skcasb
How to check the filesystem to find errors
Wed Jun 12, 2019 9:43 am
Hi to all,
Do you know if there is a command to check the filesystem for errors without repair it ?
I try to use this command on my mounted filesystem (raspbian stretch on usb)
 fsck.ext4 -c /dev/sda1
unfortunately I receive the below message that warns me that I can damage the filesystem if I continue
"WARNING!!! The filesystem is mounted. If you continue you ***WILL*** cause ***SEVERE*** filesystem damage."
rpdom
Re: How to check the filesystem to find errors
Wed Jun 12, 2019 9:49 am
Yes, fsck -n /dev/sda1
But it will probably detect errors as the filesystem is in use and will be changing during the check..
Unreadable squiggle
Andyroo
Wed Jun 12, 2019 10:21 am
Best to boot off a new SD card, mount the faulty one, take a copy of it and then fix the errors.
