dknute
Report: 3.6.7+ issues
Wed Nov 28, 2012 10:27 am
I'm running firmware revision d27ca5e5f1c3a94a0a1311e4c0dd86644f0acacc, the bleeding edge git stuff. I was trying to recompile the kernel to have a build base for my out-of-tree DVB dongle driver. Since that takes time I just run it during the night on detached tmux session.
The actual source/build directory is on NFS share that I mounted - I don't want to stress my SD card, and it's a dedicated 100Mb LAN segment to my Linux router so equally as fast. This time I also started DVB-T stream to see how stable it would be and how long it'd take to build the kernel like that.
In the morning I found that I can't SSH to my Pi and it's not reachable by ping. TV was unusable due to frozen overlay from omxplayer taking up all screen (now this could've happened in the morning where I lost power to my DVB-T antenna, but I know that once the stream is gone the player will not pick up even if the power is back - I tested that earlier). So I assumed the USB link is gone and just cycled power. I did try to unplug/plug back Ethernet before that and the link LEDs did go off and on again. Didn't help though.
This is what I found in the /var/log/syslog:
Nov 27 22:04:07 raspberrypi kernel: [26586.553501] cma: dma_alloc_from_contiguous(cma cb801ba0, count 64, align 6)
Nov 27 22:04:07 raspberrypi kernel: [26586.555114] cma: dma_alloc_from_contiguous(): returned c078d000
Nov 27 22:04:07 raspberrypi kernel: [26586.555147] cma: dma_alloc_from_contiguous(cma cb801ba0, count 64, align 6)
Nov 27 22:04:07 raspberrypi kernel: [26586.555810] cma: dma_alloc_from_contiguous(): returned c078d800
Nov 27 22:04:30 raspberrypi kernel: [26609.836819] cma: dma_alloc_from_contiguous(cma cb801ba0, count 64, align 6)
Nov 27 22:04:30 raspberrypi kernel: [26609.837923] cma: dma_alloc_from_contiguous(): returned c07b3800
Nov 27 22:04:30 raspberrypi kernel: [26609.837957] cma: dma_alloc_from_contiguous(cma cb801ba0, count 64, align 6)
Nov 27 22:04:30 raspberrypi kernel: [26609.839014] cma: dma_alloc_from_contiguous(): returned c07b4000
Two bursts of this weird stuff, at 22:04:07 and 22:04:30. This is more or less when I started the build and TV stream, is it the memory transfer happening? Then some peace and finally swapper failure:
Nov 28 00:01:07 raspberrypi kernel: [33605.687834] swapper: page allocation failure: order:0, mode:0x20
Nov 28 00:01:07 raspberrypi kernel: [33605.687909] [<c0013a7c>] (unwind_backtrace+0x0/0xf0) from [<c009265c>] (warn_alloc_failed+0xc4/0x11c)
Nov 28 00:01:07 raspberrypi kernel: [33605.687942] [<c009265c>] (warn_alloc_failed+0xc4/0x11c) from [<c009496c>] (__alloc_pages_nodemask+0x3e0/0x63c)
Nov 28 00:01:07 raspberrypi kernel: [33605.687972] [<c009496c>] (__alloc_pages_nodemask+0x3e0/0x63c) from [<c02e5864>] (__netdev_alloc_frag+0xc4/0xe4)
Nov 28 00:01:07 raspberrypi kernel: [33605.688001] [<c02e5864>] (__netdev_alloc_frag+0xc4/0xe4) from [<c02e996c>] (__netdev_alloc_skb+0x40/0xd0)
Nov 28 00:01:07 raspberrypi kernel: [33605.688030] [<c02e996c>] (__netdev_alloc_skb+0x40/0xd0) from [<c0269838>] (rx_submit+0x1c/0x1f8)
