MacBook Pro Integrated Keyboard and Trackpad Not Working
Posted: Sat Jul 20, 2019 6:43 pm
by robertr356
I’m a beginner with Raspberry Pi and I’m trying to set it up on my MacBook Pro (2017). I have the Raspberry Pi on a USB and I’m able to launch it, however when I reach the desktop, I’m not able to use the integrated keyboard and trackpad that is on my laptop. I can connect, through USB, a wired mouse and keyboard and then it works fine, however it produces a lot of clutter in my work space. Is there any way I can enable and use the integrated keyboard and trackpad on my MacBook?
Thanks,
- Robert
Re: MacBook Pro Integrated Keyboard and Trackpad Not Working
Posted: Sat Jul 20, 2019 8:45 pm
by fruitoftheloom
Thanks,
- Robert
Raspberry Pi is a Single Board Computer !
Therefore what Operating System are you talking about, a link to the download would be good.
Posted: Fri Aug 02, 2019 7:22 pm
by robertr356
Thanks,
- Robert
I’m running Linux, and unfortunately I do not have a direct link to the download because I’m using Raspberry Pi for a project and was only given a USB that had it.
Posted: Fri Aug 02, 2019 7:42 pm
by Andyroo
How do you connect to the Pi? Is it RealVNC or some other program on the Mac?
Can you run the following on the Pi and post the results here:
uname -a
cat /etc/os-release
If you are using RealVNC it is possible that it is set to view only mode - I’m not at my Mac for a few hours but maybe this will help https://www.realvnc.com/en/connect/docs ... wonly.html
Note: This can be set on the Mac and/or the Pi so check both ends
Posted: Fri Aug 02, 2019 8:17 pm
by drgeoff
I suspect that the OP's sentence "I have the Raspberry Pi on a USB and I’m able to launch it, however when I reach the desktop, I’m not able to use the integrated keyboard and trackpad that is on my laptop." means a cable between USB port on the Mac and the power input socket on the RPi.
Posted: Fri Aug 02, 2019 8:25 pm
by fruitoftheloom
OR maybe he is actually running x86 Debian with Raspberry Pi Desktop from USB Stick ???
