RiccardOne
Mail on Buster
Sun Jun 30, 2019 7:34 am
On a fresh installed Buster OS on a Raspi zero I can't send mail, I get this error:
mail: cannot send message: Process exited with a non-zero status
On a Raspi zero with Stretch and the same mail configuration the mail works.
Anybody has the same issue? suggestions?
Riccardo
Here is my setup:
Loading the packages
sudo apt-get install ssmtp
sudo apt-get install mailutils mpack
Setting up the defaults for SSMTP
sudo nano /etc/ssmtp/ssmtp.conf
1. Now edit the fields:
root=postmaster
mailhub=smtp.gmail.com:587
hostname=rpi0c
AuthUser=[email protected]
AuthPass=userpass
FromLineOverride=YES
UseSTARTTLS=YES
Using Email Now
sudo reboot
echo "sample text" | mail -s "Subject" [email protected]
pcmanbob
Re: Mail on Buster
Sun Jun 30, 2019 9:07 am
Yes SSMTP does not seem to work on buster, but I can send email using the same gmail credentials using smtplib in a python program, So there must be an incomparability with SSMTP or one of it dependants in buster, but I have no idea what.
HMo
Re: Mail on Buster
Sun Jun 30, 2019 1:44 pm
I have made the same observations with Debian / Raspbian – Buster and ssmtp.
Then, I have followed this Wiki Ubuntu about msmtp
https://doc.ubuntu-fr.org/msmtp and
https://doc.ubuntu-fr.org/tutoriel/comm ... e_commande.
Reboot and tested with mail like this :
echo 'message' | mail [email protected]
I could reuse my programs without changes.
harisb
Re: Mail on Buster
Fri Jul 05, 2019 3:59 pm
Below are my own observations, in case they can help.
I added DEBUG=YES in ssmtp.conf and examined the differences in /var/etc/mail.log
between two identically configured raspberry boxes. In both boxes ssmtp was configured
to send email via gmail.
- Box A with raspberry stretch (ssmtp working ok)
- Box B with raspberry buster (ssmtp not working)
I observed that after trying to send an email from both boxes,
in Box A (the mail went through ok) I had the following log line in mail.log:
SSL connection using RSA_AES_128_CBC_SHA1
In Box B (sending the mail failed) the above log line had been replaced with:
SSL connection using ECDHE_RSA_AES_256_GCM_SHA384
So, it seams that, in buster, ssmpt tries to use a different ciffer.
pcmanbob
Re: Mail on Buster
Sun Jul 07, 2019 11:26 am
Thanks HMo for the links
got my pi email working on buster , with a bit of help from google translate.
:D :D :D :D :D
paulv
Re: Mail on Buster
Wed Jul 10, 2019 1:03 pm
Just to follow-up on the previous posts, ssmtp is deprecated on Buster, it is no longer maintained.
(typical experience with a major system change..., sigh!)
The more modern and supported alternative is msmtp.
You can install that package with:
sudo apt-get install msmtp msmtp-mta
The configuration file is located here : /etc/msmtprc
Strangely enough, it is empty with no clues, which is different from the good old ssmtp.conf file.
However, there is a very large description with details if you use
man msmtp
For gmail accounts, these are the specific elements you should put into /etc/msmtprc:
# Generics
defaults
auth           on
tls            on
# following is different from ssmtp:
tls_trust_file /etc/ssl/certs/ca-certificates.crt
# user specific log location, otherwise use /var/log/msmtp.log, however,
# this will create an access violation if you are user pi, and have not changes the access rights
logfile        ~/.msmtp.log
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
from          [email protected]
user           [email protected]
password       your-gmail-account-password
# Default
account default : gmail
You can test this with:
echo 'your message' | msmtp [email protected]
I have not yet found a way to set the subject, there is no -s flag either.
However, if you also install mailutils:
Then these two work again:
echo 'message' | mail -s "raspi-buster" [email protected]
echo 'message' | sendmail [email protected]
Unfortunately, my watchdog setup nor cron get the mail out. From the error message in /var/log/mail.err it seems that there is an incompatibility with this setup, and the previously established mail setup.
Hopefully somebody that is more adept can help out to get this fixed.
Hope this helps to get mail going on buster.
Enjoy!
pcmanbob
Re: Mail on Buster
Wed Jul 10, 2019 1:15 pm
You can use both mailutils and mpack with msmtp just as you did with ssmtp.
