penguintutor
Raspberry Pi 4 not working with NexDock screen
Tue Jul 09, 2019 10:46 am
Has anyone got the Raspberry Pi 4 working with the 1st generation NexDock (2nd generation expected in a couple of months time)?
If so what settings are you using on the Pi?
When I try the screen is being detected (as the screen goes brighter and does not time out), but nothing is displayed. No colour splash or desktop.
The Pi works fine when I move the cable from the NexDock to a TV. The NexDock works fine with older models of the Raspberry Pi (although not tried with the latest Raspbian except using a Pi 4).
I have tried HDMI force (not 4K). I'm guessing it may be due to an unsupported resolution but if I try and use the resolution changer GUI I get an RandR index out or range error. I'm thinking I may need to start manually configuring different HDMI modes until I get a setting that works, but wondering if anyone has already gone through this and found the best settings to use?
penguintutor
Re: Raspberry Pi 4 not working with NexDock screen
Tue Jul 09, 2019 8:47 pm
After a lot of work trying different configurations I finally found a working solution. Not only did I have to find a suitable resolution, but I had to disabled the edid from being read from the screen.
These are the entries in my /boot/config.txt for anyone else that has similar problems.
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=86
hdmi_force_mode=1
This provides a resolution of 1366x768
mikeyp
Sat Apr 04, 2020 8:51 pm
hdmi_group=2
hdmi_mode=86
hdmi_force_mode=1
Sorry to necro-post but I just wanted to add this is the only thing that fixed this issue for me on the Pi4. It can indeed do 1366x768.
I still don't get the rainbow screen but once it boots into Raspbian it's fine.
penguintutor
Mon Apr 06, 2020 9:54 am
It's worth noting that this only applies to the original NexDock. The new NexDock 2 is now available which is very different from the first model.
As far as I've tested the new NexDock 2 works out of the box with all current models of Raspberry Pi without need for any special configuration on the Raspberry Pi.
See http://www.penguintutor.com/news/hardware/nexdock2
