Chromium-browser not creating screenshot
Posted: Fri Jul 12, 2019 10:02 am
by Aardappeltaart
I'm trying out the chromium-browser on a headless RPI4 Raspbian Lite:
chromium-browser --version
Chromium 74.0.3729.157 Built on Raspbian , running on Raspbian 10
I'm not able to create a screenshot running headless:
chromium-browser  --window-size=1280,1024 --screenshot --headless https://raspberrypi.org
No screenshot.png created.
Is --screenshot not supported on the pi, or do I need extra packages?
Re: Chromium-browser not creating screenshot
Posted: Sun Jul 14, 2019 6:40 pm
by DougieLawson
Forget that --screenshot parm. Install scrot and us that to capture what you need.
Posted: Mon Jul 15, 2019 12:42 pm
by klricks
scrot is already installed by default and linked to [Print Screen] key.
Posted: Mon Jul 15, 2019 4:20 pm
by Aardappeltaart
Thx, but can you run scrot on a headless Pi?
--screenshot --headless is for running chromium on servers, and create screenshots for automated testing, so without X11
Quite nice actually.
Should file a bug report then, but where?
(BTW also selenium could not create screenshot)
Posted: Mon Jul 15, 2019 6:13 pm
by DougieLawson
If you run the RealVNC server you can run scrot with
DISPLAY=:0 scrot ...
from a command line.
Posted: Mon Jul 15, 2019 7:43 pm
by Aardappeltaart
yeah, but
giblib error: Can't open X display. It *is* running, yeah?
And not using realvnc
AFAIK Chromium-browser can be installed on all debian/ubuntu based server installs (x64 & arm) to run headless/
Just tried it on Ubuntu Server on x64 and ARM, so why can't it be done on the Pi?
Posted: Mon Jul 15, 2019 8:02 pm
by DougieLawson
Probably because the code is broken. Get you coding pencil, your pencil sharpener and a coding pad. The source code is available.
Posted: Tue Jul 16, 2019 10:19 am
by Aardappeltaart
Thanks for the advice,
IMHO a bug report is the better option here.
Anybody knows the appropriate place for that, could be related to the special RPI fixes (GPU accelerated)
This seems obsolete:
https://github.com/raspberrypi-ui/chromium_patches
Posted: Tue Jul 16, 2019 10:29 am
by ShiftPlusOne
Posted: Fri Jan 17, 2020 4:29 pm
by Aardappeltaart
Yes, it's working now.
sudo apt full-upgrade
 --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
Chromium 78.0.3904.108 Built on Raspbian , running on Raspbian 10
This ssh command now saves a nice screenshot.png in home:
ssh pi4 chromium-browser  --window-size=1280,1024 --screenshot --headless https://raspberrypi.org
Thx all.
