PeterO
Re: I can´t boot from usb in pi 4
Tue Jul 09, 2019 8:09 am
kyliael wrote:
Tue Jul 09, 2019 7:51 am
thagrol wrote:
Mon Jul 08, 2019 12:34 pm
Booting from USB is not a requirement of a desktop system. Neither is rotating rust or SSD storage. (lol or otherwise)
Well maybe for you, but it is definitively a requirement. And not able to boot on USB is a regression since it's working properly and natively with the Pi 3B+.
A SSD plugged on USB2 port on my Pi 3B+ is much faster than any SD card.
The Pi4 has been released like an alpha software.
I assume you'll be giving it away to someone more deserving then ?
PeterO
Gavinmc42
Tue Jul 09, 2019 8:23 am
Also when I researched small SSDs I found the small 32GB ones are now quite cheap at around £20.
Saw a 240GB SSD for $35 AUD. 16GB Intel Optane Xpoint for $25 AUD, will that work with adaptor?
These 4's are so good (er, my requirements are not very high) as a desktop, storage is now the issue.
32GB uSD is not enough.
Which is going to be more reliable booting from 128MB SLC industrial uSD or USB 3.0 Sata SSD, or USB stick?
I'm dancing on Rainbows.
jdb
Tue Jul 09, 2019 8:37 am
kyliael wrote:
Tue Jul 09, 2019 8:29 am
PeterO
Or just put in a drawer until I can update it to use it.
What's stopping you from running the root filesystem on a USB drive?
Rockets are loud.
https://astro-pi.org
HawaiianPi
Tue Jul 09, 2019 8:46 am
thagrol wrote:
Mon Jul 08, 2019 6:53 pm
Also, you should be aware of the bandwidth limitations on the 4B's USB ports: "a total of 4Gbps of bandwidth, shared between the four ports". You'll never hit the maximum possible transfer speeds of SATA III with one drive let alone two.
You won't get full SATA-III speed even on a proper USB 3.0 port (which is only 5Gbps, while SATA-III is 6). You'd need at least USB 3.1 Gen2 or USB 3.2 Gen2x1, which are capable of 10gbps.
So, yes, the Pi 4B USB 3.0 ports are gimped slightly, but they're still way faster than USB 2.0.
k-pi
Tue Jul 09, 2019 9:55 am
grayerbeard wrote:
Mon Jul 08, 2019 8:05 pm
You should find lots of 120GB SSD for less than £20. 8-)
k-pi
Tue Jul 09, 2019 10:07 am
For my money I'd much rather see the lack of boot via GPIO 3 toggle fixed, though again that might be a minor use case so I'm not holding my breath.
To be honest, I've never seen a desktop with (accessible) GPIO pins before coming to my RPi3B - but every one that I've used had a HDD or SSD & could boot from USB, (since the introduction of USB2.0). :lol:
Tue Jul 09, 2019 10:14 am
Rubbish. We did a lot of testing, internally and externally (and I am amazed there were no leaks) but when you sell 100k devices in a couple of weeks, suddenly a lot more stuff get attached, and a lot more bugs get found. This has happened for every Pi release.
The HMDI bugs - fixed. Chromium playback bug, fixed. Within 2 weeks of release. If it were Alpha software we would still be fixing them!
USB boot is not a regression, it a future feature. This is a new product. There are a number of things this one doesn't do that previous models did. Are they all regressions? No, actual choices made to remove features, or introduce them later. If we had waited for USB boot to be completed, everyone who doesn't give a damn about USB boot (most people actually) would still be waiting for it to come out - for no reason whatsoever as as it stands it does all they want. Should we have wasted a load of sales just to make sure a tiny minority of people had the feature they wanted on launch? Of course not, that would be stupid.
Tue Jul 09, 2019 10:21 am
Ha hahahahahahah. You're not going to stop whining about this are you?. So let me put you right one last time. YOU DO NOT NEED NATIVE USB BOOT FOR THE DEVICE TO BE CAPABLE OF DESKTOP TASKS. You are suffering from a cognitive bias - that because YOU want a feature, everyone else does. This is demonstrably NOT TRUE. I am using my Pi4 as a desktop RIGHT NOW, without USB boot! Most people couldn't give a rats rectum about native USB boot. And many that do, just use an SD card to get the same effect. Which, tbh is sort of how desktop PC's work - they have a bootloader in flash memory which then runs the OS from an attached device. We just have the tiny extra bit which is the SD card, which is...just a little bit more flash memory.
Last post on this subject.
gkreidl
Tue Jul 09, 2019 10:27 am
All my RPis run from HDD. But for all I have been using the "old method": Boot partition on SD, root FS on HDD.
There's a great tutorial here on the forum (for years) and everbody should be able to follow it.
https://www.raspberrypi.org/forums/view ... 29&t=44177
Minimal Kiosk Browser (kweb)
thagrol
Tue Jul 09, 2019 10:33 am
No. It's a requirement you have. It's not, and never has been, a requirement of a generic desktop system. And I'd expect the vast majority of "desktop system" user to have never needed to use this feature or even know that it exists.