Nov 28 00:01:07 raspberrypi kernel: [33605.688064] [<c0269838>] (rx_submit+0x1c/0x1f8) from [<c0272754>] (usb_hcd_giveback_urb+0x60/0xf4)
Nov 28 00:01:07 raspberrypi kernel: [33605.688099] [<c0272754>] (usb_hcd_giveback_urb+0x60/0xf4) from [<c0298b2c>] (_complete+0xb8/0x1dc)
Nov 28 00:01:07 raspberrypi kernel: [33605.688127] [<c0298b2c>] (_complete+0xb8/0x1dc) from [<c029aaf4>] (handle_hc_xfercomp_intr+0x2fc/0x41c)
Nov 28 00:01:07 raspberrypi kernel: [33605.688153] [<c029aaf4>] (handle_hc_xfercomp_intr+0x2fc/0x41c) from [<c029b4d4>] (dwc_otg_hcd_handle_hc_n_intr+0x3a4/0x5c0)
Nov 28 00:01:07 raspberrypi kernel: [33605.688178] [<c029b4d4>] (dwc_otg_hcd_handle_hc_n_intr+0x3a4/0x5c0) from [<c029b75c>] (dwc_otg_hcd_handle_hc_intr+0x6c/0x80)
Nov 28 00:01:07 raspberrypi kernel: [33605.688202] [<c029b75c>] (dwc_otg_hcd_handle_hc_intr+0x6c/0x80) from [<c029b920>] (dwc_otg_hcd_handle_intr+0x1b0/0x1f4)
Nov 28 00:01:07 raspberrypi kernel: [33605.688225] [<c029b920>] (dwc_otg_hcd_handle_intr+0x1b0/0x1f4) from [<c0299280>] (dwc_otg_hcd_irq+0xc/0x18)
Nov 28 00:01:07 raspberrypi kernel: [33605.688249] [<c0299280>] (dwc_otg_hcd_irq+0xc/0x18) from [<c0271d04>] (usb_hcd_irq+0x2c/0x44)
Nov 28 00:01:07 raspberrypi kernel: [33605.688287] [<c0271d04>] (usb_hcd_irq+0x2c/0x44) from [<c0078524>] (handle_irq_event_percpu+0x50/0x1b0)
Nov 28 00:01:07 raspberrypi kernel: [33605.688314] [<c0078524>] (handle_irq_event_percpu+0x50/0x1b0) from [<c00786d8>] (handle_irq_event+0x54/0x84)
Nov 28 00:01:07 raspberrypi kernel: [33605.688342] [<c00786d8>] (handle_irq_event+0x54/0x84) from [<c007aa74>] (handle_level_irq+0x98/0x108)
Nov 28 00:01:07 raspberrypi kernel: [33605.688368] [<c007aa74>] (handle_level_irq+0x98/0x108) from [<c0077e1c>] (generic_handle_irq+0x28/0x40)
Nov 28 00:01:07 raspberrypi kernel: [33605.688402] [<c0077e1c>] (generic_handle_irq+0x28/0x40) from [<c000e91c>] (handle_IRQ+0x30/0x84)
Nov 28 00:01:07 raspberrypi kernel: [33605.688428] [<c000e91c>] (handle_IRQ+0x30/0x84) from [<c039a8b4>] (__irq_svc+0x34/0xc8)
Nov 28 00:01:07 raspberrypi kernel: [33605.688456] [<c039a8b4>] (__irq_svc+0x34/0xc8) from [<c01ed5a0>] (memcpy+0x240/0x330)
Nov 28 00:01:07 raspberrypi kernel: [33605.688466] Mem-info:
Nov 28 00:01:07 raspberrypi kernel: [33605.688474] Normal per-cpu:
Nov 28 00:01:07 raspberrypi kernel: [33605.688485] CPU    0: hi:  186, btch:  31 usd:  24
Nov 28 00:01:07 raspberrypi kernel: [33605.688510] active_anon:9731 inactive_anon:59 isolated_anon:0
Nov 28 00:01:07 raspberrypi kernel: [33605.688510]  active_file:21805 inactive_file:23203 isolated_file:0
Nov 28 00:01:07 raspberrypi kernel: [33605.688510]  unevictable:0 dirty:7 writeback:0 unstable:0
Nov 28 00:01:07 raspberrypi kernel: [33605.688510]  free:52991 slab_reclaimable:2978 slab_unreclaimable:1091
Nov 28 00:01:07 raspberrypi kernel: [33605.688510]  mapped:3192 shmem:68 pagetables:278 bounce:0
