I struggled for a couple of days to get crontab and selenium to do what I needed and had to use a number of threads from others to piece this together.
The main challenge was getting crontab working. The main issues are:
ensuring #PATH is correct for chromium and setting DISPLAY.
Note that using a line such as -> @reboot DISPLAY=:0 && etc (DID NOT WORK) I had to have DISPLAY on a separate line.
make sure to install selenium
program name is test1.py, this is in a user directory Selenium, but that name is just a coincidence and not relevant to the installation of selenium
The actual purpose of my code is to login to a website, so the # lines are related to this purpose and I've kept them here in case it helps others doing similar.
Please note that I do not describe myself in any way as having linux expertise so can't enter into any detailed discussion on the operation or further fault finding.
print('test1 start')
import time
import datetime
from selenium import webdriver
from selenium.webdriver.chrome.options import Options
from selenium.webdriver.common.keys import Keys
print ('imports')
now = datetime.datetime.now()
now_string = now.strftime("%Y-%m-%d %H:%M:%S") + " : "
print(now_string, 'web demo start')
# start chrome with options in kiosk mode
chromeoptions = Options()
chromeoptions.add_argument("--disable-infobars")
chromeoptions.add_argument("--kiosk")
driver = webdriver.Chrome('/usr/lib/chromium-browser/chromedriver', 0, chromeoptions)
print ('sites')
driver.get('http://www.bbc.com')
time.sleep(10)
#driver.find_element_by_name("username").send_keys("Username")
#driver.find_element_by_name("password").send_keys("Password")
#button = driver.find_element_by_name('commit').send_keys(Keys.RETURN)
print ('test1 end')
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games:/usr/lib/chromium-b$
DISPLAY=:0.0
@reboot python3 /home/pi/Selenium/test1.py > /home/pi/Selenium/log.txt 2>&1
