Buster won't boot headless with the Sense Hat attached
Posted: Fri Jun 28, 2019 12:49 pm
by tgwena
Hello all,
I have a raspberry Pi 3B+ with a sense hat attached. I installed buster on a new card (enabled ssh) and it boots up with no problems if it is attached to a display. When I try to boot headlessly the Hat just lights up the rainbow and stays that way. The Pi does not seem to boot up. With the Hat off it boots headlessly and is accessible via ssh.
I have repeated this with a second sd card and on the Pi 3B+ and 2B. I have tried disabling the splash screen and graphical boot to no avail.
How can I fix this? Thanks.
Re: Buster won't boot headless with the Sense Hat attached
Posted: Sat Jun 29, 2019 10:31 am
by pista24
I have RPI 4 and have the same problem with Sense Hat. I spent hours on it.
Why there is no testing before launch?
Posted: Mon Jul 01, 2019 7:57 pm
by TaseG
Same thing here - I'm using a RPi 3B+ with a SenseHat attached. It won't boot Buster in headless mode, it'll only boot with a display connected. Also tried disabling splash screen and using the legacy OpenGL driver, to no avail - the Sense LED Matrix stays lit up, just like it would if I would not have any SD card inserted.
This is really annoying, I'm hoping a future packaging of Buster will fix this.
Posted: Mon Jul 01, 2019 10:40 pm
by Josema
Same thing here with Sense Hat + RPi 3B+ :(
Posted: Sun Jul 14, 2019 4:11 pm
by PawelJalocha
Exactly same issue with the first (single-core) Raspberry PI, flashed SD card with Buster Lite, created ssh in boot and not able to login with ssh: connection refused.
Posted: Sun Jul 14, 2019 5:05 pm
by rpdom
Which sounds like a completely different issue. If the Pi hadn't booted you would get "No route to host", not "Connection refused". That sounds more like the Pi has booted and got stuck - or ssh isn't enabled for some reason.
Do you have a Sense HAT attached to the Pi?
Posted: Wed Jul 17, 2019 7:27 pm
by Heimetli
Same problem here: buster does not start with sensehat and no hdmi monitor.
The sensehat shows the colored startup image forever and I can't connect with ssh.
Setup: Raspberry 3 and a recent sensehat
A previous version of Raspbian starts without a hitch.
Posted: Wed Jul 24, 2019 10:15 am
by pbp
I had the same problem with buster RPi 4B. Doing:
$raspi-config
7 Advanced Options
A5 Resolution
DMT Mode 4 640x480 60Hz 4:3
solves the problem. Tested with:
- RPi4B
- 2019-07-10-raspbian-buster
- 2019-07-10-raspbian-buster-lite
Source: https://github.com/RPi-Distro/python-se ... /issues/96
Posted: Sun Jul 28, 2019 7:30 pm
by FL00DY
I just updated to Buster with the SenseHat. Tried this resolution fix, still not display. Is there any other fix out there?
Posted: Sat Aug 31, 2019 7:00 am
by ByteYourLife
Hi all,
same problem here with a Raspberry Pi 4 and a Sense HAT. I am using the latest buster image "2019-07-10-raspbian-buster-full.img".
My solution was to edit the /boot/config.txt.
I removed the "#" in front of the line "hdmi_force_hotplug=1" and now the Raspberry Pi is booting attached with the SenseHAT.
Best,
ByteYourLife
Posted: Thu Sep 05, 2019 9:01 am
by ppl4world
Hi, I tried all posted remedies (setting screen size in raspi-config and changing changing config.txt) yet to no avail (tried all the usual checks like I2C turned on etc)
Using RPi3 B+ and Sense Hat.
The boot process gets stuck with the rainbow color pattern on the Sense Hat.
I tried two different Pi's and two different Sense Hats.
Same problem.
Any further ideas?
Posted: Fri Sep 06, 2019 11:58 pm
by ppl4world
[SOLVED for me]
I had set-up the Pi with a WaveShare TFT display. I started from a fresh build without installing the touch screen drivers or setting the screen display ratio.
When using the previous Raspbian version it works now. Will try with Buster maybe later and see if that works also.
Posted: Sun Sep 08, 2019 9:48 pm
by TaseG
This seems to be working with the July 2019 version of Buster (SHA-256:9e5cf24ce483bb96e7736ea75ca422e3560e7b455eee63dd28f66fa1825db70e)