Nov 28 00:01:07 raspberrypi kernel: [33605.688563] Normal free:211964kB min:8192kB low:10240kB high:12288kB active_anon:38924kB inactive_anon:236kB active_file:87220kB inactive_file:92812kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:483488kB mlocked:0kB dirty:28kB writeback:0kB mapped:12768kB shmem:272kB slab_reclaimable:11912kB slab_unreclaimable:4364kB kernel_stack:1296kB pagetables:1112kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Nov 28 00:01:07 raspberrypi kernel: [33605.688574] lowmem_reserve[]: 0 0
Nov 28 00:01:07 raspberrypi kernel: [33605.688592] Normal: 14141*4kB 14141*8kB 2642*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 211964kB
Nov 28 00:01:07 raspberrypi kernel: [33605.688637] 45082 total pagecache pages
Nov 28 00:01:07 raspberrypi kernel: [33605.688645] 0 pages in swap cache
Nov 28 00:01:07 raspberrypi kernel: [33605.688654] Swap cache stats: add 0, delete 0, find 0/0
Nov 28 00:01:07 raspberrypi kernel: [33605.688661] Free swap  = 102396kB
Nov 28 00:01:07 raspberrypi kernel: [33605.688668] Total swap = 102396kB
Nov 28 00:01:07 raspberrypi kernel: [33605.714291] 121856 pages of RAM
Nov 28 00:01:07 raspberrypi kernel: [33605.714301] 53312 free pages
Nov 28 00:01:07 raspberrypi kernel: [33605.714308] 2684 reserved pages
Nov 28 00:01:07 raspberrypi kernel: [33605.714315] 4069 slab pages
Nov 28 00:01:07 raspberrypi kernel: [33605.714322] 18419 pages shared
Nov 28 00:01:07 raspberrypi kernel: [33605.714328] 0 pages swap cached
Followed by kevent 2 dropped, and other failures:
Nov 28 00:01:07 raspberrypi kernel: [33605.740886] smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped
Nov 28 00:01:29 raspberrypi kernel: [33627.207451] warn_alloc_failed: 22 callbacks suppressed
Nov 28 00:01:29 raspberrypi kernel: [33627.207485] ksoftirqd/0: page allocation failure: order:0, mode:0x20
This pretty much fills my log until the reboot in the morning. So the Pi did not die completly, in fact the last DHCP request to my router was sent at 04:32:38 Pi time. Cron was running as well. The last entries before the reboot:
Nov 28 06:21:25 raspberrypi kernel: [56421.955357] smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped
Nov 28 06:21:25 raspberrypi kernel: [56421.955506] ld: page allocation failure: order:0, mode:0x20
Nov 28 06:21:25 raspberrypi kernel: [56421.955554] [<c0013a7c>] (unwind_backtrace+0x0/0xf0) from [<c009265c>] (warn_alloc_failed+0xc4/0x11c)
Nov 28 06:21:25 raspberrypi kernel: [56421.955578] [<c009265c>] (warn_alloc_failed+0xc4/0x11c) from [<c009496c>] (__alloc_pages_nodemask+0x3e0/0x63c)
Nov 28 06:21:25 raspberrypi kernel: [56421.955601] [<c009496c>] (__alloc_pages_nodemask+0x3e0/0x63c) from [<c02e5864>] (__netdev_alloc_frag+0xc4/0xe4)
Nov 28 06:21:25 raspberrypi kernel: [56421.955622] [<c02e5864>] (__netdev_alloc_frag+0xc4/0xe4) from [<c02e996c>] (__netdev_alloc_skb+0x40/0xd0)
Nov 28 06:21:25 raspberrypi kernel: [56421.955644] [<c02e996c>] (__netdev_alloc_skb+0x40/0xd0) from [<c0269838>] (rx_submit+0x1c/0x1f8)
Nov 28 06:21:25 raspberrypi kernel: [56421.955670] [<c0269838>] (rx_submit+0x1c/0x1f8) from [<c0272754>] (usb_hcd_giveback_urb+0x60/0xf4)
Nov 28 06:21:25 raspberrypi kernel: [56421.955695] [<c0272754>] (usb_hcd_giveback_urb+0x60/0xf4) from [<c0298b2c>] (_complete+0xb8/0x1dc)
