Raspberry Pi 3b+ not booting after connected to Raspberry pi camera
Posted: Mon Jul 15, 2019 6:20 pm
by AshbirDhiman
I am using Raspberry Pi 3 b+ for 3 months. I connected the pi using laptop Ethernet SSH connection. Yesterday i connected raspberry pi camera to the raspberry pi and enabled the interface setting using .raspi/config setting. But suddenly the pi disconnected and not booting till now. I have installed the Raspbian OS using NOOBS on the SD card. I also changed the SD card but still the problem persist :cry: Please help!!!!
Re: Raspberry Pi 3b+ not booting after connected to Raspberry pi camera
Posted: Thu Jul 18, 2019 11:52 am
by AshbirDhiman
Please suggest something!!
Posted: Thu Jul 18, 2019 11:55 am
by B.Goode
Disconnect the camera and try again.
Posted: Thu Jul 18, 2019 12:00 pm
by AshbirDhiman
I tried this also but raspberry Pi is not booting
Only the red light is on and ACT led is not on for a single time. :/
Posted: Thu Jul 18, 2019 1:12 pm
by B.Goode
There is a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - https://www.raspberrypi.org/forums/view ... 28&t=58151
Posted: Fri Jul 19, 2019 5:13 pm
by AshbirDhiman
still not found ?
Could you tell what happened exactly or to my Pi?
or there is manufacturing default in Pi !.
Posted: Fri Jul 19, 2019 10:20 pm
by alphanumeric
Are you sure you connected the camera to the CSI and not the DSI by mistake?
Do you own a multimeter / voltmeter you could use to measure the +5V and +3V on the GPIO pins?
Have you tried a different power supply and a different SD card?
Posted: Sat Jul 20, 2019 4:55 pm
by AshbirDhiman
I tried a different power supply and 2 different SD and connected the camera to the CSI port near to the HDMI port though i have not measured +5 V or +3V on the GPIO pins
Posted: Sat Jul 20, 2019 5:09 pm
by alphanumeric
With no SD card inserted, does the green act LED blink when you power up the Pi?
Posted: Sat Jul 20, 2019 5:39 pm
by AshbirDhiman
No,The green ACT LED does not blink when no SD card inserted !!
Posted: Sat Jul 20, 2019 6:31 pm
by rpdom
It shouldn't blink on a Pi 3B+. Only the Pi 4B (and possible later versions) do anything with the ACT LED without an SD card.
Posted: Sat Jul 20, 2019 6:52 pm
by AshbirDhiman
Then why Pi is not booting ? Please help !
It has been a 2 weeks now...I have not found a solution to this !
Please suggest if you can !!
Posted: Sat Jul 20, 2019 7:02 pm
by pcmanbob
I think you need to test the 3.3V is still present on the gpio header as that is a known point of failure on the pi3B+ , the sudden failure of this is for no apparent reason has been reported on this forum.
Posted: Sat Jul 20, 2019 7:20 pm
by alphanumeric
What he said, you need to check the voltages, especially the 3v. Best guess is you had an electrostatic discharge while connecting the camera and something got fried.
Posted: Tue Jul 23, 2019 5:17 pm
by AshbirDhiman
I will try that . Thanks alot for helping :)
