MPD and bluetooth speaker issue in Raspbian Buster (used to work with Stretch)
Posted: Sat Jul 13, 2019 10:22 pm
by fbe
Installed Raspbian Buster Lite (2019-07-10).
sudo apt install mpd mpc bluealsa
After reboot paired and connected my speaker using bluetoothctl.
aplay -D bluealsa:HCI=hci0,DEV=78:44:05:8d:06:74,PROFILE=a2dp /usr/share/sounds/alsa/Front_Center.wav
produces sound as expected.
Appended configuration to /etc/mpd.conf
audio_output {
        type            "alsa"
        name            "JBL GO"
        device          "bluealsa:HCI=hci0,DEV=78:44:05:8d:06:74,PROFILE=a2dp"
mixer_type "software"
Restarting mpd and play something...
sudo systemctl restart mpd
mpc clear
mpc add file:///usr/share/sounds/alsa/Front_Center.wav
mpc play 1
This used to work with Raspbian Stretch. In Buster I have an error in /var/log/mpd/mpd.log:
Jul 13 23:41 : exception: Failed to play on "JBL GO" (alsa): snd_pcm_poll_descriptors_revents() failed: Invalid argument
Is there anybody successfully using mpd and bluetooth speakers with Raspbian Buster?
Re: MPD and bluetooth speaker issue in Raspbian Buster (used to work with Stretch)
Posted: Mon Jul 15, 2019 7:44 pm
by fbe
First success with workaround:
audio_output {
       type            "pipe"
       name            "pipe to JBL GO"
       command         "aplay -D bluealsa:HCI=hci0,DEV=78:44:05:8d:06:74,PROFILE=a2dp -f cd 2>/dev/null"
       format          "44100:16:2"
in /etc/mpd.conf
Posted: Sat Jul 20, 2019 2:52 pm
by delcre
I had exactly the same problem.
Things worked in 'Stretch", but they did not work in 'Buster'.
The workaround shown in this thread worked. Thank you!
But does anyone know about root cause of this?
Posted: Mon Sep 23, 2019 6:32 pm
by vernonjvs
The problem seems to be HCI=hci0. Once I remove this, everything works fine on my Rasperry Pi Zero W.
My mpd.conf looks at follows
audio_output {
       type            "alsa"
       name            "S113BT"
       device          "bluealsa:DEV=00:1A:7D:D0:81:E0,PROFILE=a2dp"
       mixer           "software"
       format          "44100:16:2"
The format line is only needed if you have high quality flac files.
Posted: Mon Sep 30, 2019 7:13 pm
by Thomas-F
Hello, I'm new here and writing for the first time in a forum and apologize if I didn't notice anything.
The described problem has occupied me a lot.
I compared on a raspberry zero w a simple stretch lite installation (8.Apr 2019) and a simple buster lite installation (10.Jul 2019) each with bluealsa.
This command only works with stretch
$ aplay -D bluealsa:HCI=hci0,DEV=02:1A:01:0C:EF:DA,PROFILE=a2dp /usr/share/sounds/alsa/Front_Center.wav
This command only works with buster
$ aplay -D bluealsa:SRV=org.bluealsa,DEV=02:1A:01:0C:EF:DA,PROFILE=a2dp /usr/share/sounds/alsa/Front_Center.wav
The difference lies in different interpretation files
stretch: \usr\share\alsa\alsa.conf.d\20-bluealsa.conf
buster: \etc\alsa\conf.d\20-bluealsa.conf
In buster the corresponding part of my /etc/asound.conf file looks like this
pcm.btspeaker {
    type plug
    slave.pcm {
       type bluealsa
       service org.bluealsa
       device "02:1A:01:0C:EF:DA"
       profile "a2dp"
