RiccardOne
Mail on Buster
Sun Jun 30, 2019 7:34 am
On a fresh installed Buster OS on a Raspi zero I can't send mail, I get this error:
mail: cannot send message: Process exited with a non-zero status
On a Raspi zero with Stretch and the same mail configuration the mail works.
Anybody has the same issue? suggestions?
Riccardo
Here is my setup:
Loading the packages
sudo apt-get install ssmtp
sudo apt-get install mailutils mpack
Setting up the defaults for SSMTP
sudo nano /etc/ssmtp/ssmtp.conf
1. Now edit the fields:
root=postmaster
mailhub=smtp.gmail.com:587
hostname=rpi0c
AuthUser=[email protected]
AuthPass=userpass
FromLineOverride=YES
UseSTARTTLS=YES
Using Email Now
sudo reboot
echo "sample text" | mail -s "Subject" [email protected]
pcmanbob
Re: Mail on Buster
Sun Jun 30, 2019 9:07 am
Yes SSMTP does not seem to work on buster, but I can send email using the same gmail credentials using smtplib in a python program, So there must be an incomparability with SSMTP or one of it dependants in buster, but I have no idea what.
HMo
Re: Mail on Buster
Sun Jun 30, 2019 1:44 pm
I have made the same observations with Debian / Raspbian – Buster and ssmtp.
Then, I have followed this Wiki Ubuntu about msmtp
https://doc.ubuntu-fr.org/msmtp and
https://doc.ubuntu-fr.org/tutoriel/comm ... e_commande.
Reboot and tested with mail like this :
echo 'message' | mail [email protected]
I could reuse my programs without changes.
harisb
Re: Mail on Buster
Fri Jul 05, 2019 3:59 pm
Below are my own observations, in case they can help.
I added DEBUG=YES in ssmtp.conf and examined the differences in /var/etc/mail.log
between two identically configured raspberry boxes. In both boxes ssmtp was configured
to send email via gmail.
- Box A with raspberry stretch (ssmtp working ok)
- Box B with raspberry buster (ssmtp not working)
I observed that after trying to send an email from both boxes,
in Box A (the mail went through ok) I had the following log line in mail.log:
SSL connection using RSA_AES_128_CBC_SHA1
In Box B (sending the mail failed) the above log line had been replaced with:
SSL connection using ECDHE_RSA_AES_256_GCM_SHA384
So, it seams that, in buster, ssmpt tries to use a different ciffer.
pcmanbob
Re: Mail on Buster
Sun Jul 07, 2019 11:26 am
Thanks HMo for the links
got my pi email working on buster , with a bit of help from google translate.
:D :D :D :D :D
paulv
Re: Mail on Buster
Wed Jul 10, 2019 1:03 pm
Just to follow-up on the previous posts, ssmtp is deprecated on Buster, it is no longer maintained.
(typical experience with a major system change..., sigh!)
The more modern and supported alternative is msmtp.
You can install that package with:
sudo apt-get install msmtp msmtp-mta
The configuration file is located here : /etc/msmtprc
Strangely enough, it is empty with no clues, which is different from the good old ssmtp.conf file.
However, there is a very large description with details if you use
man msmtp
For gmail accounts, these are the specific elements you should put into /etc/msmtprc:
# Generics
defaults
auth           on
tls            on
# following is different from ssmtp:
tls_trust_file /etc/ssl/certs/ca-certificates.crt
# user specific log location, otherwise use /var/log/msmtp.log, however,
# this will create an access violation if you are user pi, and have not changes the access rights
logfile        ~/.msmtp.log
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
from          [email protected]
user           [email protected]
password       your-gmail-account-password
# Default
account default : gmail
You can test this with:
echo 'your message' | msmtp [email protected]
I have not yet found a way to set the subject, there is no -s flag either.
However, if you also install mailutils:
Then these two work again:
echo 'message' | mail -s "raspi-buster" [email protected]
echo 'message' | sendmail [email protected]
Unfortunately, my watchdog setup nor cron get the mail out. From the error message in /var/log/mail.err it seems that there is an incompatibility with this setup, and the previously established mail setup.
Hopefully somebody that is more adept can help out to get this fixed.
Hope this helps to get mail going on buster.
Enjoy!
pcmanbob
Re: Mail on Buster
Wed Jul 10, 2019 1:15 pm
You can use both mailutils and mpack with msmtp just as you did with ssmtp.
So any scripts that you have used before with ssmtp, mailutils or mpack will work just the same using msmtp, mailutils or mpack
paulv
Re: Mail on Buster
Wed Jul 10, 2019 2:46 pm
pcmanbob,
Did you try to get mails out from cron or watchdog?
pcmanbob
Re: Mail on Buster
Wed Jul 10, 2019 2:59 pm
I have several pi's sending emails using cron and also had error messages from cron, if you set up the mailto line in cron, seeing as I am using mail or mpack to send mail from cron I don't see why it should not work with msmtp in exactly the same way.
I would normally just write a short bash script to send the email with what ever information is required
( for example the current IP address of the pi ) and then just call that using cron,
not forgetting that cron runs early in the boot process so if sending email at boot you need to add a delay before trying to send the email to allow networking to be up.
