded and initialized vc4
[    10.528] (II) GLX: Initialized DRI2 GL provider for screen 0
[    10.528] (II) Initializing extension XFree86-VidModeExtension
[    10.529] (II) Initializing extension XFree86-DGA
[    10.531] (II) Initializing extension XFree86-DRI
[    10.532] (II) Initializing extension DRI2
[    10.542] (II) modeset(0): Damage tracking initialized
[    10.542] (II) modeset(0): Setting screen physical size to 508 x 285
[    10.693] (II) config/udev: Adding input device Avermedia A835B(3835) (/dev/input/event5)
[    10.693] (**) Avermedia A835B(3835): Applying InputClass "evdev keyboard catchall"
[    10.693] (**) Avermedia A835B(3835): Applying InputClass "libinput keyboard catchall"
[    10.693] (II) LoadModule: "libinput"
[    10.694] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    10.709] (II) Module libinput: vendor="X.Org Foundation"
[    10.709] 	compiled for 1.20.3, module version = 0.28.2
[    10.709] 	Module class: X.Org XInput Driver
[    10.709] 	ABI class: X.Org XInput driver, version 24.1
[    10.709] (II) Using input driver 'libinput' for 'Avermedia A835B(3835)'
[    10.709] (**) Avermedia A835B(3835): always reports core events
[    10.709] (**) Option "Device" "/dev/input/event5"
[    10.710] (**) Option "_source" "server/udev"
[    10.728] (II) event5  - Avermedia A835B(3835): is tagged by udev as: Keyboard
[    10.728] (II) event5  - Avermedia A835B(3835): device is a keyboard
[    10.728] (II) event5  - Avermedia A835B(3835): device removed
[    10.800] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2.2/rc/rc0/input6/event5"
[    10.800] (II) XINPUT: Adding extended input device "Avermedia A835B(3835)" (type: KEYBOARD, id 6)
[    10.800] (**) Option "xkb_model" "pc105"
[    10.800] (**) Option "xkb_layout" "es"
[    10.847] (II) event5  - Avermedia A835B(3835): is tagged by udev as: Keyboard
[    10.847] (II) event5  - Avermedia A835B(3835): device is a keyboard
[    10.851] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 (/dev/input/event0)
[    10.851] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "evdev keyboard catchall"
[    10.851] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "libinput keyboard catchall"
[    10.851] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0'
[    10.851] (**) Microsoft Microsoft® Nano Transceiver v2.0: always reports core events
[    10.851] (**) Option "Device" "/dev/input/event0"
[    10.851] (**) Option "_source" "server/udev"
[    10.857] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[    10.857] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[    10.857] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device removed
[    10.920] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0800.0001/input/input0/event0"
[    10.920] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0" (type: KEYBOARD, id 7)
[    10.920] (**) Option "xkb_model" "pc105"
[    10.920] (**) Option "xkb_layout" "es"
[    10.927] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[    10.927] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[    10.930] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/event1)
[    10.930] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "evdev pointer catchall"
[    10.930] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "libinput pointer catchall"
[    10.931] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Mouse'
[    10.931] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: always reports core events
[    10.931] (**) Option "Device" "/dev/input/event1"
[    10.931] (**) Option "_source" "server/udev"
[    10.936] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[    10.937] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[    10.937] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device removed
[    11.010] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:0800.0002/input/input1/event1"
[    11.010] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Mouse" (type: MOUSE, id 8)
[    11.010] (**) Option "AccelerationScheme" "none"
[    11.011] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) selected scheme none/0
[    11.011] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration factor: 2.000
[    11.011] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration threshold: 4
[    11.016] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[    11.017] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[    11.020] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/mouse0)
[    11.020] (II) No input driver specified, ignoring this device.
[    11.020] (II) This device may have been added with another device file.
