Powering pump
Posted: Sat May 25, 2019 3:30 pm
by FrankRPI
Hi, I am trying to power a small pump using my raspberry pi 2b. If i connect it directly to the 3.3v output it works. However, when i connect it with an gpio output it doesn't... I am guessing the pump requires too much current from the gpio pin? Is there a sollution where i can still use a gpio to control the pump? I have looked for relays, but cant find any that not designed for higher voltages like 230V. Any ideas?
Re: Powering pump
Posted: Sun May 26, 2019 2:05 am
by EZKernel
clicky but cheap:
https://www.amazon.ca/ELEGOO-Channel-Op ... r=8-3&th=1
silent but expensive:
https://www.amazon.ca/Lerway-Solid-Stat ... way&sr=8-5
for the clicky one:
if your pump runs off of the 3.3v it has some king of internal relay that needs that voltage to trigger, in which case you can just use that 3.3v from the pi into the relay (relay is powered by 5v rail), then use the pi to turn the relay on/off and the will be closing the power connection to the pump.
Re: Powering pump
Posted: Sun May 26, 2019 8:10 am
by Imperf3kt
What kind of pump is it? Is it a water pump for liquid cooling or something? Generally these are impellers and don't require a huge amount of current to move the liquid because there's not much pressure.
Or is it like a small tap pump out of a caravan or something? This will require a large current (~1.5A @ 12v) and certainly should not be powered via the Pi.
Re: Powering pump
Posted: Sun May 26, 2019 8:56 am
by LTolledo
what is the nameplate rating of the pump?
The usual suggested connection pattern is:
[RPi]---[transistor switch]---[relay board] ---[pump]
and usually for this kind projects utilizing AC mains.... a stern warning is given to would be enthusiast.....
so if you are not a licensed electrical technician/professional (or not supervised by one) then its best to consult them first...
otherwise there can be serious consequences to you, your family, or your neighborhood.....
Re: Powering pump
Posted: Sun May 26, 2019 9:13 am
by FrankRPI
This is the pump:
https://m.banggood.com/Mini-Submersible ... mds=search.
I want to use it to water a plant.
Re: Powering pump
Posted: Sun May 26, 2019 10:07 am
by pcmanbob
You will not be able to run that pump directly off a gpio pin , it will draw more than the 16mA a gpio pin can supply.
Nor would I run it from the 3.3v supply on the pi as a motor will produce voltage spikes when switched off that could easily damage the 3.3v supply on your pi.
I would recommend you use a separate 3v power supply for the pump and then use a transistor to switch the pump on & off.
like this
now the transistor /resistor selection will depend on the current draw by your pump, but as your link to the supplier does not list a current draw you will have to measure it your self and then select a suitable transistor.
Re: Powering pump
Posted: Sun May 26, 2019 12:10 pm
by PhatFil
clicky but cheap:
for the clicky one:
Afaik Unlike mechanical relay options you need to use current specific SSRS for AC and DC loads, an AC SSR will not work for a DC load and visa versa.
