talmadage
GPIO pins having trouble
Fri Jul 19, 2019 4:25 am
So yesterday I accidentally connected the pi's neutral pin to a 12V power supply. In a few seconds I understood the mistake as switched it off. Now the pi is booting and working properly but the GPIO pins are not giving proper output. I know this as I am doing a door lock using face recognition project and the lock is opening randomly.
So is there any way to fix this??
Re: GPIO pins having trouble
Fri Jul 19, 2019 8:54 am
I believe you have destroyed the GPIO circuitry in the SoC. This is unfixable.
joan
Fri Jul 19, 2019 9:39 am
wiringPi has a pintest utility. pigpio has a similar gpiotest utility.
http://abyz.me.uk/rpi/pigpio/examples.h ... l_gpiotest
LTolledo
Fri Jul 19, 2019 11:08 am
If it is still bootable as you claimed, then it may be used for other projects that does not require GPIO functionality
and as jamesh mentioned, its unfix-able.
learn your lesson and move on....
Some people be like:
drgeoff
Fri Jul 19, 2019 4:27 pm
Damage to GPIOs can lead to an effect which propagates within the SoC and sooner or later causes it to fail completely. Hope for the best but be prepared.