Would I like USB boot to be available? Yes. I'd like network booting too.
Am I going to moan about it? No. All that would do is make me look like a petulant child with no understanding of the realities of the situation.
There are way to work around this situation. You'd be beter off spending your energy on those than on whinging on here.
Attempts to contact me outside of thes forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
Tue Jul 09, 2019 10:37 am
James has hit the nail on the head. The RPF / RP(T) folks are a small team with an incredibly big task to cure the hardware / firmware / bootcode quirks and Linux & user program software bugs in RPi4. (This is also why I'm waiting until the end of August to buy an RPI4B 4GB. Although in two weeks since the RPi4 appeared; it seems to be a very stable system.)
With a small old SDCard from that collection you've got when cameras and phones didn't do 20MPx photos (less than 256MB is needed for /boot) you can have /boot on the SD and the root filesystem on a hard drive. When the RPi4B gets the new USB boot (& PXE) feature just move the /boot to /dev/sda1 (which you've left space for) change the cmdline.txt and /etc/fstab and it will "just work".
If I were a moderator on here, I'd have stuck K-Pi in the cooler for a week for bleating about that on the forum constantly for the last fortnight.
This is a doctor free zone.
grayerbeard
Tue Jul 09, 2019 3:09 pm
I whole hearedly agree that we now have the info for an easy work around until the final boot from USB is available and also excellent advice about how to have the USB drive set up so that it will be easy to change over in the future when the normal arrangement is working.
To me also this has been an excellent example hof how well the commun ity helps each other tyop figure out how to solve probklems even when the problem is very much a miniority issue. :D
Perhaps is time to close this thread?
Tue Jul 09, 2019 3:32 pm
The instructions have been around for years - it's how its is done on all models prior to the 3B+, which is when SD cardless USB boot was added. Which is why the comments above are so frustrating.
davidcoton
Fri Jul 12, 2019 10:49 pm
kyliael wrote:
Fri Jul 12, 2019 10:24 pm
The pi3b+ can boot from usb
The pi4 can't
If that's not a regression, what's a regression then?
You're advertising the pi4 as desktop replacement... Using a Micro SD as drive. Just the worst way to run an OS.
Easy? Yes.
Cheap? Yes
Fast? No
Reliable? No
It's a non-issue. You can boot from SDCard, and transfer to root on a USB-connected drive. Like the early Pis did.
I bought a Pi4 day one.
Now I see another articles stating you will release another version of the pi4 due to USB C issue in a couple of weeks. ( a pi4 rev2 ?)
Now I don't oy feel I bought an early access Pi, I feel I've been fooled.
Will never buy a Pi again day one.. NexT time I'll wait weeks or even months to avoid to feel my ass stretched like that.
Your choice. Either you have the Pi from day 1, and risk the issues that may arise, or you wait without a Pi.
If you wait too long, you will buy the day before another version arrives.
Does the USB-C issue affect you anyway?
Signature retired
jdb
Fri Jul 12, 2019 10:53 pm
The pi4 can't
Easy? Yes.
Cheap? Yes
Fast? No
Reliable? No
Answer my question.
jdb wrote: What's stopping you from running the root filesystem on a USB drive?
Rockets are loud.
thagrol
Fri Jul 12, 2019 10:59 pm
The pi4 can't
Easy? Yes.
Cheap? Yes
Fast? No
Reliable? No
And another whiny, petulant child expecting perfection and everything handed to them on a platter with litle or no understanding of how the real world works.
The lack of USB boot is at worst a minor inconvience for a small minority of people.
The USB C thing likewise, especially as there are at least four other ways to get power into a 4B (via GPIO, via a "dumb" USB C cable, via a micro USB PSU with suitable USB C adaptor, via the PoE HAT).
Neither of this issues have life threatening consequences. Much bigger companies have made similar or much worse oversights at launch.
Here's two that could kill you and/or destroy your property:
https://en.wikipedia.org/wiki/Ford_Pint ... litigation
https://www.independent.co.uk/news/busi ... 85461.html
May I politely suggest that you grow up, gain some maturity, and calm down.
Edit:
Is it just me or are folks these days too impatient and demanding to work out solutions to their problems even when others have provived step by step instructions on how to do so?
Andyroo
Fri Jul 12, 2019 11:39 pm
Actually not all USB to sata adapters work with the Pi 3B+ - I have a pile of USB 2 and USB 3 ones that work fine in SD/HDD mode but not in HDD only mode. A two second search on this forum would have shown that as a regular issue here.
Any new computer system has had issues - if you think things not working at the start is new to this industry you are sadly deluded - just look at Windows 3.1 and 3.1.1 to say nothing of versions of DOS or CP/M
Till a couple of weeks ago the Pi 4 was a ‘wish list’ item so this was a none issue and is waiting awhile that much of an issue?