I have never used watchdog so can't comment on that.
epoch1970
Re: Mail on Buster
Thu Jul 11, 2019 8:12 pm
In case it helps. This comes from a Jessie machine working in the field with msmtp as mailer.
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 8.0 (jessie)
Release:	8.0
Codename:	jessie
$ msmtp --version
msmtp version 1.4.32
Platform: arm-unknown-linux-gnueabihf
TLS/SSL library: GnuTLS
Authentication library: GNU SASL
Supported authentication methods:
plain scram-sha-1 cram-md5 external digest-md5 login ntlm
IDN support: enabled
NLS: enabled, LOCALEDIR is /usr/share/locale
Keyring support: none
System configuration file name: /etc/msmtprc
User configuration file name: /root/.msmtprc
Copyright (C) 2014 Martin Lambers and others.
/etc/aliases: /etc/msmtprc:
$ cat /etc/msmtprc
# Accounts will inherit settings from this section
defaults
auth on
tls on
tls_certcheck off
# tls_trust_file  /etc/ssl/certs/ca-certificates.crt
logfile /var/log/msmtp.log
aliases /etc/aliases
# A first gmail address
account admin_mail
host smtp.gmail.com
port 587
# App password for this host
# Defined by user randomuser in their G account prefs
# (login to G and add other machines/apps)
password tokengeneratedbygmailforthisapp
# Add more accounts if you want
# Set a default account
account default : admin_mail
The machine has linux watchdog installed and basically the machine (watchdog) sends at least an email per day. I will post a few bits of possibly relevant config in paulv's thread on watchdog. Nothing much.
HTH
paulv
Re: Mail on Buster
Fri Jul 12, 2019 11:35 am
Epoch1970,
Your help is very much appreciated. Merci bien!
First off, I found that you have to use the TLS method the way I used it above, if I use it without as you have, there is an error generated.
With your other information, I think I found the problem with Buster.
There is no /etc/aliases file.
A default installation on one of my Jessie RPi's produces this:
# /etc/aliases
mailer-daemon: postmaster
postmaster: root
nobody: root
hostmaster: root
usenet: root
news: root
webmaster: root
www: root
ftp: root
abuse: root
noc: root
security: root
So on Buster, the system has no idea where to send stuff to.
Oversight or bug?
To test this, I added the above entries to /etc/aliases, and as a last line: To cron I added this:
MAILTO=root
17 14 * * * /bin/sh /home/pi/whatever
Just set your own time instead of 17 14, and this will trigger an email to be sent by cron coming from [email protected] because /home/pi/whatever does not exist. You could also use BTW, I still can't get the watchdog package to mail, or log...
epoch1970
Re: Mail on Buster
Fri Jul 12, 2019 5:36 pm
Oversight or bug?
I tend to port working recipes from machine to machine until it breaks, my encounter with msmtp occurred many years ago.
If you lookup the list of files provided by packages msmtp or msmtp-mta you can find /usr/sbin/sendmail and newaliases (in msmtp-mta) but a template for /etc/aliases is nowhere to be found.
I don't know which package provides /etc/aliases on Debian, if any. Not sendmail-base, as far as I can see. Perhaps some greybeards made an executive decision...
Daddyfix
Re: Mail on Buster
Sun Aug 11, 2019 11:19 pm
man msmtp
# Generics
defaults
auth           on
tls            on
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
# Default
Enjoy!
Thank you. This worked like a charm for me!
Aroa
Re: Mail on Buster
Tue Sep 03, 2019 10:34 am
Hello Im new in this world, I have a rapsberry pi3 with debian y want to send email.
I followed this steps :
man msmtp
# Generics
defaults
auth           on
tls            on
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
# Default
Enjoy!
but return to me [email protected]:~ $ sudo echo 'your message' | msmtp [email protected]
msmtp: /home/pi/.msmtprc: contains secrets and therefore must have no more than user read/write permissions
I give the permision with chmon 777 /home/pi/.msmtprc
[email protected]:~ $ ls -l /home/pi/.msmtprc
-rwxrwxrwx 1 pi pi 1378 Sep 2 18:11 /home/pi/.msmtprc
But the problem is still.
Can somebody help me please?
Thank you so much
pcmanbob
Re: Mail on Buster
Tue Sep 03, 2019 1:36 pm
Thank you so much
Hi.
So first question is why are you using " sudo " to call your send mail line ?
You don't need sudo you can send it as the pi user.
Secondly you are getting the message about user permissions because you should only have one user who can read/write the config file for msmtp, so you should be using chmon 700 /home/pi/.msmtprc so that only the pi user has read/write access to the config file.
As always read the error message it tells you what the problem is " contains secrets and therefore must have no more than user read/write permissions "
If you want msmtp to be usable by all users then you need to put the config file in " /etc " and not " /home/pi/ "
Aroa
Re: Mail on Buster
Tue Sep 03, 2019 2:55 pm
Thank you so much
Hi.
