phil995511
Problem with two ssd connected on the two USB 3 ports of RPi 4
Fri Jul 05, 2019 3:09 pm
Hello
I encounter read/write errors when I connect 2 ssd or a ssd and a USB key on each of the 2 USB 3 ports of the RPi 4, as is the case on external HUBs not being able to support several devices.
My frimware is updated to version 000137a8.
Best regards.
k-pi
Re: Problem with two ssd connected on the two USB 3 ports of RPi 4
Fri Jul 05, 2019 3:25 pm
The USB ports still only supply the same power as the RPi3Bs, so you'll need an external power supply for them, if I understand your question right.
b3lt3r
Fri Jul 05, 2019 3:58 pm
I could have sworn I saw a comment in the original release materials that one of the benefits of upgrading the power supply to USB-C/3a from micro/2.5 was that USB devices *may* not require external power.
Personally, I would not trust disks without the best power supply possible having just been through a nightmare recovery following a recent power outage but YMMV (and it wouldn't have been a nightmare with proper backups so two lessons learnt!)
Point is - I don't think it's correct to say the power supplied is the same as Pi3 but I am not an expert.
** Edit ** tracked back and suspect both points are kind of correct. USB may deliver the same max output as a standard but the intent was that there would be enough grunt in the supply to not be constrained when CPU load was high...... Either way, my point stands - I would always put disks on a hub
jdb
Fri Jul 05, 2019 5:10 pm
Firmware 137a8 is causing issues with many USB3.0 devices - please revert to 13701.
Rockets are loud.
https://astro-pi.org
phil995511
Fri Jul 05, 2019 9:14 pm
Tank you JDB for your feedback I'll do the necessary tomorrow.
Is there a directory of your website where we can find the future frimwares be it Beta, RC or stable ??
Best regards.
Philippe
HawaiianPi
Fri Jul 05, 2019 9:42 pm
The Pi's 1.2A should be sufficient any portable drive, but that's assuming you have no other power hungry accessories, and of course, you have a proper 3A power supply (due to the higher power requirements of the SoC).
If you have multiple portable drives, or other power hungry accessories then you may find a hub is needed, but it's certainly not necessary, or even needed by many users. I've been using portable drives on my 3B and 3B+ computers for years without a hub.
The most important thing is to have a stable power supply. Many phone chargers have poor voltage regulation and will not maintain a stable 5V under load, and some cheap USB-C "charging" cables are only rate for 2.4A (or less). Long cables as well as extra connections or adapters can also contribute to voltage loss and low power troubles.
Note that a laptop drive in an enclosure is technically not a portable drive. Some laptop drives are shockingly power hungry, and putting one in an enclosure does not magically fix that. If you take a drive rated for 1A or more current and put it in an enclosure, don't be surprised when it doesn't work on a Raspberry Pi computer.
