I got 41c on boot up after it had cooled down while I put my Pibow Coupe case on. 56c now after sitting idle with just the desktop open.
EDIT: 51c now with the heatsink on. Will try the fan shim when I get one.
In many different benchmarks, the Raspberry Pi 4 was delivering performance similar to the ASUS Tinker Board with its Rockchip Quad-Core RK3288. The Raspberry Pi 4 performance is certainly a dramatic upgrade over the Raspberry Pi 3 on the CPU front.
Passive heatsinks at a minimum are a must with the Raspberry Pi 4. Even with some included aluminum passive heatsinks, under load the average temperature of the SoC was 71 degrees or 83 degrees peak over various benchmarks as outlined in this OpenBenchmarking.org result file.
Looks interesting, but twice the price of the Flirc pre-order.galicin wrote: ↑Fri Jul 12, 2019 10:49 amI did pre-order this - https://geekworm.com/collections/new-ar ... tive-shell (will share results once I have it).
Wow, you decide that will be your first post here.well after trawling through all the posts in this thread it seems pretty clear that the official pi4 case is not fit for purpose and they should stop selling it with immediate effect.
Some litigious types could make this thing cost them serious money if they don't get a handle on it...
This looks very cool. Like it was designed by Porsche.galicin wrote: ↑Fri Jul 12, 2019 10:49 amI did pre-order this - https://geekworm.com/collections/new-ar ... tive-shell (will share results once I have it).
Mine works absolutely fine with the Pibow coupe case and the fan shim using the provided script. My point was that the 'official' case is just not fit for purpose because it cooks the device.Gavinmc42 wrote: ↑Sat Jul 13, 2019 12:17 amWow, you decide that will be your first post here.well after trawling through all the posts in this thread it seems pretty clear that the official pi4 case is not fit for purpose and they should stop selling it with immediate effect.
Every Desktop I have had has had a fan or three.
I use a modified old case, top on when travelling , top off if temp get near 70C.
Maybe the new case was designed to be used like that?
For the RPF mission teaching Kids, access to GPIO is needed for physical computing, top off
A small heatsink helps, a fan even the smallest makes a big difference.
And the talk about suing? Either a lawyer or troll?
So any pics of the smallest fan used so far?
Throttling due to heat is not the same as malfunctioning. If the hardware fails due to the heat, then yes that would be an issue, but there is no sign of that. If the official case was causing the Pi 4 to downclock to the lowest possible clockspeeds and still remain at the thermal limit, you might have an argument.
Throttling starts at 80C.the_atmosphere wrote: ↑Sun Jul 14, 2019 7:18 ami'm using the case that came in the pishop / buyapi kit
my 4b idles at 65 temp=65.0'C
running the apple II screensaver in xsavers it goes up to temp=83.0'C
i didn't use the little heatsinks they sent with it, because i read they weren't really needed, and i was sure i would mess up putting it on straight, and also i wasn't sure where to put the second one, but i later found a graphic depicting it. i might try those little heatsinks but don't expect it to go down more than a degree or 2 if at all.
at what temperature does the cpu throttling precisely?
They will likely make a big difference for relatively transient peak loads. However, if you are running your Pi within a more or less tightly sealed case, continuous high loads will result in the whole volume of the inside of the case heating up and your heatsinks will only result in more rapid thermal equilibration of the chips with the overheated air within the case.
HawaiianPi wrote: ↑Sat Jul 06, 2019 10:30 pmAnyone ordered one of these yet? It's supposed to work on Pi 3B and 4B.
Picture is link (available for pre-order).
