Madaeng
Need help establishing a serial connection
Tue Jul 09, 2019 1:27 pm
Hi all,
I'm currently working on a project to integrate a pi zero W in my neato Botvac.
Connecting it by way of a USB cable was pretty straightforward, tried that out according to this method: https://www.instructables.com/id/How-to ... pberry-Pi/
However, since I want to be able to use it differently then in that thread, the USB port was not an option as that didn't fit with the dust bin in.
So, I decided to use the RS232 port on the BotVac board instead, connecting the pi's UART port with a MAX3232 board
https://www.sparkfun.com/products/11189
to convert the signal suitable for the RS232.
The MAX3232 draws its power from the pi and everything is hooked up as follows, with the only differences being that I used the 3V3 pin on the pi, and I don't utilise the 'bottom' part of the BotVac board.
I've disabled the terminal on the pi, and tried to connect to the BotVac using
sudo screen /dev/ttyS0
(instead of
sudo screen /dev/ACM0
However, whenever I try this, screen is non-responsive to any input and I have to CTRL-A CTRL-D out of it. I figured I may have switched the rx&tx, but switching those is to no avail either.
Does anyone have any clues on where the problem may lie?
Milliways
Re: Need help establishing a serial connection
Wed Jul 10, 2019 6:20 am
Pin 8 is Serial Output
Pin 10 is Serial Input
Madaeng
Wed Jul 10, 2019 7:28 pm
I triple checked, ànd tried switching the wires just to make sure. That’s not the problem.
I read something about baud rate. Is there a possibility that that causes the complete lack of response?
B.Goode
Wed Jul 10, 2019 8:08 pm
If you are using asynchronous communication, having matching baud rates on the receiver and transmitter is absolutely fundamental in being able to transfer data or messages.
So yes, this is a possibility.
Madaeng
Thu Jul 11, 2019 9:49 am
Turns out I got some bad information and didn't need the MAX3232 at all.
Serial port is probably fried, back to the drawing board....
