DarkPlatinum
Contact: Website YouTube
Raspberry Pi Wifi turns off and not found (BusterP
Thu Jul 18, 2019 11:43 am
Hello, after recently upgrading from stretch to buster on my Pi 3B+, the wifi drops out and "no wireless interfaces found" appears after 40000 seconds or so. My dmesg log shows this:
[46674.827497] hub 1-1.1.2:1.0: USB hub found
[46674.828189] hub 1-1.1.2:1.0: 4 ports detected
[49046.497963] usb 1-1.1.2: USB disconnect, device number 19
[52509.150379] brcmfmac: brcmf_run_escan: error (-52)
[52509.150394] brcmfmac: brcmf_cfg80211_scan: scan error (-52)
[66069.325870] brcmfmac: brcmf_run_escan: error (-52)
[66069.325885] brcmfmac: brcmf_cfg80211_scan: scan error (-52)
[68472.177363] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[68472.177380] brcmfmac: power management disabled
[68472.406108] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[68472.406123] 8021q: adding VLAN 0 to HW filter on device eth0
[68476.767574] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[68476.767638] brcmfmac: power management disabled
Can someone reproduce this problem? I did not have this on Raspbian stretch. I am using a 3B+ with a 32GB sd card paired with OS on a 1TB external HDD seagate drive.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
Re: Raspberry Pi Wifi turns off and not found (BusterP
Thu Jul 18, 2019 3:59 pm
This is a doctor free zone.
HawaiianPi
Thu Jul 18, 2019 4:10 pm
Did you start with a clean Buster install, or upgrade Stretch to Buster?
Thu Jul 18, 2019 4:17 pm
Neither. That's Stretch with the latest rpi-update kernel. So the temporary fix on Buster is
sudo apt install rpi-update
# not installed by default to discourage misuse
sudo rpi-update f8060224e53e26cdaea5b9f6f010ac8c3692e2ea
sudo purge rpi-update
# because you don't need it normally
DarkPlatinum
Thu Jul 18, 2019 5:22 pm
I had done a dist-upgrade to buster.
DarkPlatinum
Thu Jul 18, 2019 5:52 pm
Is the rpi-update stable or should I just wait for a normal update?
Thu Jul 18, 2019 6:03 pm
That rpi-update has been stable on my Raspberry since 07:42BST this morning.