[    11.023] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event2)
[    11.023] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.023] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.023] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[    11.023] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[    11.023] (**) Option "Device" "/dev/input/event2"
[    11.023] (**) Option "_source" "server/udev"
[    11.029] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[    11.029] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[    11.030] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[    11.130] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[    11.130] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:0800.0002/input/input2/event2"
[    11.130] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 9)
[    11.130] (**) Option "AccelerationScheme" "none"
[    11.130] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[    11.130] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[    11.130] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[    11.136] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[    11.136] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[    11.140] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event3)
[    11.140] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.140] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.140] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[    11.140] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[    11.140] (**) Option "Device" "/dev/input/event3"
[    11.140] (**) Option "_source" "server/udev"
[    11.146] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[    11.146] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[    11.147] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[    11.190] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[    11.190] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:045E:0800.0003/input/input3/event3"
[    11.190] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 10)
[    11.190] (**) Option "AccelerationScheme" "none"
[    11.190] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[    11.190] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[    11.190] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[    11.196] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[    11.196] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[    11.200] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 System Control (/dev/input/event4)
[    11.200] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "evdev keyboard catchall"
[    11.200] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "libinput keyboard catchall"
[    11.200] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 System Control'
[    11.200] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: always reports core events
[    11.200] (**) Option "Device" "/dev/input/event4"
[    11.200] (**) Option "_source" "server/udev"
[    11.206] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[    11.206] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[    11.207] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device removed
[    11.250] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:045E:0800.0003/input/input5/event4"
[    11.250] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 System Control" (type: KEYBOARD, id 11)
[    11.250] (**) Option "xkb_model" "pc105"
[    11.250] (**) Option "xkb_layout" "es"
[    11.256] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[    11.256] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[    11.269] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.269] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.269] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[    11.270] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[    11.270] (**) Option "Device" "/dev/input/event2"
[    11.270] (**) Option "_source" "_driver/libinput"
[    11.270] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[    11.270] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:0800.0002/input/input2/event2"
[    11.270] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 12)
[    11.270] (**) Option "xkb_model" "pc105"
[    11.270] (**) Option "xkb_layout" "es"
[    11.270] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[    11.270] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[    11.270] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[    11.271] (**) Option "Device" "/dev/input/event3"
[    11.271] (**) Option "_source" "_driver/libinput"
[    11.271] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[    11.271] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:045E:0800.0003/input/input3/event3"
[    11.271] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 13)
[    11.271] (**) Option "xkb_model" "pc105"
[    11.271] (**) Option "xkb_layout" "es"
[    12.601] (II) modeset(0): EDID vendor "VSC", prod id 27439
[    12.602] (II) modeset(0): Using EDID range info for horizontal sync
[    12.602] (II) modeset(0): Using EDID range info for vertical refresh
[    12.602] (II) modeset(0): Printing DDC gathered Modelines:
removed...
[ 22513.084] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0
[ 22513.087] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device removed
[ 22513.156] (II) UnloadModule: "libinput"
[ 22513.222] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0 Mouse
[ 22513.222] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device removed
[ 22513.284] (II) UnloadModule: "libinput"
[ 22513.284] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control
[ 22513.287] (II) UnloadModule: "libinput"
[ 22513.287] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control
[ 22513.287] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 22513.331] (II) UnloadModule: "libinput"
[ 22513.444] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control
[ 22513.447] (II) UnloadModule: "libinput"
[ 22513.447] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control
[ 22513.447] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 22513.485] (II) UnloadModule: "libinput"
[ 22513.524] (II) config/udev: removing device Microsoft Microsoft® Nano Transceiver v2.0 System Control
[ 22513.524] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device removed
[ 22513.580] (II) UnloadModule: "libinput"
[ 22516.653] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 (/dev/input/event0)
[ 22516.653] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "evdev keyboard catchall"
[ 22516.653] (**) Microsoft Microsoft® Nano Transceiver v2.0: Applying InputClass "libinput keyboard catchall"
[ 22516.653] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0'
[ 22516.653] (**) Microsoft Microsoft® Nano Transceiver v2.0: always reports core events
[ 22516.653] (**) Option "Device" "/dev/input/event0"
[ 22516.653] (**) Option "_source" "server/udev"
[ 22516.660] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[ 22516.660] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[ 22516.661] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device removed
[ 22516.710] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0800.0004/input/input7/event0"
[ 22516.710] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0" (type: KEYBOARD, id 7)
[ 22516.710] (**) Option "xkb_model" "pc105"
[ 22516.710] (**) Option "xkb_layout" "es"
[ 22516.717] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: is tagged by udev as: Keyboard
[ 22516.717] (II) event0  - Microsoft Microsoft® Nano Transceiver v2.0: device is a keyboard
[ 22516.722] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/mouse0)
[ 22516.722] (II) No input driver specified, ignoring this device.
[ 22516.722] (II) This device may have been added with another device file.
