still not found ?B.Goode wrote: ↑Thu Jul 18, 2019 1:12 pmThere is a summary of all the knowledge accumulated from these forums during the past 7 years about difficulties getting an RPi to boot, see - STICKY: Is your Pi not booting? (The Boot Problems Sticky) - https://www.raspberrypi.org/forums/view ... 28&t=58151
I tried a different power supply and 2 different SD and connected the camera to the CSI port near to the HDMI port though i have not measured +5 V or +3V on the GPIO pinsalphanumeric wrote: ↑Fri Jul 19, 2019 10:20 pmAre you sure you connected the camera to the CSI and not the DSI by mistake?
Do you own a multimeter / voltmeter you could use to measure the +5V and +3V on the GPIO pins?
Have you tried a different power supply and a different SD card?
No,The green ACT LED does not blink when no SD card inserted !!alphanumeric wrote: ↑Sat Jul 20, 2019 5:09 pmWith no SD card inserted, does the green act LED blink when you power up the Pi?
It shouldn't blink on a Pi 3B+. Only the Pi 4B (and possible later versions) do anything with the ACT LED without an SD card.alphanumeric wrote: ↑Sat Jul 20, 2019 5:09 pmWith no SD card inserted, does the green act LED blink when you power up the Pi?
Then why Pi is not booting ? Please help !rpdom wrote: ↑Sat Jul 20, 2019 6:31 pmIt shouldn't blink on a Pi 3B+. Only the Pi 4B (and possible later versions) do anything with the ACT LED without an SD card.alphanumeric wrote: ↑Sat Jul 20, 2019 5:09 pmWith no SD card inserted, does the green act LED blink when you power up the Pi?
I will try that . Thanks alot for helpingalphanumeric wrote: ↑Sat Jul 20, 2019 7:20 pmWhat he said, you need to check the voltages, especially the 3v. Best guess is you had an electrostatic discharge while connecting the camera and something got fried.
