dschwert
USB Sound distorted: Aureon Aureon Dual USB
Tue Dec 04, 2012 8:40 pm
Hi!
Is anybody successfully using a Terratec Aureon Aureon Dual USB?
Any special settings?
I just bought one because it's listed as supported device.
I can get analog audio output, but it's highly distorted, no matter how I set the volume.
I tried both of the latest wheezy images (hard and soft floating point).
I've tried with and without a powered USB hub.
Regards,
Dietmar
pluggy
Re: USB Sound distorted: Aureon Aureon Dual USB
Wed Dec 05, 2012 3:00 pm
try
dwc_otg.speed=1
added to cmdline.txt.
It forces the USB to use V1.1 speed. It usually cures problems with audio devices but doesn't do the performance any favours with USB hard drives and the like.
dschwert
Wed Dec 05, 2012 8:32 pm
Hi pluggy,
thanks a lot. That does indeed work but of course it's not a long term solution.
Can you recommend any USB audio adapter that's actually working with high speed USB (in the same price range, i.e. around 20 Euros)?
Do you know, whether a permanent solution can be expected?
It's a pity that the page at http://elinux.org/RPi_VerifiedPeripherals does just state that the device is working. I have applied for an account to add your hint and a warning.
Regards,
Dietmar