[ 22516.784] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event2)
[ 22516.784] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 22516.784] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 22516.784] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 22516.784] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 22516.784] (**) Option "Device" "/dev/input/event2"
[ 22516.784] (**) Option "_source" "server/udev"
[ 22516.855] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 22516.855] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 22516.855] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 22516.940] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[ 22516.940] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:0800.0005/input/input9/event2"
[ 22516.940] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 8)
[ 22516.942] (**) Option "AccelerationScheme" "none"
[ 22516.943] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[ 22516.943] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[ 22516.943] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[ 22517.015] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 22517.015] (II) event2  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 22517.016] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 22517.016] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 22517.016] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 22517.016] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 22517.016] (**) Option "Device" "/dev/input/event2"
[ 22517.016] (**) Option "_source" "_driver/libinput"
[ 22517.017] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[ 22517.017] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:0800.0005/input/input9/event2"
[ 22517.017] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 9)
[ 22517.017] (**) Option "xkb_model" "pc105"
[ 22517.017] (**) Option "xkb_layout" "es"
[ 22517.021] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control (/dev/input/event3)
[ 22517.021] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 22517.021] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 22517.021] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 22517.021] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 22517.021] (**) Option "Device" "/dev/input/event3"
[ 22517.021] (**) Option "_source" "server/udev"
[ 22517.027] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 22517.027] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 22517.028] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device removed
[ 22517.070] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: needs a virtual subdevice
[ 22517.070] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:045E:0800.0006/input/input10/event3"
[ 22517.070] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: MOUSE, id 10)
[ 22517.072] (**) Option "AccelerationScheme" "none"
[ 22517.073] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) selected scheme none/0
[ 22517.073] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration factor: 2.000
[ 22517.073] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: (accel) acceleration threshold: 4
[ 22517.083] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is tagged by udev as: Keyboard
[ 22517.083] (II) event3  - Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: device is a keyboard
[ 22517.085] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 22517.085] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 22517.085] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control'
[ 22517.085] (**) Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: always reports core events
[ 22517.085] (**) Option "Device" "/dev/input/event3"
[ 22517.085] (**) Option "_source" "_driver/libinput"
[ 22517.085] (II) libinput: Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control: is a virtual subdevice
[ 22517.085] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:045E:0800.0006/input/input10/event3"
[ 22517.085] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Consumer Control" (type: KEYBOARD, id 11)
[ 22517.085] (**) Option "xkb_model" "pc105"
[ 22517.086] (**) Option "xkb_layout" "es"
[ 22517.092] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 Mouse (/dev/input/event1)
[ 22517.092] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "evdev pointer catchall"
[ 22517.092] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: Applying InputClass "libinput pointer catchall"
[ 22517.092] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 Mouse'
[ 22517.092] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: always reports core events
[ 22517.092] (**) Option "Device" "/dev/input/event1"
[ 22517.092] (**) Option "_source" "server/udev"
[ 22517.099] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[ 22517.100] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[ 22517.100] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device removed
[ 22517.190] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:045E:0800.0005/input/input8/event1"
[ 22517.190] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 Mouse" (type: MOUSE, id 12)
[ 22517.192] (**) Option "AccelerationScheme" "none"
[ 22517.193] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) selected scheme none/0
[ 22517.193] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration factor: 2.000
[ 22517.193] (**) Microsoft Microsoft® Nano Transceiver v2.0 Mouse: (accel) acceleration threshold: 4
[ 22517.209] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: is tagged by udev as: Mouse
[ 22517.209] (II) event1  - Microsoft Microsoft® Nano Transceiver v2.0 Mouse: device is a pointer
[ 22517.218] (II) config/udev: Adding input device Microsoft Microsoft® Nano Transceiver v2.0 System Control (/dev/input/event4)
[ 22517.218] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "evdev keyboard catchall"
[ 22517.218] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: Applying InputClass "libinput keyboard catchall"
[ 22517.218] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Nano Transceiver v2.0 System Control'
[ 22517.218] (**) Microsoft Microsoft® Nano Transceiver v2.0 System Control: always reports core events
[ 22517.218] (**) Option "Device" "/dev/input/event4"
[ 22517.218] (**) Option "_source" "server/udev"
[ 22517.226] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[ 22517.226] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
[ 22517.226] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device removed
[ 22517.270] (**) Option "config_info" "udev:/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:045E:0800.0006/input/input12/event4"
[ 22517.270] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Nano Transceiver v2.0 System Control" (type: KEYBOARD, id 13)
[ 22517.270] (**) Option "xkb_model" "pc105"
[ 22517.270] (**) Option "xkb_layout" "es"
[ 22517.277] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: is tagged by udev as: Keyboard
[ 22517.277] (II) event4  - Microsoft Microsoft® Nano Transceiver v2.0 System Control: device is a keyboard
Hope this helps to trace the problem.