Nov 28 06:21:25 raspberrypi kernel: [56421.955716] [<c0298b2c>] (_complete+0xb8/0x1dc) from [<c029aaf4>] (handle_hc_xfercomp_intr+0x2fc/0x41c)
Nov 28 06:21:25 raspberrypi kernel: [56421.955735] [<c029aaf4>] (handle_hc_xfercomp_intr+0x2fc/0x41c) from [<c029b4d4>] (dwc_otg_hcd_handle_hc_n_intr+0x3a4/0x5c0)
Nov 28 06:21:25 raspberrypi kernel: [56421.955754] [<c029b4d4>] (dwc_otg_hcd_handle_hc_n_intr+0x3a4/0x5c0) from [<c029b75c>] (dwc_otg_hcd_handle_hc_intr+0x6c/0x80)
Nov 28 06:21:25 raspberrypi kernel: [56421.955772] [<c029b75c>] (dwc_otg_hcd_handle_hc_intr+0x6c/0x80) from [<c029b920>] (dwc_otg_hcd_handle_intr+0x1b0/0x1f4)
Nov 28 06:21:25 raspberrypi kernel: [56421.955789] [<c029b920>] (dwc_otg_hcd_handle_intr+0x1b0/0x1f4) from [<c0299280>] (dwc_otg_hcd_irq+0xc/0x18)
Nov 28 06:21:25 raspberrypi kernel: [56421.955808] [<c0299280>] (dwc_otg_hcd_irq+0xc/0x18) from [<c0271d04>] (usb_hcd_irq+0x2c/0x44)
Nov 28 06:21:25 raspberrypi kernel: [56421.955835] [<c0271d04>] (usb_hcd_irq+0x2c/0x44) from [<c0078524>] (handle_irq_event_percpu+0x50/0x1b0)
Nov 28 06:21:25 raspberrypi kernel: [56421.955855] [<c0078524>] (handle_irq_event_percpu+0x50/0x1b0) from [<c00786d8>] (handle_irq_event+0x54/0x84)
Nov 28 06:21:25 raspberrypi kernel: [56421.955877] [<c00786d8>] (handle_irq_event+0x54/0x84) from [<c007aa74>] (handle_level_irq+0x98/0x108)
Nov 28 06:21:25 raspberrypi kernel: [56421.955896] [<c007aa74>] (handle_level_irq+0x98/0x108) from [<c0077e1c>] (generic_handle_irq+0x28/0x40)
Nov 28 06:21:25 raspberrypi kernel: [56421.955921] [<c0077e1c>] (generic_handle_irq+0x28/0x40) from [<c000e91c>] (handle_IRQ+0x30/0x84)
Nov 28 06:21:25 raspberrypi kernel: [56421.955940] [<c000e91c>] (handle_IRQ+0x30/0x84) from [<c039a8b4>] (__irq_svc+0x34/0xc8)
Nov 28 06:21:25 raspberrypi kernel: [56421.955965] [<c039a8b4>] (__irq_svc+0x34/0xc8) from [<c02c9c74>] (sdhci_spin_lock+0x54/0x5c)
Nov 28 06:21:25 raspberrypi kernel: [56421.955988] [<c02c9c74>] (sdhci_spin_lock+0x54/0x5c) from [<c02cc9dc>] (sdhci_bcm2708_dma_irq+0x20/0x2cc)
Nov 28 06:21:25 raspberrypi kernel: [56421.956010] [<c02cc9dc>] (sdhci_bcm2708_dma_irq+0x20/0x2cc) from [<c0078524>] (handle_irq_event_percpu+0x50/0x1b0)
Nov 28 06:21:25 raspberrypi kernel: [56421.956028] [<c0078524>] (handle_irq_event_percpu+0x50/0x1b0) from [<c00786d8>] (handle_irq_event+0x54/0x84)
Nov 28 06:21:25 raspberrypi kernel: [56421.956048] [<c00786d8>] (handle_irq_event+0x54/0x84) from [<c007aa74>] (handle_level_irq+0x98/0x108)
Nov 28 06:21:25 raspberrypi kernel: [56421.956067] [<c007aa74>] (handle_level_irq+0x98/0x108) from [<c0077e1c>] (generic_handle_irq+0x28/0x40)
Nov 28 06:21:25 raspberrypi kernel: [56421.956086] [<c0077e1c>] (generic_handle_irq+0x28/0x40) from [<c000e91c>] (handle_IRQ+0x30/0x84)
Nov 28 06:21:25 raspberrypi kernel: [56421.956103] [<c000e91c>] (handle_IRQ+0x30/0x84) from [<c039a8b4>] (__irq_svc+0x34/0xc8)
Nov 28 06:21:25 raspberrypi kernel: [56421.956130] [<c039a8b4>] (__irq_svc+0x34/0xc8) from [<c0025814>] (__do_softirq+0x54/0x154)