Thank you so much. It is solve
You are right, i didnt need sudo before.
i change chmon 700 /home/pi/.msmtprc and also i move the config file in "/etc"
Everything is working great!!!! Thanks :D :D :D :D :D
turbo2ltr
Re: Mail on Buster
Sun Feb 16, 2020 12:36 am
Some additional info for people that find this.
msmtp is expecting a fully formatted complete email with RFC5322 compliant headers. (which is why there is no option to set a subject)
I use a line similar to this in a script called by a cron to send an alert email.
printf "To: [email protected]\nFrom: ProperName <[email protected]>\nSubject: This is my subject\n\nThis is my message" | msmtp [email protected]
RDK
Re: Mail on Buster
Sun Feb 23, 2020 8:19 am
For those that arrive here in trying to setup MSMTP for e-mail on Buster. I have it running on several Buster Pi's (B+, 3B+ and 4B) after following much of the information in this thread and some other research.
Here are my config files:
/etc/msmtprc
defaults
auth           on
tls            on
# this will create an access violation if you are user pi, and have not changes$
#logfile        ~/.msmtp.log
logfile         /var/log/msmtp/msmtp.log
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
password      my#@%$*pw
# Default
and
/etc/aliases
# Send root to
root: [email protected]
# Send cron to
cron: [email protected]
# Send everything else to
default: [email protected]
The following works to email a message:
 echo "MSMTP Test Messsage" | mail -s "MSmpt Msg" [email protected]
One thing I have noticed which is different from SSMTP on my other Pi's/OS's is that before when the e-mal arrived the FROM displayed both the e-mail address ([email protected]) AND the "friendly name" which g-mail associated with that address, ie "Sam Smith <[email protected]> ". Now usng MSMTP what I get is this "<[email protected]", but no "friendly name". I'm not aware of anything I did special with SSMTP. Can anyone suggest how I can again get the "friendly name"?
Thanks....RDK
pcmanbob
Re: Mail on Buster
Sun Feb 23, 2020 12:43 pm
Looking at the mail log you should find that when using the mail command to send mail with msmtp that the FROM address is actually set to [email protected] , so for example one of my pi this is " [email protected] "
But for some reason Gmail just seems to ignore this when using msmtp, I have even tried using the -F option to change the FROM to something else using the msmtp command to send mail directly and even though the FROM is changed to what ever I set it to, it never appears on the email.
I have tried lots of examples I found on the web and non have worked when using msmtp , mail or mpack to send emails , some even broke the email so it would not send.
So it seems to me that using msmtp with a Gmail account you are stuck with the From just containing " [email protected]([email protected]) "
If I ever find a way I will of course post it here.
edit.....
I have also found that when using smtplib to send mail directly from a python program even though the FROM is set to something other than the email address Gmail still only displays the From just containing " [email protected]([email protected]) "
RDK
Re: Mail on Buster
Sun Feb 23, 2020 3:11 pm
PCMANBOB.....Thanks, I'll stop looking and worrying about it....RDK
witty
Re: Mail on Buster
Tue Apr 28, 2020 11:15 pm
get rid of access violation for /var/log/msmtp.log:
sudo touch /var/log/msmtp.log
sudo chown mail:mail /var/log/msmtp.log
sudo chmod 660 /var/log/msmtp.log
adduser pi mail
#log out and in again, to make new group-membership effective
receive emails from cron:
add the following line to your crontab receive emails from watchdog:
add the following line to your watchdog.sh
petike779
Re: Mail on Buster
Sat May 02, 2020 10:23 am
Hi guys
I am struggling to get working this email sending On Pi4.
First of all on my buster I don't have this 2 files: /etc/msmtprc and /etc/aliases
I followed the installation, was successful.
[email protected]:/ $ lsb_release -a
Description:	Raspbian GNU/Linux 10 (buster)
Release:	10
Codename:	buster
[email protected]:/ $ msmtp --version
msmtp version 1.8.3
plain scram-sha-1 external gssapi cram-md5 digest-md5 login ntlm
User configuration file name: /home/pi/.msmtprc
Really stucked because I don't know what I am doing wrong...
Please advice.
Thanks , Peter
pcmanbob
Re: Mail on Buster
Sat May 02, 2020 12:10 pm
You did nothing wrong , you have to create these 2 files using a simple file editor like nano, putting in the required information for your particular email account.
petike779
Re: Mail on Buster
Sun May 03, 2020 8:14 am
Thank you.....
After changing write permission and creating the 2 files working nice. Tested with:
Mail is sent successfully
Thank you for your advice
Peter
Chenko
Re: Mail on Buster
Tue May 26, 2020 9:05 am
man msmtp
# Generics
defaults
auth           on
tls            on
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
# Default
Enjoy!
hello i tried this but it did not work for me i dont know if its a mistake i made or how but i need help
i get this error wen i try to test it.
msmtp: authentication failed (method PLAIN)
msmtp: server message: 535-5.7.8 Username and Password not accepted. Learn more at
msmtp: server message: 535 5.7.8 https://support.google.com/mail/?p=BadCredentials h7sm503835wml.24 - gsmtp
msmtp: could not send mail (account default from /etc/msmtprc)
