Re: 4k 60 hz is not listed, only 30hz
Wed Aug 21, 2019 8:04 am
dangerous_dave33 wrote:
Tue Aug 20, 2019 6:03 pm
Hi there! I baught myself a new pi 4 and want to have a 4k 60Hz output.
I am using hdmi port 0 with an amazon basics hdmi to mini-hdmi 2.0 cable.
Unfortunately is only shows 30Hz- on my TV and my monitor (both capable to do 60 Hz).
I have "hdmi_enable_4kp60=1" in my config.
Does anyone have a clue what coud be wrong?
Capital K?
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
dangerous_dave33
Wed Aug 21, 2019 12:03 pm
Capital K?
I'm sorry, I don't understand?!
aBUGSworstnightmare
Wed Aug 21, 2019 12:13 pm
Jamesh wants to know if your typing in config.txt is correct.
have a look here for details https://www.raspberrypi.org/documentati ... tom%20Mode
What's the output for 'tvservice -m DMT'?
dangerous_dave33
Wed Aug 21, 2019 6:12 pm
Ah, thanks! :D
I did a clean installation and added the code with "sudo raspi-config", it now shows at the bottom of config.txt:
# NOOBS Auto-generated Settings:
hdmi_force_hotplug=1
hdmi_enable_4kp60=1
gpu_mem=256
My output for 'tvservice -m DMT' is:
[email protected]:~ $ sudo tvservice -m DMT
Group DMT has 5 modes:
           mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
           mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
           mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
           mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
           mode 39: 1360x768 @ 60Hz 16:9, clock:85MHz progressive
Many thanks in advance!
drgeoff
Wed Aug 21, 2019 6:36 pm
Something amiss there as the RPi4B has micro-HDMI sockets, not mini- ones.
aBUGSworstnightmare
Wed Aug 21, 2019 6:58 pm
Ah, thanks! :D
hdmi_enable_4kp60=1
gpu_mem=256
from that output your TV or monitor doesn't support 4k resolution.
dangerous_dave33
Wed Aug 21, 2019 8:45 pm
my mistake, of course i wanted to write micro hdmi
dangerous_dave33
Wed Aug 21, 2019 8:49 pm
then I misapplied the command or something wrong is displayed.
These are definitely 4k display devices.
I even get 4k output - only with 30 Hz.
pota
Mon Sep 09, 2019 8:22 am
Hi guys, I have the same problem with my raspberry, and I'm lookin for some help.
I have a pi 4 4gb, official hdmi raspberry cable, my TV is an LG55B8.
I plugged the hdmi connector 0, the closest from the power supplier, and enable 4k60 (but just to be sure, I have to add :
# hdmi_enable_4kp60=1
in a new line on the config.txt right? (noob here)
and with all these things, I can't see 60hz in the screen layer window.... Any help will be highly aprreciated!
Mon Sep 09, 2019 8:43 am
Take the # off the start, that makes the line a comment and ignored.
pota
Mon Sep 09, 2019 9:48 am
Well.... it did work perfectly without the # !!! thanks a lot, that was so simple! :D
Dashrendar2507
Wed Nov 20, 2019 9:07 pm
Same thing happens for me on my TCL 55R617. Enabled 4kp60 but I still only see 30hz in the display settings. I'm not extremely knowledgeable when it comes to adding display modes and such, so would someone have a suggestion?
Ps. I'd settle for 1440p60, but I don't know how to add that to my display modes...
Kendek
Thu Nov 21, 2019 10:08 am
Check your TV's user manual, page 120. Select the HDMI 2.0 mode.
Dashrendar2507
Sat Nov 23, 2019 6:52 pm
Hey Kendek, thanks a lot! I'm pretty sure it was already in that mode but I tried again and it worked! Thanks again.
Now, that might be unrelated but I'm trying to get Parsec to work on the Pi 4. I'm getting a 7007 error every time. I've heard that the Parsec team are working on it. Do any of you have experience with that?
Robc66
Tue Jan 21, 2020 11:25 pm
Hi everyone, first time post here but I just ran into this problem on my new pi 4 with Hisense H50M3300 tv, it ended up being a power supply issue to the pi 4, I had to plugged into my tv usb which I guess wasn't giving it enough power....switched it over to a samsung usb plug and it worked fine. Now running 3840x2160p at 60hz. Hope this helps other people !
