pleriche
Fresh Stretch install - WiFi not working
Wed Jun 12, 2019 9:42 pm
I have an original Pi Model B which has been running Wheezy all this time, connecting to WiFi with a USB dongle (RTL5370) which I'm tryng to upgrade to Stretch.
I downloaded the latest Stretch (with desktop but without recommended software) and copied it to a fresh SDCard. To /boot I wrote a file ssh and a wpa_supplicant.conf file containing a copy of the wpa_supplicant.conf from my Wheezy installation.
I booted it up but it didn't connect to WiFi so I had to pull the plug. So I connected a screen and keyboard/mouse to see what was going on, and plugged in an ethernet cable. On the next boot I got a desktop and ssh login but shortly after I got segmentation faults to anything I did. I reseated the SDCard and rebooted, and this time it seemed stable but still not connected to WiFi.
lsusb shows the dongle is being recognised.
lsmod shows the rt2800usb module loaded.
ifconfig shows wlan0 with a credible MAC address but not connected.
/etc/wpa_supplican/wpa_supplicant.conf contains what it should, in fact identical to the Wheezy vertion.
/etc/network/interfaces just contains a pointer to /etc/network/interfaces.d, which is empty.
/etc/dhcpcd.conf has no mention of wlan0 and only commented lines relating to eth0.
What gives?
davidcoton
Re: Fresh Stretch install - WiFi not working
Wed Jun 12, 2019 10:13 pm
What gives?
Since Wheezy, wpa_supplicant has aquired an extra line defining the country, so as to enforce regional rules on WiFi channels. Does your version contain that? It might help to post the contents (with the passcode redacted).
Signature retired
HawaiianPi
Wed Jun 12, 2019 10:26 pm
I have a USB WiFi dongle with that same chipset and it works on my Pi Zero and Pi 2B with the latest Raspbian Stretch with Desktop.
As suggested above, something may be wrong with your old wpa_supplicant.conf file. Mine looks like this.
update_config=1
country=GB
network={
	ssid="WiFi SSID"
	psk="WPA/WPA2 passphrase"
	key_mgmt=WPA-PSK
Edit country=, ssid= and psk= with your information and save the file.
pleriche
Thu Jun 13, 2019 7:42 am
I do have the country line. In fact I didn't get the wpa_supplicant.conf from the old Wheezy system (as it was necessarily offline at the time!) but from a Pi 3 running Jessie. Here it is (redacted):
update_config=1
country=GB
network={
        ssid="AR9716_std"
        psk="***********"
        key_mgmt=WPA-PSK
        id_str="home"
network={
        ssid="BTBusinessHub-572"
        psk="*************"
        id_str="church"
network={
        ssid="Philip's iPhone 5S"
        psk="*************"
        key_mgmt=WPA-PSK
B.Goode
Thu Jun 13, 2019 8:04 am
First line is incorrect.
ctrl_interface
MrEngman
Thu Jun 13, 2019 8:05 am
There is a character "c" missing from the first line of the file which would cause your problem, but possibly it is a typo.
MrEngman
pleriche
Thu Jun 13, 2019 10:15 am
OK, thanks all. Simple problem: 1 character short when I selected the text to copy and paste.
As I aways say, there's no such thing as a hard problem - but some easy problems are hard to find.