So any scripts that you have used before with ssmtp, mailutils or mpack will work just the same using msmtp, mailutils or mpack
paulv
Re: Mail on Buster
Wed Jul 10, 2019 2:46 pm
pcmanbob,
Did you try to get mails out from cron or watchdog?
pcmanbob
Re: Mail on Buster
Wed Jul 10, 2019 2:59 pm
I have several pi's sending emails using cron and also had error messages from cron, if you set up the mailto line in cron, seeing as I am using mail or mpack to send mail from cron I don't see why it should not work with msmtp in exactly the same way.
I would normally just write a short bash script to send the email with what ever information is required
( for example the current IP address of the pi ) and then just call that using cron,
not forgetting that cron runs early in the boot process so if sending email at boot you need to add a delay before trying to send the email to allow networking to be up.
I have never used watchdog so can't comment on that.
epoch1970
Re: Mail on Buster
Thu Jul 11, 2019 8:12 pm
In case it helps. This comes from a Jessie machine working in the field with msmtp as mailer.
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 8.0 (jessie)
Release:	8.0
Codename:	jessie
$ msmtp --version
msmtp version 1.4.32
Platform: arm-unknown-linux-gnueabihf
TLS/SSL library: GnuTLS
Authentication library: GNU SASL
Supported authentication methods:
plain scram-sha-1 cram-md5 external digest-md5 login ntlm
IDN support: enabled
NLS: enabled, LOCALEDIR is /usr/share/locale
Keyring support: none
System configuration file name: /etc/msmtprc
User configuration file name: /root/.msmtprc
Copyright (C) 2014 Martin Lambers and others.
/etc/aliases: /etc/msmtprc:
$ cat /etc/msmtprc
# Accounts will inherit settings from this section
defaults
auth on
tls on
tls_certcheck off
# tls_trust_file  /etc/ssl/certs/ca-certificates.crt
logfile /var/log/msmtp.log
aliases /etc/aliases
# A first gmail address
account admin_mail
host smtp.gmail.com
port 587
# App password for this host
# Defined by user randomuser in their G account prefs
# (login to G and add other machines/apps)
password tokengeneratedbygmailforthisapp
# Add more accounts if you want
# Set a default account
account default : admin_mail
The machine has linux watchdog installed and basically the machine (watchdog) sends at least an email per day. I will post a few bits of possibly relevant config in paulv's thread on watchdog. Nothing much.
HTH
paulv
Re: Mail on Buster
Fri Jul 12, 2019 11:35 am
Epoch1970,
Your help is very much appreciated. Merci bien!
First off, I found that you have to use the TLS method the way I used it above, if I use it without as you have, there is an error generated.
With your other information, I think I found the problem with Buster.
There is no /etc/aliases file.
A default installation on one of my Jessie RPi's produces this:
# /etc/aliases
mailer-daemon: postmaster
postmaster: root
nobody: root
hostmaster: root
usenet: root
news: root
webmaster: root
www: root
ftp: root
abuse: root
noc: root
security: root
So on Buster, the system has no idea where to send stuff to.
Oversight or bug?
To test this, I added the above entries to /etc/aliases, and as a last line: To cron I added this:
MAILTO=root
17 14 * * * /bin/sh /home/pi/whatever
Just set your own time instead of 17 14, and this will trigger an email to be sent by cron coming from [email protected] because /home/pi/whatever does not exist. You could also use
MAILTO="your-email-address[email protected]"
BTW, I still can't get the watchdog package to mail, or log...
epoch1970
Re: Mail on Buster
Fri Jul 12, 2019 5:36 pm
Oversight or bug?
I tend to port working recipes from machine to machine until it breaks, my encounter with msmtp occurred many years ago.
If you lookup the list of files provided by packages msmtp or msmtp-mta you can find /usr/sbin/sendmail and newaliases (in msmtp-mta) but a template for /etc/aliases is nowhere to be found.
I don't know which package provides /etc/aliases on Debian, if any. Not sendmail-base, as far as I can see. Perhaps some greybeards made an executive decision...
Daddyfix
Re: Mail on Buster
Sun Aug 11, 2019 11:19 pm
man msmtp
# Generics
defaults
auth           on
tls            on
# Gmail specifics
account        gmail
host           smtp.gmail.com
port           587
# Default
Enjoy!
Thank you. This worked like a charm for me!
