[CM3] spidev spi2.0: setup: unsupported mode bits 1
Posted: Wed Jul 17, 2019 10:04 am
by shinasys
I use CM3, and add dtoverlay=spi2-1cs.
if i change the spi mode to SPI_MODE_1, meet error...
ioctl always return -1.
SPI_MODE_0 have no problem, but set SPI_MODE_1 to CPHA(data is clocked in on falling edge).
my code is general as following :
spi_cs_fd = open("/dev/spidev2.0", O_RDWR);
if (spi_cs_fd < 0)
perror("Error - Could not open SPI device");
exit(1);
status_value = ioctl(spi_cs_fd, SPI_IOC_WR_MODE, &spi_mode); =====> always return -1
if(status_value < 0)
perror("Could not set SPIMode (WR)...ioctl fail");
exit(1);
spidev1.0 and spidev1.1 are all good, but spidev2.0 make error.
error on dmesg is following :
[ 1260.033552] spidev spi2.0: setup: unsupported mode bits 1
How can I solve this problem?
Re: [CM3] spidev spi2.0: setup: unsupported mode bits 1
Posted: Wed Nov 27, 2019 6:44 pm
by wiwi
I have exactly the same problem with a CM1 board.
I can change the mode with the the SPI0 but not with the SPI2!
I didn't have checked if IOCTL return -1, but spi-config return "SPI_IOC_WR_MODE: Invalid argument".
DMESG: [ 159.636574] spidev spi2.0: setup: unsupported mode bits 1
Do you have some news about this?
Best regards,
Wilfrid
Posted: Wed Nov 27, 2019 6:58 pm
by joan
Experiment has demonstrated that modes 1 and 3 do not work on the auxiliary SPI (i.e. the SPI device which uses GPIO 16-21).
Posted: Wed Nov 27, 2019 7:14 pm
by wiwi
Thanks a lot for the information :) I didn't think to try the others mode.
Wilfrid
