Any one having problems with printing laterly
Posted: Fri May 24, 2019 11:30 pm
by paulsiu
I have been using a Raspberry PI for a printer server for about 2 years now. The PI has been hooked up to a Brothers HL-2240D laser printer. I had use CUPS and the hpijs drivers.
One day, the server stopped working and the files were corrupted. I had image backup the sdcard using AOMEI backupper, but surprisingly, the restore sdcard didn't boot, so I had to download Raspbian NOOB and recreate the server. This time around, I can't get printing to work. I install CUPS and HPIJS and then proceeded to add the printer, which worked fine until I print a test page. Now I get get a filter error. I looked in /var/logs/cups/error_log, but the message were not helpful even when I up the debug level to the max. All it said was that it can't get a page count when it's printing.
I had looked online and there were some messages talking about about hpijs not working any more. Is there an issue with the latest raspian and printing from CUPS?
Paul
Re: Any one having problems with printing laterly
Posted: Mon May 27, 2019 9:11 am
by paulsiu
So the issue does appear to be related to the release. When I downloaded Jessie and tried to install the print driver, it worked just fine. I think there are probably issues with Stretch, CUPS and the hpijs driver.
Posted: Mon May 27, 2019 9:49 am
by fruitoftheloom
https://packages.debian.org/stretch/pri ... iver-hpijs
It states that hplip is an advisable install !
sudo apt update
sudo apt install system-config-printer printer-driver-hpijs hplip
Posted: Thu May 30, 2019 7:46 am
by paulsiu
Thanks, I believe I did try that and it didn't seemed to work. Maybe the packages have to be installed in a particular order? I suppose Jessie work well enough for now. My only concern would be security patching, so I may try stretch again later.
Paul
