I've read all the forum posts here that mention 'kexec', and I'm pretty sure I'm doing everything correctly. I also saw that support for kexec was added back in 3.2.18 but it's just not working for me.
When I run
sudo kexec --append "$(</proc/cmdline)" /boot/kernel.img
I've exhausted every possible test I could think of, but nothing works. I'm running the very latest (as of yesterday) firmware/kernel that I downloaded using the rpi-update script, and it definitely has kexec support built in.
I've also tried changing around the kernel boot parameters, omitting some, adding others (particularly debug, loglevel=7, and initcall_debug) but I still don't get a peep out of the new kernel. In all cases it just hangs and I have to power cycle.
At one point early on I did manage to get kexec to come up with "Bye" after trying to load the new kernel, but I don't know how to reproduce that behaviour. Not that that would be of any use, but I thought I should mention it anyway.
Here's a dump of all the relevant info I can think of from the system:
$ uname -a
Linux hamilton 3.2.27+ #307 PREEMPT Mon Nov 26 23:22:29 GMT 2012 armv6l GNU/Linux
$ zcat /proc/config.gz | grep -i kexec
CONFIG_KEXEC=y
$ cat /proc/cmdline
dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708.boardrev=0xe bcm2708.serial=0x282fc977 smsc95xx.macaddr=B8:27:EB:2F:C9:77 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1c000000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
$ cat /proc/cpuinfo
BogoMIPS : 697.95 (no overclock)
Revision : 000e
$ free
total used free shared buffers cached
Mem: 448948 92088 356860 0 11392 60276
$ perl -nle 'print if /^\d+[= ]/' /boot/config.txt
(no output: I'm using default config with no edits)
$ md5sum /boot/* # emergency kernel is mine, the rest are from rpi-update
a990c6bcb62a26880609b805ca9e71bb /boot/bootcode.bin
a51b441bfdde643f237ad2fa77027052 /boot/cmdline.txt
65b1f32223e8609ff5d0e80afb435285 /boot/config.emergency
5a17b9828796861050b3b17465a8ab1d /boot/config.txt
7c25ed1c16092063bc5fd0c64d5a0661 /boot/fixup_cd.dat
1935f75fdf989a78a9f99dc738e09626 /boot/fixup.dat
68ccad657720710325ce5c3890860a02 /boot/issue.txt
6227ede075298b5f6d124b8bfcad3032 /boot/kernel_cutdown.img
d574ffcbfbe87d9ca40fbb3caab0086f /boot/kernel_emergency.img
a27b345e85ab3e1d8db530bd805356dc /boot/kernel_emergency.old
c13c0fa41d86cb4f397129b11214ce65 /boot/kernel_emergency.sav
1794be00832e1f909b39c2412fb759e4 /boot/kernel.img
6e5296cb3f82310d7e8ac535bcbb387f /boot/start_cd.elf
5d192f847eb1aa55967ed6727f9e80aa /boot/start.elf
Thanks for reading!
