goodburner
4k 60 hz is not listed, only 30hz
Fri Jun 28, 2019 7:58 am
I have a mini HDMI to HDMI cable that DOES support 60hz (https://www.amazon.com/dp/B009W9RXVO/re ... UTF8&psc=1)
But when I list out the resolution modes possible using tvservice, it does not show 60hz at all, only 30. I'm disappointed with this device. It also very barely plays 720p video on youtube, anything more is not good.
Please stop advertising it as a "desktop replacement". I have 4k
[email protected]:~ $ sudo /opt/vc/bin/tvservice -m DMT
Group DMT has 8 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 28: 1280x800 @ 60Hz 16:10, clock:83MHz progressive
mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
mode 82: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 83: 1600x900 @ 60Hz 16:9, clock:108MHz progressive
mode 85: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
[email protected]:~ $ sudo /opt/vc/bin/tvservice -m CEA
Group CEA has 8 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
(native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
(prefer) mode 95: 3840x2160 @ 30Hz 16:9, clock:297MHz progressive
Re: 4k 60 hz is not listed, only 30hz
Fri Jun 28, 2019 8:41 am
Probably best to sort out the problem you are seeing before slagging us off.
Assuming you monitor does actually support it (some don't )you need to enable 4kp60, either by using the Configuration utility from the preferences menu, or by editing config.txt and adding hdmi_enable_4k=1. Note that this will increase power consumption and therefor heat, so if 4kp30 works for you, then I would recommend using that. Note, 4kp60 only available on HDMI-0.
There is a bug in Chromium that we are currently investigating which is slowing down video playback. ONce that is fixed all should be a lot better.
goodburner
Fri Jun 28, 2019 8:54 am
i'll try that and apologize for the rude tone, I just expected too much.
goodburner
Fri Jun 28, 2019 9:08 am
i updated the packages and now it wont boot, goes blank after outputting the kernel messages. wonderful, thanks.
i have a 4gb rpi 4b and 4k monitor capable of 60hz.
Fri Jun 28, 2019 9:14 am
How did you update the packages? Did you try enabling 4kp60 first?
Mark2Zero
Sun Jun 30, 2019 5:25 pm
I'm having a similar issue. I only can get [email protected] even though i have the correct cable and added hdmi_enable_4k=1 to my boot config.txt. It's hooked up to a Samsung 4k TV that can do [email protected]
Mark2Zero
Mon Jul 01, 2019 2:28 pm
Since I have a PS4 that does 4kp60 on the same TV that should mean the pi would as well?
Mon Jul 01, 2019 2:59 pm
One more thing to check, you must be using HDMI 0 to get 4kp60. Cannot remember the exact reason why, some weirdness in the HW clocks somewhere means HDMI 1 is limited to p30.
Mark2Zero
Mon Jul 01, 2019 4:05 pm
Thanks for the response but it's still a no go in hdmi 0. I tried 2 different cables but still the same result. I'll try another 4k tv tonight. Another thing to note is that I'm using a pi 3 micro usb power supply with a usb-c adapter on the end (I know it's a little underpowered). I've ordered the official one but still waiting on the mail. Could that be related?
Mon Jul 01, 2019 4:29 pm
I would not have thought so. Using HDMI 0, setting hdmi_enable_4k=1 in config.txt should be all you need to get it going. I've got a 4k Dell monitor at 4kp60 and a Dell monitor at 1920xx1200p59 (?) running in front of me right now, with just those settings.
Ashe
Mon Jul 01, 2019 5:39 pm
In the general forum topic about the Pi 4, there's been discussion about the Pi not supporting YCbCr420 at 4K 60Hz (which unfortunately my SDR 4K TV uses at 4K 60Hz - I'm still waiting for my Pi 4 currently though).
Could this could be the issue?
