oshry70
PI 3 apache web server "href " link to anither html page
Sun May 19, 2019 8:40 am
HI,
i installed apache on PI 3 the page is index.php and i have nav bar with some links to another html page in my website the problem is when i put the path to the html page i get the error "the requested url was not found http://localhost movies/index.html"
the movies folder is inside html folder i gave permission to the folder and all files .
in my laptop all work great . maybe the path is different in raspberry pi??
thanks for help
Ernst
Re: PI 3 apache web server "href " link to anither html page
Sun May 19, 2019 8:48 am
Do you notice the problem above ? You should look at the URL to find out why you are using local host.
And you should find out why there is a space in the URL (cut&paste error ?)
ankith26
Sun May 19, 2019 1:58 pm
You have to be careful while writing the path. Remember "movies" and "Movies" are two different words.
Also make sure that the index.html file exists
My website is at https://pratt.ml
Hope it runs (which it wont)
oshry70
Mon May 20, 2019 5:28 am
i didn't change nothing i copy the same files from my PC windows 10 and website work fine with all path
but when i copy to PI3 i get this error ... maybe the path for the HTML file in sub-directory is different from windows 10 ?
Ernst
Mon May 20, 2019 7:29 am
Solving a problem like this remotely is like blind brain surgery with chopsticks, to be able to succeed lots of information is needed. Please answer all the questions below.
a) you have a website on your windows 10 PC that looks to be working correctly.
a few questions:
- do you have apache2 installed on the PC ?
- what browser did you use to test your website ?
- where did you use the browser ?
- what is the URL you used to open the website.
b) you have copied website on from your windows 10 PC to a raspberry pi.
a few questions:
- how did you copy the files ?
- do you have apache2 installed on the Pi ?
and at last (for the moment), please post the code (href) giving you problems using [code] [/code] tags in your reply to this post.
oshry70
Mon May 20, 2019 7:51 am
a) you have a website on your windows 10 PC that looks to be working correctly. = yes
a few questions:
- do you have apache2 installed on the PC ? yes i use xampp server with apache for this website
- what browser did you use to test your website ? chrome or Edge
- what is the URL you used to open the website. = localhost
b) you have copied website on from your windows 10 PC to a raspberry pi. = yes
a few questions:
- how did you copy the files ? copy paste as is
- do you have apache2 installed on the Pi ? yes
- what browser did you use to test your website ? i use the default browser and chrome
this is the code in main page Index.html
movies is folder in
<li><a href="MOVIES/INDEX.HTML">MOVIES</a>
Ernst
Mon May 20, 2019 8:23 am
Do you understand that Windows file systems are case-insensitive and Linux file systems are case-sensitive ?
What this means it that the filename "MOVIES" or "movies" are the same under Windows but different under Linux.
Please keep this in mind.
Do you understand that in a Windows file system there is a "hidden" attribute that does not exist under Linux ?
Under Linux a leading "." is used for hidden files, you can see this using the "ls -la" command.
Please keep the above in mind, it could be important.
I do not like the way you have specified the href= because it is too loose, doing some research I found the following:
An absolute URL contains all the information necessary to locate a resource. A relative URL locates a resource using an absolute URL as a starting point. ... A relative URL typically consists only of the path, and optionally, the resource, but no scheme or server.
in my documentation I found the following information:
With a relative URL, you provide an abbreviated document address that, when automatically combined with a "base address" by the system, becomes a complete address for the document.
In your case "http://localhost" is being combined with "MOVIES/INDEX.HTML" giving the absolute URL "http://localhost MOVIES/INDEX.html" (watch the space, I don't know why this happens)
The solution to this might be simple: if the directory MOVIES is in the base directory of the site then use the following:
<a href="/MOVIES/INDEX.HTML">MOVIES</a>
if the directory MOVIES is in a directory below another directory under where the source page is located:
<a href="./MOVIES/INDEX.HTML">MOVIES</a>
In any case you have to cleanup your site to use lowercase only because soon you will run into a problem and wonder why.
oshry70
Mon May 20, 2019 8:55 am
many thanks it's works :D
the problem that is all the files need to be with lower case
Ernst
Mon May 20, 2019 9:11 am
No problem, lower case is the better choice.
Andyroo
Mon May 20, 2019 12:52 pm
Do not do it by hand - a quick Google will show you lots of ways to do it from the command line - if you do not understand the command try it on a backup first :lol:
