sneakybrit
Pi 4 Trouble
Thu Jul 04, 2019 3:40 pm
New Pi 4 fresh install unable to get wifi working, enter passphrase and nothing. Lan only transferring at 11mb/s to a powered USB 3 HDD. Setting resolution for my Sony Bravia to 1920 x 1080 puts menu bars off screen, have to set the res at 1360 x 768 to fit on screen.
Anyone have any solutions? cos I'm all out.
wildfire
Re: Pi 4 Trouble
Thu Jul 04, 2019 4:03 pm
Your post makes absolutely no sense.
Provide more details (though I doubt you will).
NF
sneakybrit
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:18 am
I'll try and make it simple just for you.
Pi 4 <---- This is the new one that's just come out.
Fresh install <---- This is a new install of the operating system. Keeping up? Good.
Unable to get wifi working <---- you know the voodoo, magic gizmo that lets you connect to the internet.
enter passphrase and nothing. <----- I enter my password for voodoo, magic gizmo but nothing happens.
Lan <--- wired version of voodoo, magic gizmo to connect to the internet.
transferring at 11mb/s <---- move file from one place to another at said speed.
powered USB 3 HDD <---- Hard drive connected via USB 3 with power.
Setting resolution for my Sony Bravia to 1920 x 1080 puts menu bars off screen, have to set the res at 1360 x 768 to fit on screen <---- resolution of the TV with name and model.
I hope this helps you in your quest to understand.
B.Goode
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:27 am
New Pi 4 fresh install unable to get wifi working, enter passphrase and nothing. Lan only transferring at 11mb/s to a powered USB 3 HDD. Setting Resolution for my Sony Bravia to 1920 x 1080 puts menu bars off screen, have to set the res at 1360 x 768 to fit on screen.
So to clarify, this is three separate problems in one paragraph?
In respect of the first: have you set an appropriate locale for your installed Operating System, or taken other steps to see that the wlan interface has a working Country Code?
For the second: how is the external hard drive exposed to the cabled Lan? Could the speed be being limited by some filesharing software somewhere on the path?
No comment on the third.
HawaiianPi
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:37 am
Turn off overscan in the TV settings for the HDMI input you are using. I believe Sony calls it Full-Pixel mode (if I recall correctly).
sneakybrit
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:42 am
Just fixed the overscan.
Thanks for the reply.
sneakybrit
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:47 am
Yep...had a lot on yesterday when I posted so it was throw everything in. All settings for the wifi are correct, just checked.
I have my pi connected via wire to the router, I have a 3.5 powered USB 3 HDD connected to the USB 3, when I transfer something from my PC to the HDD on the pi I just get 11mb/s speed.
Overscan sorted.
HawaiianPi
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:53 am
For your WiFi troubles, have you used the configuration tool to set your location and country code?
Does cat /etc/wpa_supplicant/wpa_supplicant.conf return something similar to this (with the correct country code)?
update_config=1
country=GB
network={
	ssid="WiFi SSID"
	psk="WPA/WPA2 passphrase"
	key_mgmt=WPA-PSK
Also, make sure your keyboard settings are correct in Localisation Options (otherwise you might not be typing what you think).
gkreidl
Re: Pi 4 Trouble
Fri Jul 05, 2019 9:54 am
Looks like a 100 MBit connection.
Minimal Kiosk Browser (kweb)
sneakybrit
Re: Pi 4 Trouble
Fri Jul 05, 2019 10:02 am
update_config=1
country=GB
network={
	ssid="WiFi SSID"
	key_mgmt=WPA-PSK
No such file or directory. I found it manually and checked and everything looks spot on. Rebooted now the wifi is saying no wireless interface...checked the wpa_supplicant.conf again and its gone. Think I'll re-install the OS again.
sneakybrit
Re: Pi 4 Trouble
Fri Jul 05, 2019 10:35 am
Right. A fresh install and from the setup it will not connect the wifi. Skipped past that part and tried again after the reboot. Nothing, just doesn't do anything. I do believe the wifi doesn't work on my board. The wpa_supplicant.conf is there with the correct SSID and pass phrase.
pik33
Re: Pi 4 Trouble
Fri Jul 05, 2019 10:40 am
I have a USB3 SSD which also works at 11 Mbps (1.1 MB/s transfer) when connected to USB3, while working normally on USB2. I posted another topic with detailed dmesg report.
