RPi 4 Buster No audo over HDMI
Posted: Tue Jul 16, 2019 11:25 am
by omikron
Everything is updated and upgraded to latest Buster, but still not Audio over HDMI.
is uncommented in config.txt
Re: RPi 4 Buster No audo over HDMI
Posted: Tue Jul 16, 2019 2:32 pm
by trejan
Works okay here. What does "sudo tvservice -a" say?
Posted: Tue Jul 16, 2019 5:01 pm
by omikron
It says
PCM supported: Max channels: 2, Max samplerate: 96kHz, Max samplesize 24 bits.
Posted: Mon Sep 23, 2019 9:56 pm
by thomasj
Wow! Is that it?
Question answered and no response!
This issue was posted back in July.
I have the same problem with the newest Raspbian on my new RPi 4B 2G. pulseaudio is not finding the driver for HDMI audio output.
Is this a problem that Raspbian has not been updated for the Rpi4 chip set?
Posted: Tue Sep 24, 2019 8:48 am
by LTolledo
pulseaudio removed from Raspbian (since Raspbian Jessie)
....only works with alsa....
and HDMI audio only works on HDMI0 (zero) and not HDMI1 (one)
Posted: Tue Sep 24, 2019 3:01 pm
by thomasj
This I understand but alsa doesn't even find my USB audio capture device. I installed pulse audio and at least I now have input from my stereo audio capture device. I still have no device listed as output for the HDMI.
How do I switch between HDMI-0 and HDMI-1?
Posted: Tue Sep 24, 2019 7:59 pm
by LTolledo
to switch is overly simple
just plug the micro-HDMI cable to HDMI0 (near the USB-C port)
now was that a very hard, complex procedure?
Posted: Tue Sep 24, 2019 8:17 pm
by thomasj
No, that was not to hard at all. One would surmise that this would be the logical assumption, although I have not yet run into anything where this was explicitly stated. It also may be that since I asked "how do I switch the HDMI ports", one might also assume that I already tried that without results and answered without condescending sarcasm.
I have given up on Raspbian anyway and moved back to ubuntu-server where I have proven the use of my device by issuing "arecord --device=hw:1,0 -f dat -c2 test.wav" and was successful in recording an external event.
Thanks, anyway.
