Autonomous commands execution
Posted: Tue Jul 16, 2019 12:10 pm
by nick8967
Is there any possibilty to make the Raspberry run commands by itself, without typing commands? What I mean is this: suppose I have a program running in Raspberry Pi 3 B+, and concerning the outputs I take on the terminal I give different commands: do this, do that etc. What I want to achieve is to setup the Raspberry and let it work autonomously and the commands I would give on terminal, to program it in such a way, so that to be executed autonomously.
Thank you...
Re: Autonomous commands execution
Posted: Tue Jul 16, 2019 12:30 pm
by klricks
Not sure what you are asking?
The xdotool package will allow you to execute keyboard key-press & mouse move/clicks from scripts.
sudo apt update
sudo apt install xdotool
xdotool -h
man xdotool
or Google for examples.
Posted: Tue Jul 16, 2019 12:43 pm
by nick8967
For example: I start a program, this program gives me an output on the terminal, then I should give a command as far the output is concerned, the command is executed, the program gives me an output on the terminal, I should give another command, the program gives me another output, then I should give another command, etc until the program finally finishes. This whole procedure I want to take place automatically.
Posted: Tue Jul 16, 2019 1:29 pm
by PhatFil
Yes put your commands in a bash script file, make it executable and give permissions to any users that need it.
(GOOGLE/SEARCH 'Make bash script executable Raspberry Pi' )
to schedule your script to run at startup, before shut down, or at a specified time use cron
(GOOGLE/SEARCH 'Raspberry Pi crontab')
to execute your commands conditional on an input or condition write a monitoring program/script containing your logic and use crontab above to schedule it to start with the pi.
(GOOGLE/SEARCH 'Raspberry Pi programming')
Posted: Tue Jul 16, 2019 1:40 pm
by PiGraham
If you know what commands you want to run in what sequence in what situation you can simply put the commands in a shell script. That is you can write a program in script and have it do quite complex things.
Alternatively you can invoke commands from various programming language such as Python and make use of Python libraries and features to work out what commands to run when.
If you are thinking of having the RPi automatically working out for itself what commands to run that takes you into Artificial Intelligence and a different order of complexity.
Posted: Tue Jul 16, 2019 3:49 pm
by Andyroo
You may get away with a long series of ‘IF THEN’ statements or a finite state machine.
The hard bit maybe reading the output on the GUI screen - terminal / console output is easier to handle.
