Infraviolet
espeak and aplay broken
Sun Jun 09, 2019 7:11 pm
I've been using espeak as a speech synthesizer in a project on a pi. I've now gone and flashed a new microSD card to use in another project and have tried to set it up the same as the old microSD card, but espeak is refusing to work, and aplay is cutting off just after the "cen" of "centre" when I do
"aplay /usr/share/sounds/alsa/Front_Center.wav" . I think the problem is in alsa somewhere but haven't a clue how to fix it. Everything works fine with the other raspbian install on the other SD card but I need this one too work properly too, they are from the same initial version burned to the card with win32 diskimager and then updated with sudo apt-get update/upgrade/dist-upgrade to be the most recent versions possible. The other Sd card might be using a slightly older version of alsa/espeak..., the new card was updated today, the other hasn't been updated for a few months, but I'm not sure which version of what program I'd have to roll back to to fix this. I've tried removing pulseaudio as much advice online claims this conflicts with alsa, but it isn't apparently installed anyway, I've edited /usr/share/alsa/alsa.conf so that:
pcm.front cards.pcm.default
pcm.rear cards.pcm.default
pcm.center_lfe cards.pcm.default
and so forth with all the others going to default too.
None of this has helped. I just want to make the audio output, especially for espeak, on this sd card like it is on my other. I've checked the full history of terminal commands run on the good sd card and see nothing of relevance to audio which I haven't run on this card too.
I have tried running espeak as sudo and that doesn't help either.
espeak gives the following errors:
sudo espeak -ven-rp+m2 -s150 -g8 "again and again and again"Expression 'alsa_snd_pcm_hw_params_set_period_size_near( pcm, hwParams, &alsaPeriodFrames, &dir )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 924
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition 'defaults.bluealsa.device'
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4996:(snd_config_expand) Args evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM bluealsa
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2048
Expression 'PaAlsaStreamComponent_InitialConfigure( &self->playback, outParams, self->primeBuffers, hwParamsPlayback, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2722
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
wave_open_sound > Pa_OpenStream : err=-9997 (Invalid sample rate)
Thank you
P.S. I'm playing out of the 3.5mm jack and have enforced this in raspi-config, I also output the audio as a single channel through physical pin 12.
Andyroo
Re: espeak and aplay broken
Sun Jun 09, 2019 7:30 pm
Not a fix but I was updating a Zero today and noticed that all the updates seemed to be audio related.
It may be worth trying a basic Raspbian build and then updating module by module till you hit the iffy one.
Not sure if I have a Pi thats not upto date to list the modules for you though :cry:
Silverlock
Sun Jun 09, 2019 7:40 pm
I reported a likely related problem with audio output from the 3.5mm jack in the thread Audio playback truncation with kernel packages 1.20190517-1.
I was able to reproduce the problem you're having with espeak and aplay with kernel 4.19.42-v7+ (package version 1.20190517-1).
No audio from espeak, just the same pages of errors you saw.
truncates the output as "Front Cen".
truncates the output as "Front" (play is from the sox package, and where I first noticed problems with the new kernel).
With kernel 4.14.98-v7+ (package version 1.20190401-1), espeak, aplay and play all work fine sending audio thru the 3.5mm jack.
USB audio output with kernel 4.19.42-v7+ works fine too. Whatever's been changed in the kernel, the problem seems to be limited to the 3.5mm audio jack.
RPi3+external HDD/Raspbian Stretch
hippy
Sun Jun 09, 2019 9:03 pm
With kernel 4.14.98-v7+ (package version 1.20190401-1), espeak, aplay and play all work fine sending audio thru the 3.5mm jack. ... Whatever's been changed in the kernel, the problem seems to be limited to the 3.5mm audio jack.
Odd; for me it fails on both audio jack and HDMI, aplay cuts out on "Front cen" in both cases as described ...