Mark2Zero
Tue Jul 02, 2019 3:38 am
Not sure. But my TV is SDR as well
aBUGSworstnightmare
Wed Jul 03, 2019 9:02 am
Hi jamesh,
as I cant get [email protected] running, would you mind sharing your config.txt with me? I have just made a post here https://www.raspberrypi.org/forums/view ... 7#p1491293, and the display I'm using is - let me say - similiar to what you have in front of you (sorry, can't go into details on a public forum).
Wed Jul 03, 2019 9:25 am
Hi jamesh,
The config is entirely standard. Just with the hdmi_enable_4k=1 added.
Are you sure the device supports p60? You could dump the edid using tvservice, then used decode_edid to find out what the monitor says it supports.
aBUGSworstnightmare
Wed Jul 03, 2019 10:16 am
Hi jamesh,
yes, it does! It's just as usual 'error 60'!
Stupid me connected to wrong HMDI input.
Here's the story end. Might be worth for others to check as well (if their wiring is correct) https://www.raspberrypi.org/forums/view ... 1#p1491361
popandplay
Tue Jul 23, 2019 5:13 pm
So I'm having the same problem and tried all of this and it's not working.
However, when I boot into LibreELEC it defaults to 4k60Hz and works just fine, so I know the hardware/cabling/monitor settings are all working.
Either other suggestions? Or should I just wait it out since this is all so new.
Tue Jul 23, 2019 6:19 pm
If you have set hdmi_enable_4kp60=1 in config.txt and are using the HDMI0 port, then it should just work.
Samile
Thu Aug 01, 2019 12:02 pm
Hello Guys, I have done a little help for guys cannot switch to 4K 60Hz :
https://imgur.com/a/W9fTcl2
Don't forget to put your cable on HDMI at proximity of power plug not the other one.
Enjoy.
aBUGSworstnightmare
Thu Aug 01, 2019 3:12 pm
Enjoy.
or add
hdmi_enable_4kp60=1
to your config.txt
popandplay
Thu Aug 01, 2019 5:48 pm
Tried it all again on a fresh install, no dice. Like I said though, LibreELEC boots right in to 4kp60 without changing anything.
Not sure what the problem is. I understand this is new and there’s a lot of work to be done so I’m not upset about it, still love the Pi, but it’s obviously still a problem for me.
lpsw
Thu Aug 01, 2019 9:40 pm
I've been dealing with a similar (if not identical) issue with 4kp60.
My monitor is a Samsung U28E590. Samsung says HDMI2 can push 4kp60. I could not get 4kp60 from either my Pi42M (config.txt was correct) or my Windows 10 desktop, regardless of HDMI port. I switched my Win10 box to 2560x1440 @ 60Hz, and it worked fine. Then I switched back to 3840x2160, rebooted Win10, and [email protected] Looks great.
Later when I get time I'll try the same on my Pi4.
May be unique to my monitor, but I doubt it.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
lpsw
Fri Aug 02, 2019 5:56 pm
Update: did same with Pi4 and now it's running at 4kp60.
Seems to be monitor wonkiness and not the Pi4, at least in regard to my particular monitor.
YMMV.
dangerous_dave33
Tue Aug 20, 2019 6:03 pm
Hi there! I baught myself a new pi 4 and want to have a 4k 60Hz output.
I am using hdmi port 0 with an amazon basics hdmi to mini-hdmi 2.0 cable.
Unfortunately is only shows 30Hz- on my TV and my monitor (both capable to do 60 Hz).
I have "hdmi_enable_4kp60=1" in my config.
Does anyone have a clue what coud be wrong?
Kendek
Tue Aug 20, 2019 7:34 pm
My UHD Samsung TV is only supports 60Hz (basically HDMI 2.0) if the HDMI UHD color option is enabled on the HDMI port.
dangerous_dave33
Wed Aug 21, 2019 6:02 am
I have 2 HDMI-4k-60Hz screens (Monitor ande TV), I don't there is something wrong with them. I am trying a different cable today. I am gonig to report!
