Bluetooth and hciuart not working
Posted: Sat Jun 08, 2019 3:31 am
(I also posted this in the sticky bluetooth thread)
I bought a Pi 3 and used the image from an older Pi 2 (so there was no bluetooth on it). Now, although though the new Pi supports bluetooth, I'm having some trouble getting it working on my image ("Raspbian GNU/Linux 9 (stretch)", upgraded from jessie).
On startup, bluetooth is not enabled:
I can start the bluetooth service:
But when I try to start hciuart it says:
And bluetoothctl says "No default controller available" when I try to do anything with it.
On the advice of Douglas6, I unmasked the hciuart service, but now it cannot be found at all:
I tried updating the firmware with rpi-update, but that did not fix the problem.
Any help would be appreciated,
thanks
$ service bluetooth status
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
$ service hciuart status
● hciuart.service
Loaded: masked (/dev/null; bad)
$ sudo modprobe btusb
$ sudo systemctl start bluetooth
Active: active (running) since Sun 2019-06-02 18:26:20 AEST; 15s ago
Main PID: 1958 (bluetoothd)
Status: "Running"
CGroup: /system.slice/bluetooth.service
└─1958 /usr/lib/bluetooth/bluetoothd
Jun 02 18:26:20 Raspberry-Pi systemd[1]: Starting Bluetooth service...
Jun 02 18:26:20 Raspberry-Pi bluetoothd[1958]: Bluetooth daemon 5.43
Jun 02 18:26:20 Raspberry-Pi systemd[1]: Started Bluetooth service.
Jun 02 18:26:20 Raspberry-Pi bluetoothd[1958]: Starting SDP server
Jun 02 18:26:20 Raspberry-Pi bluetoothd[1958]: Bluetooth management interface 1.14 initialized
Failed to start hciuart.service: Unit hciuart.service is masked.On the advice of Douglas6, I unmasked the hciuart service, but now it cannot be found at all:
Unit hciuart.service could not be found.Any help would be appreciated,
thanks
