High temperatures on Raspberry Pi 4 running only Pi-hole
Posted: Thu Jul 04, 2019 4:03 am
by yslupdates
Hello my RPi 4 1GB is averaging about 70C while only running Pihole. I'm on Raspbian Buster Lite.
sudo vcgencmd measure_temp
temp=70.0'C
uptime
21:01:57 up 57 min,  1 user,  load average: 0.05, 0.15, 0.09
Is there anyway to reduce these temperatures?
Re: High temperatures on Raspberry Pi 4 running only Pi-hole
Posted: Thu Jul 04, 2019 4:44 am
by Yukon Cornelius
temp=70.0'C
uptime
That certainly seems high for Pihole .
For comparison , I'm seeing 41'C on a Pi ZeroW.
As someone else has mentioned on this forum ....
with a new OS version running on newly released hardware , it's important to isolate one of
those factors , to get some insight into what's cooking .
As soon as I saw the Pi4 4GB I thought ..... "Do I want it ? " .... YES !
"Do I need it ? " .... NO , not immediately anyway
All of these reports of high running temperatures make me want to hold off for a while .
I've read that firmware updates are already in the pipeline .
Posted: Thu Jul 04, 2019 5:02 am
by miraceti
I was having similar heat problems with PiHole and solved it by fitting a heat sink. There are a number on the market but get one with long cooling fins. I also leave the top of the case off and have a small 12V 80mm case fan running at 5V, mounted beside the Pi and I get 28 Deg C with an ambient temperature of 25 Deg C. Hope that helps
Posted: Thu Jul 04, 2019 9:46 am
by Yukon Cornelius
Just out of interest ..... can you recall what temperature the Pihole was running at
before fitting the heatsink and fan ?
