ElCrouchoGrande
Printing to Selphy 1300
Tue May 21, 2019 8:22 pm
Hi guys,
I'm a newbie to Raspberry Pi and having some trouble adding a printer, I've no doubt I'm making a really basic mistake but can't work out what and can't see a solution in past posts.
I have Raspberry Pi 3 model B and a Canon Selphy 1300 printer. I can find the printer and add it across the wireless network but when I try to print it says "cannot print incompatible images" on the printer. When I try to connect with USB, the printer won't even turn on - if I plug the USB in after the printer is turned on, CUPS just can't find the printer.
I've installed the latest instance of CUPS and I'm on Gutenprint 5.2.11. There isn't a driver for the Selphy CP1300, so I used Selphy CP910 which seems to be common.
Any help making this work would be hugely appreciated!
Thanks,
Paul
Re: Printing to Selphy 1300
Wed May 22, 2019 3:51 am
Removed as better solution offered which may help OP ?
Last edited by fruitoftheloom on Sun May 26, 2019 5:51 am, edited 1 time in total.
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
Dinah546
Fri May 24, 2019 9:19 am
Hi guys,
Thanks,
Paul
the questions myself too, no experiences?
ctrlw
Sat May 25, 2019 10:10 pm
Hi Paul,
I couldn't try myself (still waiting for my print media), but maybe these links are helpful:
* https://github.com/reuterbal/photobooth ... INSTALL.md
Gets Gutenprint 5.2.13 by adding a newer repository which contains drivers for SELPHY CP 1200 (similar to CP 1300).
* https://www.voss.earth/2018/08/31/kurzt ... verwenden/
Also got the CP 1300 running over wifi, and links the .ppd file used. However, this description is in German.
All the best,
Markus
scruss
Sun May 26, 2019 12:37 am
The CP 1300 supports AirPrint, which is just a fancy implementation of Internet Printing Protocol. So it should work if you install IPP support:
sudo apt install cups-ipp-utils system-config-printer
(leave off system-config-printer if you’re running from the terminal.)
Once that's installed, the system should find the printer automatically if it's on the same network. This doesn't work over USB.
Sun May 26, 2019 5:53 am
Hi Paul,
All the best,
Markus
Canon Selphy CP910 for my Photo Booth
The Original Poster is using a Selphy1300 which is not listed under Gutenprint ??
adieu
