Dud
Backspace key on official keyboard not working properly?
Wed Jun 26, 2019 9:39 pm
Hi
Just set up my Pi4 with the official keyboard and mouse. All seems to be working except I notice that the backspace key only works if you press and hold it down - it doesn't seem to work if you just tap it like a normal backspace key. I notice you can do shift-backspace which then allows single taps.
Am I going mad or is this normal? It seems really inconvenient
Dud
Re: Backspace key on official keyboard not working properly?
Fri Jun 28, 2019 12:25 pm
So I guess this really just affects me then?
Andyroo
Fri Jun 28, 2019 12:28 pm
Are you sure the keyboard and language are defined correctly?
There are some odd faults in the Perl script reported elsewhere since the Pi 4 came out with Buster...
Can you try it on an older Pi by any chance?
Dud
Fri Jun 28, 2019 9:35 pm
I don't have an older Pi to try but I did try the keyboard on a windows machine and I see the same behaviour - the backpsace key does not work unless you press and hold it - you cant just tap it.
I was just curious to know if other peoples backspace key works in the normal manner?
Andyroo
Fri Jun 28, 2019 9:44 pm
That is very very odd - I’ve nit used one but hopefully someone here can tell you.
Tempted to give you this link https://m.youtube.com/watch?v=yo5WSl74ojY but it would be a bit unfair :lol:
I do agree it sounds a bit if a pain for day to day use.
d_older
Sat Jun 29, 2019 8:56 am
Hi Dud,
Just tried my UK Pi keyboard (Bus 001 Device 004: ID 04d9:0006 Holtek Semiconductor, Inc. ) on both my Pi4 and Debian i5 machine and a "tap" on the Backspace key works as expected. (Num Lock on or off - just in case it had any effect)
The usual cause of "weird" issues is the power supply - I've tried this with both the old 2.5A PSU (with a USB-C adapter) and the new 3A adapter.
I know this doesn't really help you but it is another datapoint.
Dave