Also please watch your phrasing - this is a family friendly forum.
thagrol
Fri Jul 12, 2019 11:46 pm
Not just new ones. I remeber working with a sysadmin back in the 90s whose rule was never touch an even numbered version of Oracle's database engine. Hi sjustification? That's the ones bugs get introduced on, they get fixed in the next odd numbered release.
No idea if there was anything to it, and frankly you could just as easily apply it the ootherway around.
Edit:
Now that I think about it, it wasn't because the even number version had more bugs but because the even numbered version were the ones where new features were introduced, which usually meant new and exciting bugs.
His theory was that the next odd numbered version would have those fixed.
thagrol
Fri Jul 12, 2019 11:51 pm
Easy? Yes.
Cheap? Yes
Fast? No
Reliable? No
Something I left out earlier:
You're forgetting that the primary purpose of the Pi was (and AFIK still is) providing cheap educational computers for kids to learn coding on. Not something that can easily be done with SSD or HDD storage.
As for "Reliable? No" I've only had one SD card go bad in the last 7 years, and that was on a 'droid tablet not a Pi. And what, precisely do you mean by "reliable" anyway? Your average desktop is a lot more vulnerable (and therefore less reliable) than the average Pi.
As for "Fast? No", in the real world "fast" is subjective and depends on much more that the speed of the storage medium.
I'd avise against you buying another computer (of any sort) ever again. You won't be satisfied with it and there'll always be a revised one coming along soon. Or car, or pretty much anything really.
HawaiianPi
Sat Jul 13, 2019 12:14 am
grayerbeard wrote:
Mon Jul 08, 2019 5:09 pm
Because of some security issue you can't just put a fresh Raspian on the drive on the USB it ONLY works with a copy of what is on the SD card
Wait, what? :?
That is absolutely not true. You can write a Raspbian image directly to the USB drive and copy the files from the "boot" partition to a FAT32 formatted micro SD card, and with a simple file edit it will boot fine (all you need to do is remove the command that launches the resize script from cmdline.txt). I've been meaning to do a full tutorial on this, but I've been dealing with some "life" nonsense and haven't had time.
Simple version of hybrid SD-USB boot tutorial:
  1. Write Raspbian image to USB drive with Etcher.
  2. Edit cmdline.txt to remove the resize script launch (see edit below).
  3. Copy files from USB "boot" partition to FAT32 micro SD card.
  4. Plug card and USB drive into Pi4 and boot it up.
Once the system is up and running, edit /etc/fstab to mount the card as /boot (so that kernel and firmware updates are correctly applied) and reboot. Also, for headless boot, put ssh and wpa_supplicant.conf files on the USB drive (not the card, because USB mounts as /boot initially).
Then, of course, you'll need to resize the 2nd partition...
EDIT:
Forgot to mention, when you remove the resize command from cmdline.txt, make sure you only leave a single space.
Gavinmc42
Sat Jul 13, 2019 12:27 am
And for education market I can see network booting would be a much higher priority than USB booting.
A classroom of Pi's without uSD's or USB drives that can going walking.
We keep thinking about our wants, but RPF has a Mission.
After spending 3 x times the cost of a Pi on memory this week, netbooting is making more sense now.
LTolledo
Sat Jul 13, 2019 3:44 am
After spending 3 x times the cost of a Pi on memory this week, netbooting is making now sense now.
hmmm...good point....
....and that's one good reasoning why netbooting is taking priority over USB boot....
...one of these days am going to try this method....
(help with some procedures... please.... ;) )
Some people be like:
Gavinmc42
Sat Jul 13, 2019 5:17 am
I will wait till it works, still need to get another Pi4 and a Gigabit switch and probably better cabling.
Seen 8, 16, 24, do they have 32 port switches?
Those would make sense in a classroom.
And with the faster LAN speed, how quick would they boot?
Especially if that was checked first in the Boot EEPROM.
Going to make school IT support so much easier.
With the right lesson plans autobooting etc.
I don't do this stuff so this is just a guess.
Now if they had 4A's with WiFi boot, no need for the LAN stuff.
Might need bigger EEPROM for those?
I use old Dell monitors with USB hubs in them, great use for 3A+.
But the Official Pi keyboard has a hub, use it with 4A?
Whoops more brain dumping.
gsh
Sat Jul 13, 2019 7:02 am
Probably around another two or three weeks for Ethernet booting, another month for USB flash booting
Gordon Hollingworth PhD
Raspberry Pi - Director of Software Engineering
Gavinmc42
Sat Jul 13, 2019 7:57 am
Thanks Gordon for the update.
So if you guys had waited for those two issues to be fixed there would be about 1/2 Million Pi's sitting in a warehouse or two.
The Pi3B+ was the second version, the Pi3B did not have USB boot on release either.
I imagine if there is ever a 4B+ it would boot from USB, Network etc on release.
Some people are never happy.
Nice mindset.
Mountains out of molehills?
Old timers are grateful for hardware that works faster and software that will just get better if we have patience.
I wonder about those that complain the most, how much coding experience they have.