Nov 28 06:21:25 raspberrypi kernel: [56421.956150] [<c0025814>] (__do_softirq+0x54/0x154) from [<c0025d28>] (irq_exit+0x8c/0x94)
Nov 28 06:21:25 raspberrypi kernel: [56421.956168] [<c0025d28>] (irq_exit+0x8c/0x94) from [<c000e920>] (handle_IRQ+0x34/0x84)
Nov 28 06:21:25 raspberrypi kernel: [56421.956184] [<c000e920>] (handle_IRQ+0x34/0x84) from [<c039a8b4>] (__irq_svc+0x34/0xc8)
Nov 28 06:21:25 raspberrypi kernel: [56421.956203] [<c039a8b4>] (__irq_svc+0x34/0xc8) from [<c0095a68>] (test_set_page_writeback+0x100/0x190)
Nov 28 06:21:25 raspberrypi kernel: [56421.956225] [<c0095a68>] (test_set_page_writeback+0x100/0x190) from [<c0184b28>] (nfs_do_writepage+0x190/0x28c)
Nov 28 06:21:25 raspberrypi kernel: [56421.956245] [<c0184b28>] (nfs_do_writepage+0x190/0x28c) from [<c01854e8>] (nfs_writepages_callback+0xc/0x20)
Nov 28 06:21:25 raspberrypi kernel: [56421.956263] [<c01854e8>] (nfs_writepages_callback+0xc/0x20) from [<c00965f0>] (write_cache_pages+0x1d0/0x3c8)
Nov 28 06:21:25 raspberrypi kernel: [56421.956280] [<c00965f0>] (write_cache_pages+0x1d0/0x3c8) from [<c0185c4c>] (nfs_writepages+0xa4/0x128)
Nov 28 06:21:25 raspberrypi kernel: [56421.956299] [<c0185c4c>] (nfs_writepages+0xa4/0x128) from [<c00978e0>] (do_writepages+0x24/0x38)
Nov 28 06:21:25 raspberrypi kernel: [56421.956327] [<c00978e0>] (do_writepages+0x24/0x38) from [<c008eee4>] (__filemap_fdatawrite_range+0x4c/0x54)
Nov 28 06:21:25 raspberrypi kernel: [56421.956348] [<c008eee4>] (__filemap_fdatawrite_range+0x4c/0x54) from [<c008efd0>] (filemap_write_and_wait_range+0x40/0x6c)
Nov 28 06:21:25 raspberrypi kernel: [56421.956374] [<c008efd0>] (filemap_write_and_wait_range+0x40/0x6c) from [<c0179c74>] (nfs_file_fsync+0x2c/0x74)
Nov 28 06:21:25 raspberrypi kernel: [56421.956403] [<c0179c74>] (nfs_file_fsync+0x2c/0x74) from [<c00e7664>] (vfs_fsync+0x3c/0x4c)
Nov 28 06:21:25 raspberrypi kernel: [56421.956429] [<c00e7664>] (vfs_fsync+0x3c/0x4c) from [<c00be8a8>] (filp_close+0x34/0x88)
Nov 28 06:21:25 raspberrypi kernel: [56421.956448] [<c00be8a8>] (filp_close+0x34/0x88) from [<c00be9cc>] (sys_close+0xd0/0x134)
Nov 28 06:21:25 raspberrypi kernel: [56421.956467] [<c00be9cc>] (sys_close+0xd0/0x134) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
Nov 28 06:21:25 raspberrypi kernel: [56421.956473] Mem-info:
Nov 28 06:21:25 raspberrypi kernel: [56421.956480] Normal per-cpu:
Nov 28 06:21:25 raspberrypi kernel: [56421.956488] CPU    0: hi:  186, btch:  31 usd:   8
Nov 28 06:21:25 raspberrypi kernel: [56421.956507] active_anon:7347 inactive_anon:7790 isolated_anon:0
Nov 28 06:21:25 raspberrypi kernel: [56421.956507]  active_file:27169 inactive_file:25450 isolated_file:0
Nov 28 06:21:25 raspberrypi kernel: [56421.956507]  unevictable:0 dirty:2239 writeback:197 unstable:0
Nov 28 06:21:25 raspberrypi kernel: [56421.956507]  free:36505 slab_reclaimable:6500 slab_unreclaimable:1263
Nov 28 06:21:25 raspberrypi kernel: [56421.956507]  mapped:2130 shmem:67 pagetables:248 bounce:0
