Narsil
sudo hostname problem
Sun May 19, 2019 2:50 pm
Hi folks,
Hope you read french enough to point the problem ;)) :
[email protected]:~ $ sudo pkill deluge-web
sudo: impossible de déterminer le nom de l'hôte raspberrypi
[email protected]:~ $ cat /etc/hosts
127.0.0.1	localhost
::1		localhost ip6-localhost ip6-loopback
ff02::1		ip6-allnodes
ff02::2		ip6-allrouters
127.0.1.1	RaspberryDeluge
[email protected]:~ $ cat /etc/hostname
RaspberryDeluge
Suggestion ?
THX
epoch1970
Re: sudo hostname problem
Sun May 19, 2019 7:31 pm
If you just changed the host name you need to reboot for the change to be fully taken into account.
Traditionally a unix/linux hostname is written entirely in lowercase. CamelCase should work ok as well.
