AshbirDhiman
Raspberry Pi 3b+ not booting after connected to Raspberry pi camera
Mon Jul 15, 2019 6:20 pm
I am using Raspberry Pi 3 b+ for 3 months. I connected the pi using laptop Ethernet SSH connection. Yesterday i connected raspberry pi camera to the raspberry pi and enabled the interface setting using .raspi/config setting. But suddenly the pi disconnected and not booting till now. I have installed the Raspbian OS using NOOBS on the SD card. I also changed the SD card but still the problem persist :cry: Please help!!!!
B.Goode
Re: Raspberry Pi 3b+ not booting after connected to Raspberry pi camera
Thu Jul 18, 2019 11:55 am
AshbirDhiman wrote:
Thu Jul 18, 2019 11:52 am
Please suggest something!!
Disconnect the camera and try again.
AshbirDhiman
Thu Jul 18, 2019 12:00 pm
I tried this also but raspberry Pi is not booting
Only the red light is on and ACT led is not on for a single time. :/
B.Goode
Thu Jul 18, 2019 1:12 pm
There is a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - https://www.raspberrypi.org/forums/view ... 28&t=58151
AshbirDhiman
Fri Jul 19, 2019 5:13 pm
still not found ?
Could you tell what happened exactly or to my Pi?
or there is manufacturing default in Pi !.
alphanumeric
Fri Jul 19, 2019 10:20 pm
Are you sure you connected the camera to the CSI and not the DSI by mistake?
Do you own a multimeter / voltmeter you could use to measure the +5V and +3V on the GPIO pins?
Have you tried a different power supply and a different SD card?
AshbirDhiman
Sat Jul 20, 2019 4:55 pm
I tried a different power supply and 2 different SD and connected the camera to the CSI port near to the HDMI port though i have not measured +5 V or +3V on the GPIO pins
alphanumeric
Sat Jul 20, 2019 5:09 pm
With no SD card inserted, does the green act LED blink when you power up the Pi?
AshbirDhiman
Sat Jul 20, 2019 5:39 pm
No,The green ACT LED does not blink when no SD card inserted !!
Sat Jul 20, 2019 6:31 pm
It shouldn't blink on a Pi 3B+. Only the Pi 4B (and possible later versions) do anything with the ACT LED without an SD card.
Unreadable squiggle
AshbirDhiman
Sat Jul 20, 2019 6:52 pm
Then why Pi is not booting ? Please help !
It has been a 2 weeks now...I have not found a solution to this !
Please suggest if you can !!
pcmanbob
Sat Jul 20, 2019 7:02 pm
I think you need to test the 3.3V is still present on the gpio header as that is a known point of failure on the pi3B+ , the sudden failure of this is for no apparent reason has been reported on this forum.
alphanumeric
Sat Jul 20, 2019 7:20 pm
What he said, you need to check the voltages, especially the 3v. Best guess is you had an electrostatic discharge while connecting the camera and something got fried.
AshbirDhiman
Tue Jul 23, 2019 5:17 pm
I will try that . Thanks alot for helping :)