Nov 28 06:21:25 raspberrypi kernel: [56421.956547] Normal free:146020kB min:8192kB low:10240kB high:12288kB active_anon:29388kB inactive_anon:31160kB active_file:108676kB inactive_file:101800kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:483488kB mlocked:0kB dirty:8956kB writeback:788kB mapped:8520kB shmem:268kB slab_reclaimable:26000kB slab_unreclaimable:5052kB kernel_stack:1240kB pagetables:992kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Nov 28 06:21:25 raspberrypi kernel: [56421.956555] lowmem_reserve[]: 0 0
Nov 28 06:21:25 raspberrypi kernel: [56421.956568] Normal: 30627*4kB 2939*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 146020kB
Nov 28 06:21:25 raspberrypi kernel: [56421.956602] 52686 total pagecache pages
Nov 28 06:21:25 raspberrypi kernel: [56421.956608] 0 pages in swap cache
Nov 28 06:21:25 raspberrypi kernel: [56421.956615] Swap cache stats: add 0, delete 0, find 0/0
Nov 28 06:21:25 raspberrypi kernel: [56421.956621] Free swap  = 102396kB
Nov 28 06:21:25 raspberrypi kernel: [56421.956627] Total swap = 102396kB
Nov 28 06:21:25 raspberrypi kernel: [56421.975285] 121856 pages of RAM
Nov 28 06:21:25 raspberrypi kernel: [56421.975293] 36785 free pages
Nov 28 06:21:25 raspberrypi kernel: [56421.975298] 2684 reserved pages
Nov 28 06:21:25 raspberrypi kernel: [56421.975304] 7763 slab pages
Nov 28 06:21:25 raspberrypi kernel: [56421.975309] 14683 pages shared
Nov 28 06:21:25 raspberrypi kernel: [56421.975314] 0 pages swap cached
Nov 28 06:21:25 raspberrypi kernel: [56421.975585] smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped
Nov 28 06:21:26 raspberrypi kernel: [56423.225088] warn_alloc_failed: 172130 callbacks suppressed
I have no idea why TCP was non-functional at this time but with all these errors anything could've happened. I am running my Pi overclocked but this is the first time I saw anything like this.
My cmdline.txt and config.txt:
coherent_pool=2M cma=2M smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
gpu_mem=316
cma_lwm=16
cma_hwm=32
boot_delay=0
disable_overscan=1
hdmi_drive=2
#framebuffer_depth=24
#framebuffer_ignore_alpha=1
arm_freq=900
core_freq=450
sdram_freq=450
dknute
Re: Report: 3.6.7+ issues
Wed Nov 28, 2012 9:50 pm
Same thing (page allocation failure) happened during another build run during the day, and this time it was the only task I started. Curiously the build took some 30min longer than usual but it finished successfully. Well I can't say much about the integrity of these files but there weren't any fatal errors or anything.
The Pi does slowly break down as this happens though, things no longer work as supposed to. For example plugging in a DVB-T dongle got noticed by kernel, all syslog entries looked good, but the tzap could not be run - complained about not being able to open/create /dev/dvb/adapter0/dvr0. Free showed tons of free RAM and not a single byte of swap being used. Again, a reboot fixed it.
I'm going to try again with overclocking disabled.
dknute
Thu Nov 29, 2012 10:29 am
More swapper: page allocation failures even with default clocking. This is the last straw I'm afraid, going back to 3.2.27+ now. I like this new CMA stuff and DVB-T drivers but unless my Pi actually survives the night it's not much of use.