Note:
I have removed some lines about modelines and modeset monitor.
Andyroo
Wed Aug 14, 2019 3:44 pm
Could you possibly edit your post and put the list in code tags (</> fifth button across) as it shortens the scroll to scroll bars :lol:
look like an error posted today on VNC breaking. Maybe it’s tied together (no idea just guessing).
Would be interesting to remove VNC and see if that fixes your issue...
RPIgoodSBC
Wed Aug 14, 2019 4:04 pm
I am not using real-vnc-server then...
sudo apt-get remove realvnc-vnc-server
Andyroo
Wed Aug 14, 2019 5:41 pm
There is also the viewer realvnc-vnc-viewer package.
Like I said - no idea if it will help!
sconemad
Thu Aug 15, 2019 3:28 pm
I've been investigating the RealVNC issue you mention (https://www.raspberrypi.org/forums/view ... 3#p1518612) and I don't think this is related. These look like fairly normal warnings produced by the X server.
Andy (from RealVNC)
gordon77
Thu Aug 15, 2019 4:49 pm
I''ve noticed a problem with my wireless keyboard and mouse, it's an Acer KG-0917. Never been an issue with any previous Pi or raspbian OS but now stops working occasionally with Pi4 and Buster. Fixed by unplugging and replugging USB wireless dongle.
RPIgoodSBC
Sat Aug 17, 2019 5:22 pm
Today it has turned off again but the keyboard has indicated me a low battery. I no longer remembered that I am using rechargeable NiMh batteries that give a lower voltage to the alkaline ones and that last a little less.The led indicator low batteries probably is designed to alkaline batteries that are the default with the keyboard.
I recommend using high-quality alkaline batteries because I have to think that the problem may be related to the batteries.
Keyboard says ok but perhaps the voltage is low and in some cases touchpad freezes but not keyboard.
The touchpad probably consumes more than the keyboard itself that stops working even if the keyboard works.
The recharged NiMh batteries are 1.4V versus 1.6V for alkaline fresh and 1.8V for lithium AAA.
I have put long-lasting alkaline batteries and we will see what happens.
MidGe48
Tue Sep 17, 2019 6:39 am
I can confirm the same issue.
The problem occurs with different brands of wireless mouses/keyboards (Logitech and Microsoft) and different brands of usb 3 ssd (Sandisk and Toshiba) combinations. No combination has been stable, all have displayed random instances of the mouse ceasing to respond. This has never happened with any raspberry pi models before the current raspberry pi 4.
gkreidl
Tue Sep 17, 2019 7:05 am
https://www.raspberrypi.org/forums/view ... d#p1508902
(and the next one)
Minimal Kiosk Browser (kweb)
RPIgoodSBC
Tue Sep 17, 2019 12:47 pm
In my case the mouse hang on touchpad is very occasional every 7 days approximately with a daily use.
Anyway I have changed the microsoft touchpad wireless keyboard for a smaller one that takes up less space on the table.
I've been with it for about 15 days and I haven't had touchpad failures.
This new keyboard is dual BT and 2.4GHz wireless.
Is this model ...
Rii i4 (Mini Bluetooth & Wireless 2.4 GHz)
https://www.amazon.es/Rii-bluetooth-ina ... B07RQBRRR7
bjtheone
Tue Sep 17, 2019 2:01 pm
Interestingly enough I have a Kingston 128 GB (A400 I think) SSD, a USB 3.0 128 GB USB stick on the USB 3.0 ports, and two wireless dongles on the USB 2.0 ports (1 Microsoft for a media keyboard with touchpad, 1 Logitech Unifying for a MX Master 25 mouse). I mostly use the mouse for GUI stuff but do use on the touchpad on occasion, without any issues.
Just to add to the potential issues, the Pi is sitting approximately 18" from two wireless routers. Lurking on the same desk are 3 other laptops, two of which have Logitech wireless dongles in use. A work laptop with another MX Master joins the party most weekends. Have been using this setup daily for over a month, with absolutely no mouse/keyboard issues. It is being used as a desktop machine at home so only probably only averages an hour or two a day of usage, but still zero issues. It should not make a difference but I am running Buster - Raspbian Lite + Mate.
I wonder if it is a specific configuration issue in Raspbian, or some sort of marginal design issue such that some Pi 4 boards have issues and other don't. I would suspect that many people are running with wireless keyboards and mice. SSDs are probably far less common. Potentially I just happened to luck into a perfect combination of performance tolerances, but its a data point.
