grahambb
Networking after Buster upgrade
Sat Jun 29, 2019 9:24 pm
I upgrade a Pi 3B to buster successfully, but after a reboot wlan0 is not connected.
In checking the properties, I'm offers a long list of options none of which seem appropriate. MY network uses WPA2 PSK AES, which of the many options in Wicd is appropriate?
Cheers
PhatFil
Re: Networking after Buster upgrade
Sat Jun 29, 2019 10:12 pm
set up wifi via the cli
sudo raspi-config
grahambb
Sun Jun 30, 2019 1:17 pm
Thanks!
When I use rasps-config, the networking option reports 'Could not communicate with wpa_supplicant.'
Sun Jun 30, 2019 4:14 pm
Thanks!
https://www.raspberrypi.org/documentati ... /README.md
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
grahambb
Sun Jun 30, 2019 6:39 pm
For anyone with a similar problem that needs ACTUAL help, it turns out that rfkill was somehow set on the wlan.
I unset it and all is well.
cflyer185
Tue Jul 02, 2019 2:33 am
Please explain how one tells if rfkill is on and how it is turned off. Thankyou.
PhatFil
Tue Jul 02, 2019 2:44 pm
I suspect the quickest solution would be to follow the currently recommended path by using a fresh buster image download and installing any supported systems needed for your application.
grahambb
Tue Jul 02, 2019 3:32 pm
@cflyer185 I discovered the issue by digging on DuckDuckGo. I issued the command 'rfkill list all' and I could see all interfaces. After digging a bit more there is a switch in the guy wireless setup that I had missed.
@PhatPhill, I agree if you don't have an extant system, or you're happy to rebuild everything. Not my situation :-)
Cheers
