LibreOffice Cursor in Buster
Posted: Fri Jul 05, 2019 12:40 pm
by exartemarte
I'm trying out a Pi4 4 as a second desktop, and so far I'm quite impressed. In LibreOffice Writer, however, no text cursor is visible, which is inconvenient to say the least. If anyone knows how/where to fix this I'd be most grateful.
(The Pi is running Raspbian Buster 2019-06-20. I'm typing this in the Raspberry Pi Forum app where the cursor is normal, so it doesn't seem to be any sort of system-wide problem. It's also normal in the text editor.)
Afternote: By changing the background colour in LibreOffice I've discovered that the cursor is there but is white. So what I need is to find out how to change the colour of the cursor.
Re: LibreOffice Cursor in Buster
Posted: Fri Jul 05, 2019 1:19 pm
by jamesh
This is fixed and in the latest apt update/upgrade.
Posted: Fri Jul 05, 2019 2:32 pm
by exartemarte
Thank you, Jamesh. Unfortunately that hasn't worked for me; when I update/upgrade this is what I get:
[email protected]:~ $ sudo apt-get update
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Reading package lists... Done
[email protected]:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libboost-system1.62.0 libboost-thread1.62.0
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
  libreoffice-pi nodered
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
The LibreOffice Cursor is still not visible.
Posted: Fri Jul 05, 2019 2:34 pm
by jamesh
Hmm. Odd. I'll flag this up to the guy who fixed it.
Posted: Fri Jul 05, 2019 2:35 pm
by rpdom
Try sudo apt-get dist-upgrade
The fact you got
suggests that there are additional packages that need installing and a straight "upgrade" will not do that.
Posted: Fri Jul 05, 2019 2:36 pm
by jamesh
The fact you got
What he said, as confirmed by the bloke who knows (not me).
Posted: Fri Jul 05, 2019 2:52 pm
by exartemarte
That works. Thank you, rpdom and Jamesh. (And the bloke who knows . . .)
Posted: Sun Jul 07, 2019 7:35 pm
by petracus
Same issue here, the cursor is not visible with update/upgrade (distro too).
Any suggestion?
Thx.
Posted: Sun Jul 07, 2019 8:01 pm
by pcmanbob
Any suggestion?
Thx.
Did you try
sudo apt update
sudo apt full-upgrade
Posted: Sun Jul 07, 2019 8:29 pm
by petracus
[email protected]:~ $ sudo apt upgrade
Leyendo lista de paquetes... Hecho
Creando árbol de dependencias
Leyendo la información de estado... Hecho
Calculando la actualización... Hecho
0 actualizados, 0 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
[email protected]:~ $ sudo apt full-upgrade
[email protected]:~ $ sudo apt update
Obj:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Obj:2 http://archive.raspberrypi.org/debian buster InRelease
Todos los paquetes están actualizados.
No luck.
Posted: Sun Jul 07, 2019 8:31 pm
by DirkS
No luck.
The first command is not
sudo apt upgrade
but
sudo apt update
Try again...
Posted: Sun Jul 07, 2019 8:34 pm
by pcmanbob
It should not be any different but try
sudo apt-get update
Posted: Sun Jul 07, 2019 8:42 pm
by petracus
Obj:1 http://archive.raspberrypi.org/debian buster InRelease
Obj:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
[email protected]:~ $ sudo apt-get dist-upgrade
Same. The cursor is ok in other apps, like Chromium, but dissapears (seems is white) in Libreoffice.
Posted: Sun Jul 07, 2019 8:54 pm
by pcmanbob
Have you rebooted the since updating ?
Posted: Sun Jul 07, 2019 9:00 pm
by petracus
Reboot now. Same result.
Posted: Sun Jul 07, 2019 9:06 pm
by pcmanbob
Then I am at a loss as to why it works for others but not for you , my be Jamesh or the bloke who knows will have some ideas tomorrow.
Posted: Sun Jul 07, 2019 9:11 pm
by petracus
Thank you anyway.
Posted: Mon Jul 08, 2019 7:11 am
by petracus
Hi, solve the problem with:
sudo apt-get install libreoffice-pi nodered
nodered ya está en su versión más reciente (0.20.6-1).
Se instalarán los siguientes paquetes adicionales:
  gstreamer1.0-gtk3 libreoffice-gtk3
Paquetes sugeridos:
  libreofficekit-data
Se instalarán los siguientes paquetes NUEVOS:
  gstreamer1.0-gtk3 libreoffice-gtk3 libreoffice-pi
0 actualizados, 3 nuevos se instalarán, 0 para eliminar y 0 no actualizados.
Se necesita descargar 1.492 kB de archivos.
Se utilizarán 2.248 kB de espacio de disco adicional después de esta operación.
¿Desea continuar? [S/n] s
I think is possible that when I installed spanish language gui these packets were broken ?¿
Regards.