[email protected]:~/tmp $ uname -a
Linux Pi3B 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
[email protected]:~/tmp $ aplay /usr/share/sounds/alsa/Front_Center.wav
Playing WAVE '/usr/share/sounds/alsa/Front_Center.wav' : Signed 16 bit Little Endian, Rate 48000 Hz, Mono
I have my Pi use espeak to tell me its IP address etc, and I haven't noticed anything odd with that but there's something going on.
I do recall there having always been loads of errors spat out by espeak when I have used it but this works for me, analogue and HDMI -
[email protected]:~/tmp $ espeak "front center" --stdout > x.wav
[email protected]:~/tmp $ aplay x.wav
Playing WAVE 'x.wav' : Signed 16 bit Little Endian, Rate 22050 Hz, Mono
Espeak also works with longer phrases. So why does this work but the /usr/share/sounds/alsa/Front_Center.wav not ? Sample rate seems the only thing different.
Infraviolet
Sun Jun 09, 2019 10:11 pm
Does this mean I should roll back the kernel then? I've done it once or twice on an x86 linux PC but how is that done on a pi? Thanks
P.S. just checked and on the good Sd card I'm running "Linux raspberrypi 4.14.70-v7+ #1144 SMP Tue Sep 18 17:34:46 BST 2018 armv7l GNU/Linux" according to uname -a .
Silverlock
Sun Jun 09, 2019 11:33 pm
I forgot about HDMI audio; oops, mea culpa. Okay, it happens with HDMI and the audio jack, but there is at least one USB audio adapter that seems to work fine with the new kernel.
It's not just the Front_Center.wav file, that was just a handy example. It happens with wav's recorded from arecord, wav's generated by pico2wave, wav's from packages (as seen in the speaker-test files for one), etc. I've tried sample rates from 16K up to 44.1K on the wav's I've generated from arecord and it doesn't seem to make any difference.
If the kernel driver wasn't handling the last partial chunk of audio properly anymore, that might explain why shorter files seem to have the problem whereas longer files don't; it's just more noticeable with shorter files because there's fewer full chunks to hear. I know with very short files, like the Google Assistant listening/thinking sounds, I don't hear anything at all when I try to play them with sox's play.
Silverlock
Sun Jun 09, 2019 11:38 pm
That's what I did on the system I was having trouble with; rolled the kernel back to 4.14.xxx. I was lucky and had another system that I hadn't upgraded yet, so I just dug into the /var/cache/apt/archives directory and grabbed the 1.20190401-1 deb files from there and used dpkg to overwrite the 1.20190517-1 (4.19.42-v7+) kernel.
I vaguely recall that there's a way to do a rollback with apt-get and specifying a hash for the particular kernel you want (from reading threads where people used rpi-update when they shouldn't have), but I'm not up on the specifics.
hippy
Tue Jun 25, 2019 5:30 pm
Just to note that, whatever the problem is, it's still foreshortening to "Front Cen" using Buster on a 3B -
Linux Pi3B 4.19.50-v7+ #896 SMP Thu Jun 20 16:11:44 BST 2019 armv7l GNU/Linux
laloshifrin
Wed Jul 31, 2019 7:53 am
This workaround works for me:
add the environment variable: PA_ALSA_PLUGHW=1
https://www.raspberrypi.org/forums/view ... 6&t=241814 if you want more reference
hippy
Wed Jul 31, 2019 12:23 pm
https://www.raspberrypi.org/forums/view ... p?t=241814 if you want more reference
That doesn't work for me even after the latest (today's, 2019-07-31) update, upgrade and reboot.
In fact, whether a result of this last upgrade or otherwise, as well as getting truncation, "Front Cen", I am sometimes losing the start as well, "Cen", and am now fairly regularly getting bizarre "Cen Front Cen".
It all feels to me like something has gone very wrong with buffering somewhere.
My Python code which shells out for an espeak "My IP address is x.x.x.x" --stdout | aplay is also dropping the start of that when it was previously working, though so far it seems only immediately after a reboot, and not always.
I'll also post this to the linked thread.
