a7md0
[VNC] Enable access for new user?
Tue Jun 04, 2019 1:35 am
Basically, I have VNC enabled from raspi-config and created new user with sudo permission. When I try to connect from VNC Viewer, I receive "Access is denied" error.
I did some search and found out that I should login using pi user and give access to other users from GUI. Unfortunately, I already deleted pi user completely. I cannot find any document about giving user permission from CLI :(
Is there anyway to do that without going into GUI?
sconemad
Re: [VNC] Enable access for new user?
Tue Jun 04, 2019 8:57 am
The default settings are to allow access to anyone in the sudo group. Is this how you enabled sudo access for your user (or did you add the user to /etc/sudoers)?
Alternatively, you can set the VNC permissions to allow your user directly. The file you need to edit is /root/.vnc/config.d/vncserver-x11 and
you'll need to add (or edit) the "Permissions" line, as described here:
https://www.realvnc.com/en/connect/docs ... ermissions
Something like this should do it:
Permissions=user:f
Where user is your username, and 'f' means full permissions.
a7md0
Thu Jun 06, 2019 4:07 am
Permissions=user:f
I just added the user to /etc/sudoers. I did some research and did this
usermod -aG sudo <username>
Anyway, when connecting I receive this message "Cannot currently show the desktop". I already added
Permissions=<username>:f
to
sconemad
Thu Jun 06, 2019 8:58 am
This is because VNC normally requires a desktop to be running on the console in order to provide access. You have two options here:
  • Set your Pi to boot to desktop from raspi-config by going to Boot options > Desktop/CLI > Desktop, then reboot.
  • Enable "direct capture" mode for the VNC Server, which will enable it to work without an X desktop running. To do this edit /root/.vnc/config.d/vncserver-x11 and add the line "CaptureTech=raspi", and restart the VNC Server.
