rpiuser1
New Lirc (0.10.1-5.2) is not working on Raspbian
Wed Jul 24, 2019 6:40 am
Hello.
I'm running Raspbian 10 (buster) on Raspberry Pi Zero.
I've soldered GPIO panel to Pi and wanted to add IR input with KY-022 IR Reciever.
Unfortunately on installing lirc I've got the following error: Job for lircd.service failed because a fatal signal was delivered to the control process.
Looks like it's a bug that is not yet fixed.
So how do I install a previous version of lirc?
I tried sudo apt-get install lirc=0.9.1 but it shows the error: Version '0.9.4' for 'lirc' was not found.
P.S. Controlling Raspberry with IR seems to be a common use case, so why isn't it included in the distro by default?
Re: New Lirc (0.10.1-5.2) is not working on Raspbian
Wed Jul 24, 2019 8:54 am
Because it's actually a very uncommon use case.
HiassofT
Wed Jul 24, 2019 9:30 am
This sounds a lot like you are hitting this Debian packaging bug: https://bugs.debian.org/cgi-bin/bugrepo ... bug=932779
Fortunately, the bug report mentions a simple workaround: when the installation fails, manually create the lirc_options.conf file:
sudo cp /etc/lirc/lirc_options.conf.dist /etc/lirc/lirc_options.conf
After that run "sudo apt-get install" to finish the installation.
PS: just verified that I see the same issue on my laptop running Debian Buster, and the workaround works there, too.
so long,
Hias
rpiuser1
Wed Jul 24, 2019 9:39 am
HiassofT, it works, thank you!
